Author Topic: Race and Performance parts for sale and wanted.  (Read 293990 times)
Offline slikwilli420
  • Master of Disaster
Re: Race and Performance parts for sale and wanted.
« Reply #1550 on: October 13, 2022, 06:31:42 AM »
Think it's time to buck up and put smoothbores on the race bike. Does anyone here have a lead on a decent set 29mm CR Specials that's being underutilized?
I see one used set on eBay in Canada that is of unknown history, but I'm kind of amazed there aren't more used sets around considering how long they've been available and how many are put on "custom" bikes that are probably only ridden a handful of times before they're put up to collect dust in the corner of a trendy clothing store.
They are relatively rare "race carbs", and tend to be expensive when you do find them. Have you considered Mikuni VMs?
CR carbs are worse than buying a new car. It seems as soon as they leave the original packaging, their value plummets. I just picked up a set that is all but brand new for $700 shipped. You can't touch VM29 smoothies for nearly twice that these days.
« Reply #1551 on: October 13, 2022, 04:29:52 PM »
The Kawasaki guys are mad for 29mm smoothbore carbs so they’re selling for over $1K USD for a worn out 40 year old set of carbs. I bought new RS34’s for $700 USD for my 1100cc Z1-B, and love them. ;D
Online Don R
« Reply #1552 on: October 13, 2022, 05:17:00 PM »
 The later ARD's (and it appears there are some different late model types) are also a magneto. The instructions clearly state; no battery voltage should be applied to any wire, especially the yellow which is a ground to a switch to kill the motor. Some have external coils and CDI box; other mark II types have points and no external box.
  The cap appears to be from a Fiat, maybe X19. Possibly off of a Magnetti Marelli distributor.
  Start searching for the 29 smoothbore spacing to 750 Honda carb adapter rubbers.  Sudco made some but I may have bought the last set in the wild. They are urethane rather than rubber. Edit; dime city and Z1 may have them now. Sudco 005.026 VM29 carb kit.
« Last Edit: October 13, 2022, 06:15:49 PM by Don R »
Offline Ramrod_Racing
« Reply #1553 on: October 14, 2022, 08:55:46 AM »
These are going on a late 650 head. I'll deal with and implementation snafu's when I have parts on hand. I have plenty of experience buying stuff that I thought would be needed for fitting other stuff on order, only to find out it was either the wrong thing or unnecessary.
Offline corky
« Reply #1554 on: October 16, 2022, 05:23:54 PM »
I have an RC Weber manifold for sale. I bought this from Frank 3-4 years ago for $300 + shipping, which is what I want for it. It has been polished and the rc emblem has been removed. The only reason I am parting with it is because I found one in more original condition (thank you greggo!).
Online Don R
« Reply #1555 on: October 18, 2022, 07:50:01 PM »
 That's a sweet manifold corky, I got an MTC style one, it uses straight rubbers and makes it difficult to get on. It was previously broken and then welded crooked, so I cut it apart and made it a bolt together unit.
  I've scrolled through here and searched ebay past sales. I'm trying to determine the value of an ATP early square fabbed and late style chromed turbo intake and a nice log style ATP exhaust with the back pipe and another set that a moron beat the snot out of. I'm sure it would take welding to repair it. Any ideas? Some guys on F/B were interested but I hadn't decided which ones to use on my build then.
« Last Edit: October 23, 2022, 10:43:52 PM by Don R »
Offline corky
« Reply #1556 on: October 24, 2022, 07:14:15 AM »
Good morning Don!
Those MTP manifolds are nice in the sense I think you have more room for air filters.  Long story, but my dad bought a weber setup in the 70’s, and we lost the intake maniold some how.  I found this one from Frank, but really wanted to find one that wasn’t polished and more original looking.  I finally found an original, and figure I can’t use both of them, lol.
It’s always hard to price old performance parts.  They are worth a lot to a select few, but not worth much to a lot of people.  I probably value them on the high side because I am an enthusiast.  From what I have seen, I feel like ATP intakes usually bring in $250-400 depending on their condition, and exhaust manifolds I would think would be valued around $200-300?  Complete turbo/supercharger setups go for around $1500, right? I see a turbo charger header sold on ebay for a cb750 for $237.50 on august 28th this year that wasn’t in bad shape.
I tend to hold on to more then I sell anymore because it is so hard to find these parts if you really want something anymore.  Good luck with your sale Don!
