Author Topic: Anybody ever have this happen to their chain???  (Read 3864 times)
Offline Thunder
« on: February 01, 2011, 10:23:49 AM »
So i was prepping the bike for a possible role in a movie (will tell more about that if they choose her), when i was cleaning the chain and noticed this. It appears about half the link plates have tiny cracks in em!!!!! Scary.
This is a pic of the worst.(sorry bout the quality, cellphone.)
The chain came off an old bike i had , but i checked the links for free play. The chain was never too tight, if anything i kept it on the loose side and always well lubed. Its possible the chain had these cracks before and i didn't notice it but any ideas to what caused it?
Cheers
Thor
Offline GammaFlat
Re: Anybody ever have this happen to their chain???
« Reply #1 on: February 01, 2011, 10:29:26 AM »
Wow - that's terrible.  I've not seen that happen before.  The story could be a lot worse.
She's probably good for another 1000 miles - NOT.
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
Offline Bakeoff
« Reply #2 on: February 01, 2011, 11:55:07 AM »
Someone beats on their chain....   Good thing the movie deal came up, or you'd probably be stranded the next time you cracked open the throttle.
I haven't seen one crack like that since my BMX days.  That's why chains are part of doing maintenance.   ;)
Markcb750
« Reply #3 on: February 01, 2011, 01:18:45 PM »
I have never seen anything like that happen, you are lucky you where not riding when it failed the rest of the way, good way to bust an engine case!
Was it stiff from corrosion?
Offline tmac
« Reply #4 on: February 01, 2011, 01:29:46 PM »
OR YOUR LEG !
Offline MoMo
  • Ride like you're invisible
« Reply #5 on: February 01, 2011, 01:40:51 PM »
Worked in a cycle shop for at least 14 years, that is a first :o...Larry
« Reply #6 on: February 01, 2011, 03:21:23 PM »
Little dab of JB Weld your good to go----NOT---Time for a real chain and consider yourself lucky you still got your lower cases------. Thanks for pointing it out and we should all take a peek now and then,especially them young guys out there who want to hit the TON. ------
« Last Edit: February 01, 2011, 06:16:46 PM by ekpent »
Offline Steve_K
« Reply #7 on: February 01, 2011, 04:51:46 PM »
Take a good at your battery tube route and make sure it does not vent on the chain.  Battery acid will do that to tempered steel.
Glad that it did not let go when in use.
Steve
Steve_K
« Reply #8 on: February 01, 2011, 05:02:17 PM »
I have not seen anything like that but in looking at it I have a theory. I would think the wheel has or had been out of line for a long period of time and the links have been subjected to significant side forces. You say they the other links have developed cracks, if they are all on the same side, that would fit.
Offline nickandkristy02
« Reply #9 on: February 01, 2011, 05:04:11 PM »
great now i have to go check the chain on my rd350 :o
« Reply #10 on: February 01, 2011, 09:00:15 PM »
Damn Defence department computer firewall, I can't see the pics! I'll have to check 'em out when I get home, but I like Bobby and Steve_K's theories Thor. Cheers, Terry. ;D
Offline Thunder
« Reply #11 on: February 01, 2011, 09:10:12 PM »
Cheers Guys.
Battery vent isn't routed down that away but that's good to know for future.
The Idea of the wheel being skew fits (no pun intended) , but that I'll have to put down to a PO.
Thing is, about 20 of the plated are cracked, some in more than one place. I will check today if its all on one side when i go to a chain place (in the car)and see what they gotta say.
Could incorrect sprocket  "profile"? have done this, like the teeth were too big?
Not saying it was this as the chain fitted well into the sprockets, but to my mind if the "teeth" were too large the tension whilst riding would've exerted lateral forces on the chain plates?
I dunno. Tx for the ideas
Thor
« Reply #12 on: February 01, 2011, 09:17:26 PM »
Thts exacty what happen when the early 750's broke chains and cases, Honda put it down to incorrect battery vent routing and fitted all those nice stickers to tell you where to route it
Offline Thunder
« Reply #13 on: February 01, 2011, 11:54:28 PM »
Ok, update, back from the chain shop.
They were suprised but said it could be from having put the sprockets on the wrong direction. IF the sprockets are worn and bend slightly in one direction, it puts undue stess on the chain when installed.
The sprockets were not new, but to my eye they didn't have much in the way of a bend or slant.
But what they said makes sense?
Thor
Offline crazypj
  • I'm brill, me
« Reply #14 on: February 02, 2011, 12:02:52 AM »
Thor
nope, they are full of it.
 Don't have a correct answer so make up something plausible  ::)
bryanj got it,
I've never actually seen it before but it's battery breather hose routing.
 Yamaha had a major recall because chains broke.
They fitted longer breather hose and re-routed it.
