Author Topic: Homemade Mid Controls for CB750 - w/ PICS  (Read 5541 times)
Offline hallin222
« on: January 21, 2011, 11:17:44 AM »
Hey, everyone.  This is one of my first posts, but I've been a lurker here for some time, getting ideas for a project I'm working on for a friend of mine.  It was good running, but asthetically mediocre, near-stock 1976 CB750K (except exhaust and seat) that we decided to cafe.  I'll get some other, more general, project pics up later, but wanted to share a simple modification I've made this week.
I always thought the stock pegs were ugly and heavy, but the bike owner wanted to keep the stock peg location.  I thought I could improve on the stock pegs, so I began by making a cardboard template for a pair of footpeg support plates on the bike, and transfering that to some 3/8" aluminum.  Those arcs follow the contour of thelower frame rails, and those tabs fit the anti-rotation nubs that are welded to the frame.
Then cut them out on a band saw, and drilled the mounting stud holes.
Added some ideas for 'speed holes' and footpeg support location.
Then got to drilling...
The standoffs were also just notched on the bandsaw, then drilled & tapped on the rear, and drilled for peg mounting bolts.  I used 3/8 x 16 bolts for both the peg hinge and standoff ounts.  I would have liked to have used metric fasteners, but they're hard to find at the local hardware stores.  The rear of the mounting plates have since been drileld with a countersink bit to allow the bolt heads to sit flush.  This is especially important on the right side, as the oil line passed right across this area, and I didn't want any possible abrasions to it in the future.  The pegs were purchased of ebay for like $4 + $2 shipping.  No bad, and the knurled chrome matches the stock brake pedal quite well.
Here are some shots of them mounted.  I still need to sand & lightly polish them, but i wanted to share this with the forum.  I've learned a lot on here, and wanted to hopefully give some others ideas in return.  Thanks, everyone.
Right side:
Left side:
Before & After:
Rider View.  Yes, the right peg is further forward than the left.  This is how the stock pegs are positioned as well.  I thought about evening it out, by placing the right peg farther rearward, but realized the stock placement is to allow more toe clearance during kick starting.  Since this bike is currently kick-only, I left it where is was, within about 1/4" from the stock location:
« Last Edit: April 12, 2011, 10:14:51 PM by hallin222 »
Offline Roach
Re: Homemade Mid Controls for CB750 - w/ PICS
« Reply #1 on: January 21, 2011, 02:48:28 PM »
seem to have the talent a know how to make your own stuff....
why not make rearsets ???
1978 CB550K Cafe Racer
Offline nickandkristy02
« Reply #2 on: January 21, 2011, 02:54:00 PM »
"the bike owner wanted to keep the stock peg location." :P
Offline Roach
« Reply #3 on: January 21, 2011, 02:57:54 PM »
doh! missed that part while skimming :D
« Reply #4 on: January 21, 2011, 02:59:10 PM »
under achiever ;D
Offline underachiever
  • Squandering my potential since 1989
  • 77 CB550K
« Reply #5 on: January 21, 2011, 03:55:08 PM »
« Last Edit: January 21, 2011, 03:57:20 PM by underachiever »
Offline hallin222
« Reply #6 on: January 21, 2011, 04:56:12 PM »
Hey, CycleRanger, we're here in the ATX too.  Actually, I'm SW of town and the bike owner lives in San Marcos, but we're close.
Offline bluesmoke69
« Reply #7 on: January 21, 2011, 07:51:45 PM »
The blocks that the pegs are mounted to would look good with holes drilled threw them. Nice idea keep up the good work. If a guy had a bridge port he could make anything for bikes.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #8 on: January 21, 2011, 07:59:35 PM »
Great job.
Big improvement from stock.
Offline hallin222
« Reply #9 on: January 21, 2011, 09:04:04 PM »
The mounting bolt from the rear penetrates about 3/4 of the way through that square stock, so there would be no way of me to dill holes straight through it.  I wanted to be sure there was plenty of thread engagement so it didn't strip the aluminum threads I tapped.  I've thought about added some round divots to them, but didn't want to weaken the 7/8" square stock.  I'm sure it would be fine, though.  It may also look too 'busy' with those features added.
