Author Topic: fuel supply/delivery issue 73 750 SOLVED  (Read 928 times)
Offline Atlantic
« on: January 27, 2011, 10:02:43 AM »
Something is odd with my bike: It doesn't run well. I am pretty sure it has to do with the fuel getting to the carbs. When I drained the tank by removing the fuel hoses from the valve, I realized that the fuel ran mostly through one of the little funnels (the more rear one). I took the valve apart and cleaned it all out. I realized that it is probably normal that it runs out stronger through one funnel, because the other one is in line behind it. When the engine runs the pumping of the engine then takes care of that!?
Is this correct? Or should it be the same. If so, what's wrong with mine?
Alternatively it could be the fuel filter that is in the line after the valve. I already changed it, but might have gotten one that has too much resistance.
All ideas are welcome.
Thx as always!
« Last Edit: February 18, 2011, 06:50:46 AM by Atlantic »
bollingball
Re: fuel supply/delivery issue 73 750
« Reply #1 on: January 27, 2011, 10:52:49 AM »
Check that the lines run down hill no loops no kinks open gas cap to eliminate vent issues temporarily take out in line filter do you have a in tank or in petcock filter?
Offline Really?
« Reply #2 on: January 27, 2011, 11:38:02 AM »
The fuel is gravity fed to the carbs.  The engine pumping only affects your heart as you ride it.
Your issue might be further down the line (in the carbs themselves).  Do check the lines as Bollingball says.
Please provide any additional info you can.  How is it not running well?  Does it backfire?  When running, spray some water on each pipe to see how each one reacts or use one of those thermometer things to check.  If you tap the float bowls with something does it change?  What did you do about the time it started running bad?  Did you go to a different gas station this time?  Have you checked the plugs?  What color are they?
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline nhodges
« Reply #3 on: January 27, 2011, 12:52:04 PM »
What condition is the inside of the tank in?...the petcock screen could be gunked up.
Offline Atlantic
Re: fuel supply/delivery issue 73 750 SOLVED
« Reply #4 on: February 18, 2011, 06:51:56 AM »
okay okay - I figured it out: not enough fuel in the tank  :-[
Thx for all the quick advise though!
Offline Gaither
  • '77 CB550F
« Reply #5 on: February 18, 2011, 09:36:59 PM »
Atlantic
Don't feel badly. It ain't unique.
Years ago I knew a fellow who did everything he could think of to start a Chevie that quit on him. Finally, he completely rebuilt the engine. It still wouldn't run until he got around to putting gas into the tank. (True story and, it WASN'T me!)
Did you try the "reserve" position on the petcock?
Gaither ('77 CB550F)