 I did hundreds of Yams but never saw chain like that, usually just the rollers broke off (probably rained too much in South Wales  ;D)
Offline Thunder
« Reply #15 on: February 02, 2011, 12:05:53 AM »
Well, i bow to the collective knowledge on here. i will double check the routing of the Battery vent, but as it came of another bike i have it's possible the damage was done when i put it on.
Thanks for the help and i have learned some stuff today.
cheers
Thor
« Reply #16 on: February 02, 2011, 01:33:42 AM »
had the chain ever been rusty and dry?is it an old cheapie chain?ten more seconds and it looks like it would have snapped.
Offline HondaNorway
« Reply #17 on: February 02, 2011, 03:53:18 AM »
Damn! That's the worst chain i've seen! Lucky you noticed it now, could go terribly wrong..
'74 CB750
'76 CB750F
Offline Deltarider
« Reply #18 on: February 02, 2011, 04:21:30 AM »
Some years ago, when I was bringing my bike on the centerstand, all of a sudden the bike gave way and went on his side like a dying elephant. I could only prevent the bike from hitting the concrete too hard. I was shocked to discover the centerstand was broken due to what seemed to me as metal fatigue. Anyway I had it welded by a friend and the stand is still on. But now that I read the above, I wonder whether as a result of an incorrect routing of the battery vent tube, the metal of the stand had softened. Any ideas?
Maybe the stand is made of bad quality metal. It's certainly not Rearden metal, that's for sure.
« Last Edit: February 02, 2011, 04:25:19 AM by Deltarider »
CB500K2-ED Excel black
Markcb750
« Reply #19 on: February 02, 2011, 04:39:29 AM »
Excellent catch!
*Another reason why I like AGM batteries.
« Reply #20 on: February 02, 2011, 05:49:34 AM »
Been an off and on topic here for years. here's one of the more recent threads:
http://forums.sohc4.net/index.php?topic=72783.msg808964#msg808964
Offline Kong
« Reply #21 on: February 02, 2011, 06:31:28 AM »
If you all don't mind I'd like to revisit something said in the original post.  You all may have missed this but here is part of what was said:  "The chain came off an old bike i had"
It sort of makes arguments about the sprockets and battery vent lines moot when we don't even know what kind of bike it came off of but might just as likely be the source of the problem as the bike its on now - probably more likely the source if the chain was on the other bike longer.  I do not know why I think this, I have no idea where I heard it and I don't know that I've ever actually seen it in print, but it has always been my understanding that you should never reuse a chain or switch one from one bike to another.  In fact I thought it was the general recommendation that a new chain be used whenever new sprockets were put on a bike; that chains were nearly as expendible a part as brake pads.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline Steve_K
« Reply #22 on: February 02, 2011, 07:13:23 AM »
Changing chains and sprockets at the same time is a good idea.  That said, on old bikes that I got with the chain rusty and done for,  I have just replaced the chain.  Note: the sprockets had little wear and chains on old CB 750s and 550 don't cost that much.  Newer bikes with high hp need both changed.
Still, I think its likely acid did in the chain.  Best of all is that it found before it broke.
Steve
Steve_K
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #23 on: February 02, 2011, 07:17:27 AM »
Looks like the chain is smaller than the sprockets, i.e. a 520 chain on 530 sprockets. The chain came from "another bike" per original post.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #24 on: February 02, 2011, 07:32:12 AM »
Could be. The "pitch" (distance between pins) is determined by the "5", all 5 series chains have the same pitch. A 4 or 6 series chain would be so far off it wouldn't work a bit.
The 20 or 30 is the width. I don't know if a 20 would even fit on a 30 sprocket. Maybe a 525 could be a tight fit on a 530 sprocket. Don't know.
Offline JMC208K3
  • A work of art is a corner of creation seen through a temperament.
  • Rookie noob
« Reply #25 on: February 02, 2011, 07:43:47 AM »
That is crazy, you should feel lucky.  Just replace it with a new chain AND get new sprockets.  Even if they look ok, piece of mind is priceless.  I wouldn't skimp on quality either.
1973 CB750 K3
« Reply #26 on: February 03, 2011, 05:19:40 AM »
I hate to tell you this Thor, but after seeing the picture I've decided that your chain has fallen victim to Global Climate Change, caused by man's insatiable lust for carbon producing oil. Sorry mate, but you ignored the warnings and now you're paying the price................  :P  ;D
Offline crazypj
  • I'm brill, me
« Reply #27 on: February 03, 2011, 09:01:12 AM »
 Chains are 'coded' in 1/8" increments.
520 chain is 5/8" x (2/8") or 1/4"
525 = 5/8 x (2.5 x 1/8") or, 5/16"
530 = 5/8" x 3/8"
420 = 4/8" x 2/8" (1/2" x 1/4")
etc.
 Only 'odd' size is 428 which is slightly stronger/wider than a 425 and compares to the primary chain fitted to many (most?) vintage~1950's British bikes
