Author Topic: Help! CB550F , thick or thin washer for All Balls steering bearing upgrade ?  (Read 986 times)
Offline eworth
Thanks in advance for the help...
Was bored before Packer game and installed the All Balls tapered steering bearing races in steering neck before I compared bottom bearing height to determine if I needed to install the thin or thick washer.    :-[ :-[
I know, I know, bonehead move on my part.      It's a 77 CB550F.
Can anyone tell me if I should install the thin or thick washer  on my CB550F to match the height of the original set up?
Would really appreciate the info.
Thanks!
Mark in Wisconsin aka eworth
Offline Trav-i
  • Has finally become an
For what it's worth, I've done 2 All Balls kits and both took the thin shim.  Just my past experiences.
Forum member #9962
1992 GL1500 Interstate
Offline eworth
Hi, thanks for the reply.
Were they CB550s?
Offline Trav-i
They were both 750s.
Forum member #9962
Offline eworth
ok,  thanks.  I've seen a few mention both ways,   thick and thin.    Leaning towards the thin washer as you have done.
Hoping a few with cb550s will also chime in as well.
Thanks again!!
