Author Topic: Question for anyone who glass bead/sand/soda blasts  (Read 1633 times)
Offline Rocker
  • The one, the only!
« on: January 23, 2011, 12:49:32 PM »
I just picked up this from Harbor Freight:
http://www.harborfreight.com/40-lb-capacity-floor-blast-cabinet-93608.html
I plan to soda/sand blast my bike parts and such. The air requirements of the cabinet are 12-15 cfm @ 90 psi. Lowe's has an 80 gallon compressor that will go 11.5 cfm @ 90 psi. Will the lack of 0.5 psi really make a noticeable difference?
For anyone that has the same cabinet..what compressor do you use and how are the results?
Basically I do not have to buy a bigger compressor then I need and have noticed once you go above the 12 cfm threshold the prices of compressors jump quickly.
Thanks
~Rocker (aka Adam) | rocker@sohc4.net | SOHC/4 member #4151 | Facebook
Current Bikes:
1975 CB750 K5 pic
1974 CB360T " lil' twin " Rebuild thread
1976 CB550 K2 Cafe Racer build thread
1975 CB550 K1 parts bike Parted out and cut up.
2003 VTX 1800C
Bikes I've had:
1974 CB550 K0
1976 CB750 K6
Offline MoMo
  • Ride like you're invisible
Re: Question for anyone who glass bead/sand/soda blasts
« Reply #1 on: January 23, 2011, 05:04:31 PM »
I have the same cabinet and a compressor similar to the one you are looking at, runs all the time when I am glass beading  :( :(
Buy the biggest compressor you can afford...Larry
Offline Rocker
« Reply #2 on: January 23, 2011, 05:07:45 PM »
How does it perform though? Running all the time is annoying but if it keeps up the cfm I can live with that.
Current Bikes:
1975 CB750 K5 pic
2003 VTX 1800C
Bikes I've had:
1974 CB550 K0
1976 CB750 K6
« Reply #3 on: January 24, 2011, 08:56:47 AM »
You really need a 2 stage compressor for large work.
Offline markb
  • When I finish my current project I might be a
« Reply #4 on: January 24, 2011, 11:04:02 AM »
Am I looking at the wrong thing?  The link shows a unit that says the air consumption is 9.5 cfm.  ???
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline CycleRanger
  • No comment about being an
« Reply #5 on: January 24, 2011, 11:30:21 AM »
I use this:
http://www.lowes.com/pd_221565-14989-LLA3706056_4294813361+5003702_4294937087_?productId=3115863&Ns=p_product_prd_lis_ord_nbr|0||p_product_quantity_sold|1&pl=1&currentURL=%2Fpl_400%2B600_4294813361%2B5003702_4294937087_%3FNs%3Dp_product_prd_lis_ord_nbr|0||p_product_quantity_sold|1&facetInfo=$400%20-%20$600
with the HF blasting cabinet.
60-Gallon Cast Iron Oil Lubricated Air Compressor with Heavy Duty Induction Motor
    * Cast iron, twin cylinder, oil lubricated pump features: one-piece cast iron crankcase, thermally stable cast iron cylinder body, aluminum head & machined cast iron valve plate, automotive style ball bearings, and durable stainless steel reed valves
    * Heavy duty induction motor for maximum performance and efficiency. 208-240 volt
    * Large capacity, 60 gallon ASME vertical tank provides more air for longer tool run times on air tools such as ratchets, impacts, spray guns, hammers, etc.
    * 155 PSI max pressure, 13.4 SCFM @ 40 PSI, 11.5 SCFM @ 90 PSI , 3.7 running HP
Works great!  (And I see it's cheaper now than when I got mine three years ago.)
Offline Rocker
« Reply #6 on: January 24, 2011, 11:57:57 AM »
I saw that 9.5 cfm rating on the site too but the operating manual says something different. I have attached the specs page.
Current Bikes:
1975 CB750 K5 pic
2003 VTX 1800C
Bikes I've had:
1974 CB550 K0
1976 CB750 K6
Offline Really?
« Reply #7 on: January 24, 2011, 12:02:01 PM »
I se a compressor that is rated lower than the cabinet.  It works fine for me.  I just pause a bit to let the compressor built up, oh maybe 20 seconds.  Cuts good down to 50psi with the black oxide stuff.
I sometimes have to lift the cabinet while my arms are in it and kind of bang it cause it will stop picking up the media.  Then is picks up fine.  I just put 10lbs of stuff in too.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Rocker
« Reply #8 on: January 24, 2011, 01:13:28 PM »
Called HFT technical support and they said there was a revision to their manual. The 9.5 CFM @ 90 psi is correct.
Current Bikes:
1975 CB750 K5 pic
2003 VTX 1800C
Bikes I've had:
1974 CB550 K0
1976 CB750 K6
Offline kirkn
« Reply #9 on: January 24, 2011, 01:32:13 PM »
I have that exact cabinet and blast with a compressor with only ~6 cfm at 90 psi.
I blast for 1 minute then my compressor starts.  I stop for 1 minute while my compressor pumps up and shuts off.  Then blast for 1 minute, etc etc.
I've never blasted for more than ~30 minutes at a time this way (small parts, etc).  But, I've been doing it for ~3 years.  Very satisfied, but probably doing harm to my cheap Craftsman compressor.
That all said - buy the biggest compressor you can afford.  Having MORE CFM than the spec sheet calls for is only better.  It has gotten kinda frustrating to stop and pause, but now I just live with it.
BTW, I'm VERY pleased with the cabinet.  A great bang for the buck, and I'm completely addicted to that nice clean bare metal...
Kirk
Offline MoMo
« Reply #10 on: January 24, 2011, 01:34:39 PM »
Does not do that very well :( but it is ok for the frequency I use it.  For everyday use the Kobalt recommended by cycle ranger would be the ticket...Larry
Offline Rocker
« Reply #11 on: January 24, 2011, 01:47:55 PM »
I read about a lot of people calking the isides and doing other small mods to make it work better. Have you done any to yours?
I was thinking about reinforcing the legs and building a frame with casters to move it around easier.
Current Bikes:
1975 CB750 K5 pic
2003 VTX 1800C
Bikes I've had:
1974 CB550 K0
1976 CB750 K6
Offline CycleRanger
« Reply #12 on: January 24, 2011, 02:45:55 PM »
Yep, I posted in some other thread about the HF cabinet.   It does need caulking.  Mine didn't come with a light inside, I had to install one.  Wheels would be a great addition!
And get a good shop vac or run a pipe outside to vent it.
I used my cabinet a lot when I got it as I was working on my car.  I don't use it every day now but it's really nice to have it available and the compressor of course has a 1001 uses!
Offline Rocker
« Reply #13 on: January 24, 2011, 02:54:17 PM »
I read about a lot of people calking the insides and doing other small mods to make it work better. Have you done any to yours?
I will probably end up with the compressor you linked above. I have a nice 6.5' tall Black Kobalt rolling tool chest. They would match :)
What size shop vac do you use on yours?
I have a 5 gallon Porter Cable pancake compressor so the addition of a high volume stationary unit would be great. I already have friends/family lining up for items to be blasted.
Current Bikes:
1975 CB750 K5 pic
2003 VTX 1800C
Bikes I've had:
1974 CB550 K0
1976 CB750 K6
Offline CycleRanger
« Reply #14 on: January 24, 2011, 07:32:53 PM »
Yeah, I looked at a lot of compressors and bang-for-the-buck I think it was a good deal. I've had it for three years with no issues.
I ran a vent outside and that works fine for glass beads but with soda I really could have used more active scavenging as it was a little hard to see the work sometimes.
