Author Topic: Race and Performance parts for sale and wanted.  (Read 294122 times)
0 Members and 9 Guests are viewing this topic.
Offline gschuld
Re: Race and Performance parts for sale and wanted.
« Reply #1000 on: January 08, 2016, 02:38:59 PM »
Looking to see who has vintage Venolia or RC Arias big bore pistons, 70, 71, 72, or 73mm that aren't currently being used.  Either 10.5:1 or 12.5:1 compression.   From destroyed right up to NOS.  Incomplete sets, whatever.  Just let me know what you have.
George
Offline Tintop
« Reply #1001 on: January 08, 2016, 03:44:15 PM »
Are you planning on opening an RC museum George???  ;D ;D ;D ;D ;D
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #1002 on: January 08, 2016, 04:45:19 PM »
I'm starting to wonder too Brian. ;D
Offline Bill/BentON Racing
    • BentON Racing
« Reply #1003 on: January 08, 2016, 05:01:10 PM »
Damn Mike, don't you recall...you da curator! ! Hehe.  ;D, Bill And over here is the RC kiln where I melt down old RC stuff! Oh no, Mr. Bill  ;) ;D
BentON Racing Website
BentON Racing Facebook
Offline gschuld
« Reply #1004 on: January 08, 2016, 05:58:56 PM »
Is that what you mean by "kiln" Billy? ;D..... ;)
Now Mike, we have been over this.  It's going to be an amusement the park.  Museums are too stuffy.  The kids need a realistic chance to hurt themselves for it to be fun for them :o.   Nothing says danger like a bunch of obsolete disco era facaca engine parts zipping around at 10,000rpm between your legs. ???
George
Offline hotdog
« Reply #1005 on: January 08, 2016, 06:02:11 PM »
George
What's your plans..? Measure weights etc..?
I have a new set of 10.5:1 70mm arias that are 10 or so years old, that are not for sale.
If you want weights or pics I can help with that.
Or are you looking for old school stuff..?
Edit : just re-read your post, vintage pistons - didn't see that first time round.
Sent from my HTC_M9u using Tapatalk
« Last Edit: January 08, 2016, 06:03:43 PM by hotdog »
Instagram - LUMPY CAM MOTORCYCLES
FB - LUMPY CAM Motorcycles
Offline gschuld
« Reply #1006 on: January 08, 2016, 06:58:14 PM »
Actually all of the above.  I am interested in specs on modern big bore pistons as well for reference.  I have recently spoken with Elmer at Arias about making me custom pistons.
If you were interested in weighing your pistons rings and pins(separately preferbly), I would be very grateful.
Frankie's (Dragracer) 1999 Arias 12.5:1 k head 73s came in at 190 grams bare, minus pin, rings, circlips.  That's pretty light.
I'm interested to see where yours come in.
George
Offline hotdog
« Reply #1007 on: January 09, 2016, 12:41:24 AM »
Here you go, all weights in grams. Manufactured in 2006
Specs sheet -
Piston bare -
Piston pin -
Ring set -
If you look at the job card, pins,clips and rings were to be customer supplied, they are wiseco - pic below.
I got these from Rob Boischeter (voxonda) and are for future use.
Regards.
« Last Edit: January 09, 2016, 12:43:03 AM by hotdog »
Offline dragracer
  • CB750F Dragbike
Re: RC454 cam wanted.
« Reply #1008 on: January 13, 2016, 01:31:42 PM »
I also posted this in the Wanted section but felt it might be wise to put it here also. I'm in search of a RC454 cam. Must be in good condition.
Let me know what you have. I'd like to keep my legs, arms and testicles so please don't beat me up on the price.
Thanks fellas.
Frank
Offline POPS 911
« Reply #1009 on: January 19, 2016, 05:36:25 AM »
FOR SALE : Mikuni=VM 29'-A7 w/chrome stacks and two Long swing arms [ 1 square w/ air in arm, 26" long and 1 round xtra strong 29" long like a PUPPET made ] use with shocks or struts.  Also a  MSD-1 with the BROWN wire.  Will bring to Valdosta Man Cup event. Like new stock carbs 27mm- CB750 w/chrome bowls, w/stacks .
Offline dragracer
  • CB750F Dragbike
« Reply #1010 on: January 22, 2016, 05:30:13 PM »
In
Pops,
What the width of the arm at the pivot point. Does it have roller bearings or bushings?? What's the width at the rear. Oh, I asking about the square tubing arm by the way.
Offline Old Scrambler
« Reply #1011 on: January 22, 2016, 06:30:05 PM »
FOR SALE...........Replica CB750 CR oil tank with Monza Lid.  MADE IN USA  All Alloy copy of the tanks used on the Daytona CB750 CRs with a few improvements. Same dimensions and ready to attach to your custom frame-mounts. Improvements include interior baffle-plates and metric-wrench bases at the bungs to prevent torquing the tank when attaching the oil-lines. All standard fittings for original oil-line fasteners.  We have sold one unit, have one in stock, and will take orders for more with a 60-day lead-time. The current tank has a 2-inch Monza lid. We can also fit the standard twist-cap with the dip-stick as used on the original Daytona racers, and an optional 2nd vent tube is available.
PRICE: $900 plus shipping and insurance from Wisconsin.  At the present, that's several hundred less then the units from England (if available) or Germany.
Thanks for looking............If you wish to order, please use a PM.
