Author Topic: Fairing Clearance Against Alternator Cover  (Read 1855 times)
srook
« on: January 17, 2011, 08:37:13 AM »
For those that are running full fairings, how much clearance do you have between the fairing and the alternator cover?  My fairing just touches the lower part of the cover.  I can space it out but it is already out there.  Should there be some gap or is it ok to touch the cover?
Thanks
Scott
Re: Fairing Clearance Against Alternator Cover
« Reply #1 on: January 17, 2011, 10:24:59 AM »
I guess the true CR would have a narrower alternator, so that would fix it.   :D
I've seen others where a hole is cut in the fairing to allow the alternator cover to poke through about an inch or so. Otherwise its going to look like its not fitting.
IMO
Offline Really?
« Reply #2 on: January 17, 2011, 10:29:15 AM »
CycleX has a teeny exposed one.  He wants $450 for it too.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
  • Moderator
« Reply #3 on: January 17, 2011, 12:13:03 PM »
Scott, is this the Dunstall fairing that you posted at the bottom of this page. http://forums.sohc4.net/index.php?topic=81403.msg916379#msg916379
If so it should fit with the big alternator cover as it was just an after market product for a road bike.
Sam. ;)
srook
« Reply #4 on: January 17, 2011, 02:08:44 PM »
Yes, Dunstall fairing for a road bike.  Not looking for a different alternator solution.  Its supposed to stick out like it does.  I know some of you are running full fairings.  How close is your alternator cover to the fiberglass and have you experienced any problems with heat?
Thanks
Scott
  • Moderator
« Reply #5 on: January 17, 2011, 02:20:07 PM »
The fairing on the CR in my avatar rubbed on the genny cover when it ran with the stock motor.
I put a thin peice of rubber where it touched to stop it wearing through the glass untill we got the factory CR cover.
If you can't make your's clear with the brackets, just do as I did, no one will see it.
Sam. ;)
srook
« Reply #6 on: January 17, 2011, 09:44:51 PM »
Just what I was looking for.
Thanks Sam
Offline lordmoonpie
    • Moonpie
« Reply #7 on: January 18, 2011, 01:19:55 AM »
Scott, if you're bothered about heat, get down to your local hardware store and buy a plumbers soldering mat - should be able to get about a 12" square mat made of ceramic material. I then use fibreglass resin to stick that to the inside of the fairing. The mat is used by plumbers to blowtorch solder heating joints without burning the wall/floor behind the mat and it works great in fairings to stop heat transfer from the engine and paint discolouration. Should only cost a couple of dollars too! ;D
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
