Author Topic: Anybody have extra carb parts or a better exploded view with part numbers  (Read 769 times)
Offline greenjeans
  • 1972 CB750K2
75  750K5
Just got finished cleaning the nastiest most gunk filled carbs I've ever seen.    In the process, I lost a part.  The brass pin that holds the float to the posts inside the carb.
I also need some of the felt/synthetic washers/gaskets that go around the needle that the float closes - make sense ?
From the parts fische at servicehonda.com, it looks like i can order a replacement float (16011-375-004) but I only need the pin.
For the gaskets, looks like part number 16010-300-305 - $16.37 x 4
Me being a cheapskate, I was hoping that somebody might have a source for the gaskets & the float pin
Anyone ?
take float a pin to a welding supply store and see if they have some brass wire the same size,they might snip you off a little bit.
Offline greenjeans
  • 1972 CB750K2
Holy crap - didn't even think of that - my dad has a ton of brass wire.  great idea.
Now, for the gaskets etc.
Offline Trav-i
  • Has finally become an
I have a float pin handy if you want it.  It came from some junk carbs I had laying around.  PM me your address if you want it.
Forum member #9962
1992 GL1500 Interstate
