Author Topic: CB400 ignition switch wiring question  (Read 4596 times)
Offline -CB-Jamie-
« on: January 25, 2011, 10:25:07 AM »
I've been doing up a cb400f I picked up a few months ago and I'm having a small problem with the ignition switch wiring. The wires going to the ignition switch had been chopped off short so I soldered on new wires and got a new connector block and ignition switch.
My problem is I don't know which wire goes into which part of the connector block and i can't figure it out from the wiring diagram.
So if maybe somebody could take a pic of their block going on the igition switch or list the order they go I would
appreciate it.
Thanks in advance for any help.
72 CB350/4
76 CB400/4 CB400f "Project Resurrection"
77 CB550/4 1977 CB550 Yet Another Cafe
77 cb200
09 cbf600
Offline kajtek
Re: CB400 ignition switch wiring question
« Reply #1 on: January 25, 2011, 11:23:02 AM »
if i remember correctly there are 2 red, 2 black and one brown yes? if i get the chance later i will check it out as i shortened the wiring as i relocated it to under the tank...
if i get to post details later pm me to remind me!
ashley
1978 honda cb400f supersport
Offline kajtek
« Reply #2 on: January 25, 2011, 12:05:14 PM »
ok, went down and couldnt see it unless i get the tank off... might take it off 2mrw evening when i do a bit of cleaning, if no one else has got back to you will get a photo :)
Offline -CB-Jamie-
« Reply #3 on: January 25, 2011, 02:00:27 PM »
Thanks man appreciate it. Its 2 brown wires, 1 brown and white, 1 red and 1 black
72 CB350/4
77 cb200
09 cbf600
Offline rockvegas400
« Reply #4 on: January 26, 2011, 01:43:57 AM »
Jamie,
Attached is a diagram from the Haynes manual which should help.
Justin
1975 CB400F
1988 VFR750F-J
Offline -CB-Jamie-
« Reply #5 on: January 26, 2011, 05:08:15 AM »
Thats perfect thanks rockvegas, Thats another thing I can get sorted now and out of the way
72 CB350/4
77 cb200
09 cbf600
Offline Gnat
« Reply #6 on: January 26, 2011, 05:44:08 AM »
This is the link to my post on my wiring problem. This has the wire colors for the 350-400 in a diagram
http://forums.sohc4.net/index.php?topic=82742.0
Gnat
"Trying to keep the rubber side down"
