It might do you some good to consider your condensers too. If one of them has failed it will kill - or greatly impair - the spark generated for its associated coil. If you find you have a set of burned points, its probably because the condenser associated with that points set has begun to go bad (leak down badly). If you like you can picture it in your mind this way, every time your plugs fire with that great big jolt of electricity, well, a second smaller jolt shoots back down the small wire to the points, and it is the job of the condenser to absorb that jolt. When the condenser begins to fail the pulse of power finds its way to the point's face, and begins to erode it. So your dead points may in fact just be a symptom of bad condensers.
Might help, might not, 50-50 chance.