Online newday777
Online Don R
« Reply #1558 on: November 05, 2022, 04:26:57 PM »
 Well, anyway it's a video of my ARD mark II mag firing 4 spark plugs. It didn't need a battery contrary to some opinions. I threw a crank in an old block with three main bearings and some assembly oil, put the mag in it and spun it with a drill. There may be other models that need voltage but I wanted to show you don't hook this one to a battery unless you want to kill it.
https://www.facebook.com/don.rosenberry.5/posts/pfbid02EJiqN1KN56mEFbNS7qQ8dDuuaka7JwHTAMwYL1DfqoPV9zw1uTmB3Ae1YNdVhau8l?notif_id=1667680077556606&notif_t=feedback_reaction_generic&ref=notif
« Last Edit: November 05, 2022, 08:50:47 PM by Don R »
« Reply #1559 on: November 05, 2022, 04:58:33 PM »
Try linking the FB post Don, that was the only one that worked for me. Yep I'm pretty sure that the benefit of installing an ARD magneto is so you can delete your battery. (and alternator etc) ;D
Online Don R
« Reply #1560 on: February 24, 2023, 03:20:02 PM »
 Does anyone have a single Koni shock or an inexpensive set that needs a rebuild. Koni #K6-1302 I believe.  12.5" aluminum body.
« Last Edit: February 24, 2023, 04:28:54 PM by Don R »
« Reply #1561 on: February 25, 2023, 07:06:29 AM »
No, not those numbers... I have 2 sets of 76f-1296?  No idea if they are similar.
Offline Ricky_Racer
« Reply #1562 on: February 25, 2023, 10:54:16 AM »
Sean, the 76-1296 is the correct number for the CB750 application. The K6 series appear to be automotive applications.
RR
Online Don R
« Reply #1563 on: February 25, 2023, 11:30:50 AM »
 Crazy, I'll get a pic.
« Last Edit: February 27, 2023, 06:14:07 PM by Don R »
Online Don R
« Reply #1564 on: May 08, 2023, 08:53:46 PM »
 The melted sticky rubber indicated by the pen is a top out washer that is in some koni's but not all of them. The rebuild kits don't include that part because the shock doesn't need it. Go figure.
 I spent hours online finding this info.
« Last Edit: May 09, 2023, 05:12:17 PM by Don R »
Offline CBJoe
« Reply #1565 on: June 01, 2023, 08:20:00 AM »
UPDATE....SOLD......It pains me to do this, but I have a fresh unused JMR Billet Block and Piston Set (JE 71.25mm) which I had planned for a build, but life has had other plans.
2600 + Shipping.  PM me for questions.....not a lot of opportunity to get one of these as I dont believe Mike is planning any further production runs.  Block is bored and nikasil plated, comes with base gasket and all shown.
« Last Edit: June 20, 2023, 11:50:58 AM by CBJoe »
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline Dresda500
« Reply #1566 on: November 23, 2023, 11:29:05 AM »
Anybody have a CB500 crank that has good mains and could help get the rods ground and crank balanced? Like maybe just send to APE for me if they will help and I can handle from there. I’m in Norway and not able to find anyone to help here so cheaper to buy a used crank than ship one of mine. It’s for a road racer.
Instagram: hansrodncycle
Roadracing CB250K, Dresda CB500 and Martin KZ1000
Special intrest in hand made frames/bikes, porting/flowbench and Dyno tuning of vintage bikes
« Reply #1567 on: November 23, 2023, 05:53:27 PM »
What about Per in Sweden? I think he might know someone? ;D
Offline Dresda500
« Reply #1568 on: November 25, 2023, 10:15:05 AM »
Which Per?? So many over here…😂
« Reply #1569 on: November 25, 2023, 12:38:03 PM »
Ha ha, like “Dave” here mate. Per’s handle here is “PeWe”. ;D
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #1570 on: November 26, 2023, 10:23:10 AM »
Yeah, he might know someone that knows someone
« Reply #1571 on: November 29, 2023, 08:23:29 PM »
My nearby shop can lighten a crank but not balance it.
I have had thoughts about to get a CB750 crank lightened and balanced.
Theur machinist that has tuned engines since the 70's is now not working, not clear if coming back or will retire at 70+.
There are shops balancing car  cranks if searching Internet. No shops I know.
APE is another place doing this kind of work.
My CB750K6 has one. Engine idle nice with it.
Mike Rieck helped me o get one, found a used good one on eBay USA for a good price he sent to APE.......
Offline Dresda500
« Reply #1572 on: December 04, 2023, 01:58:26 PM »
Hey PeWe! I knoe Stig Axvall Motormakaniske north of Goteborg has a really nice big balancer but he has it for sale, so not sure what his plans are.....I did finally find a guy in Norway that can both custom grind and balance my crank...
« Reply #1573 on: December 04, 2023, 04:16:02 PM »
I've been to Goteborg....granted it was in 1979 BUT I've been there several times. ;) ;D
Offline Finnigan
« Reply #1574 on: December 27, 2023, 09:23:12 PM »
Looking for ported head for SOHC, '76 motor go fast project.