No Bridgeport used here.  This was all done with pretty basic tools.
-bandsaw
-drill press
-vertical belt sander
-hand files to tweak them after a test fit.
It could have all been done with only a band saw, hand drill, and hand sanding / filing, if your access to equipment is more limited than mine.
Today I added chamfered edges to all the holes and got those mounting bolts countersunk.  I'll try to get some higher resolution pics of the installation posted soon rather than those crappy cell phone shots.
Ian
Offline Really?
« Reply #10 on: January 21, 2011, 09:31:55 PM »
The only basic thing I see is that list are files.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
« Reply #11 on: January 22, 2011, 12:56:05 AM »
looks great..
 But are the pegs reversed..??..dont look like they would fold being hit from the front..
Offline hallin222
« Reply #12 on: January 22, 2011, 06:54:52 AM »
By 'basic' I meant nothing like a lathe or millling machine was used to produce these.  As a result, they're not perfect, but i wanted to show what's possible with some 'basic' tools.  Also, while not everyone has access to a band saw, almost anyone with any amount of tools will have a hand drill, sandpaper, and files.  You can often find used shop tools, like the others listed in my previous post, on Craigslist for under $100.
looks great..
Correct.  The pegs are designed to fit most modern sport bikes, and the knurled surface is rotated, offset, and angled upward compared to the pivot pin, so it's hard to get them to sit parallel to the ground.  Its hard to explain.  I may spend some more time doing some hand filing on the tabs of the standoff shafts to allow the pegs to rotate down and 'sag' more under rider weight.  That may allow me to swap sides and have them foldable in a more traditional manner.  I also plan to place an arced spring washer between the peg and the mounting shaft to add some friction and prevent the pedals from rattling.
« Reply #13 on: January 22, 2011, 07:57:08 AM »
You are correct about the basic tools.. anyone with a hackdaw, files drill, & sandpaper, and Desire.. should be able to build that.
 Do you have access to a lathe? You may be able to make washers(Uhmw or delrin) to tension the pegs a bit.
Offline hallin222
« Reply #14 on: January 22, 2011, 08:18:43 AM »
No lathe access, but I was just going to use something like these, as are used on my Harleys.
or
These should do the trick.
Offline Really?
« Reply #15 on: January 22, 2011, 08:48:07 AM »
Prolly shoulda put a  ;D behind that.  They peg setup does look good.  I guess I was thinking basic like 754 said.
I haveta go look at mine to see that the right peg is forward a bit.  What is funny, now that I think about it, my feet always felt funny on them.
Offline DV Red Herring
  • Army RETIRED
« Reply #16 on: November 20, 2017, 05:25:18 PM »
Sorry about the zombie reply to this thread. Can anyone post pics and info on this topic? I keep getting the photobucket account crap because of its age. Thanks guys.
« Reply #17 on: November 21, 2017, 03:16:40 AM »
There is a browser fix for photobucket on FireFox and Chrome I am certain of...I don't know about otber browsers or platforms...
David
« Reply #18 on: November 21, 2017, 03:28:47 AM »
David
http://forums.sohc4.net/index.php/topic,168102.msg1946279.html#msg1946279
I did the Photobucket fix that started to work after I had installed 2 of each.
I had to install Chrome Photobucket Embedded Image Fix too
Link in this thread refer to  photobucket embed fix
Yes, I see the photos at top of this page
Both add-ons:
https://chrome.google.com/webstore/search/photobucket%20embed%20fix?hl=sv
Firefox
This only did not help my computer
https://addons.mozilla.org/en-US/firefox/addon/photobucket-embedded-fix/?src=search
This did it
https://addons.mozilla.org/en-US/firefox/addon/photobucket-fixer/
« Last Edit: November 21, 2017, 04:22:56 AM by PeWe »