« Last Edit: January 22, 2016, 06:35:03 PM by Old Scrambler »
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline POPS 911
« Reply #1012 on: January 24, 2016, 05:31:03 AM »
FRANK in the 10's : This square tube swing arm is not a club footed but a well built gusseted PRO-MADE  8 7/8" between the mounts w/bushings , with a 16mm hole , axel is 20mm, and it is 9 3/4" between the rear inside slides, dual air fittings on side rail and cross brace that is gusseted, raises shock or strut mount that you can drill your own holes or use the 5 3/8" slide front or back pre-drilled holes for the adjustment of your needs. NO DINGS,NO RUST, STRAIGHT, COMPLETE ADJUSTER W/ BOLTS AND LOCK DOWN NUTS.
COMPARE Stock arm F =  9 1/16" Between mounts, hole 13mm [ you would be twisting with real power ] axel way smaller than 20mm [ you would be twisting that too ]
I did not measure with the dust caps on so that would add a little to the square or the stock F arm. But we race on a mostly clean tracks, so no dust caps but special made bronze bushings [ with anti size both sides ] so you can move the tire to the right to stop tire slap or sidewall wear  for a [ bigger -wider that stock rear tire ] you must have welded a ground down front sprocket onto another front sprocket to get that tire spacing in the old dayz !!!!!! then the dam chain wore a hole in the frame down tube = loved those KZ make one thing better makes a problem at another point.
    • BentON Racing
« Reply #1013 on: January 24, 2016, 06:45:15 AM »
Go Frank go. See Frank go...faster!! Hehe! K, Bill
Offline dragracer
  • CB750F Dragbike
« Reply #1014 on: January 24, 2016, 09:17:44 PM »
Real funny Bill, real funny!!  Just remember, everyone is looking at YOU to go quicker this season than i ever have on a Honda. Can't wait to see your low ten second time slip. :-)
    • BentON Racing
« Reply #1015 on: January 25, 2016, 04:42:16 AM »
Frank,  we hope so, it's a goal, we'll see if we can achieve it,  we are  trying, me working,  BabyFace watching! K, Bill
Offline POPS 911
« Reply #1016 on: January 25, 2016, 06:48:05 AM »
FRANK in the 10's :  That square tube arm is chrome-moly. I have those SUZUKI SWING ARMS you can cut off and add to make your stock arm longer. MSP JOE threw away into a roll off scrap container [ full of arms from the many bike he built over the years] = I took out the ones you could use down the road, and a  H2 swing arm for a old days KZ fix for longer. Get ready for a 1976 CB750A [ YOUR OWN ] powerglide to run in SE , HAPPY BIRTHDAY........ cleaning out my small building.
    • BentON Racing
« Reply #1017 on: January 25, 2016, 05:30:32 PM »
Look ma, it's dem old men, Frank and Bill, you know, the ones you said can't pull in a clutch, but can still cut a light and twist a throttle!  Ma, are they really 75? Lol.Gnight and G'luck to us, hehe!  Autos forever!! LMAO,  Bill
Offline dragracer
  • CB750F Dragbike
« Reply #1018 on: January 26, 2016, 10:33:21 AM »
FRANK in the 10's :   Get ready for a 1976 CB750A [ YOUR OWN ] powerglide to run in SE , HAPPY BIRTHDAY........ cleaning out my small building.
Pops,
 I may have to make plans to meet you at one of the races to pick up that GIFT. Never had an AUTO on my radar but I won't turn down a birthday present. At least Bill can then mentor me on how to make one go fast. Not trying to go slower in my old age, but sometimes you have to be wise to stay ahead in the race game.
Offline POPS 911
« Reply #1019 on: January 27, 2016, 05:48:02 AM »
Their you go AGAIN fast : Frank IN 10's take a old beater CB750A, getting it running, no money, get a lane and take this old beater to a slow win light against a $10,000 BUSA on the 1320' = when that green win light come on  YOUR SIDE OF THE LANES at the end of 1320', you will have a big smile on your face and the person in the other lane will limp back to the pits in SHAME .......... beat by a low cost [ in your case FREE ]  old ,heavy ,slow, but dead on the numbers S/ET bike. It's the riders  " EFFORT EQUALS RESULTS " that gets those WIN TICKETS !!!! in bracket racing.
Offline POPS 911
« Reply #1020 on: January 27, 2016, 06:29:01 AM »
TURBO-D: Just posted the Matic head in stock flowed better than a K stock head...... got a few stock Matic heads in the parts room and one that has been done by me, with a cam that I reworked ...... will measure the lift.
Offline POPS 911
« Reply #1021 on: January 28, 2016, 07:30:17 AM »
Chrome-moly arm 26" center to center = pulled back all the way for sale $200 you pay shipping or pick up at MAN CUP RACE.
Offline dragracer
  • CB750F Dragbike
« Reply #1022 on: January 29, 2016, 12:08:08 PM »
Pops,
I'm interested in the arm. Can you email me some pictures to: Nextplain@aol.com??
Offline Justind97
« Reply #1023 on: February 03, 2016, 08:32:45 AM »
NOS Yoshimura CB650 pistons
http://forums.sohc4.net/index.php/topic,154910.0.html
$350 plus shipping
Offline POPS 911
« Reply #1024 on: February 10, 2016, 06:38:13 AM »
29" long swing arm mention above with all the sizes = $200 you pay shipping in USA.
