Hey Frank, yeah, no speedo already, made a new aluminum spacer a few weeks ago to replace the steel spacer I had used before.
In hindsight, I could have taken more off the ears, but it was a major PITA as it was, with the 7 bolt Kawi pattern. I think I could lose more weight by drilling the steel disc, but since it is already drilled with a "funky" pattern, I have yet to figure out how to lay it out...
The plan now is to get the rear wheel back together, then shift my attention back to the front wheel and brakes. I can take more weight off the Yami slotted discs more easily than the funky Kawi. Already have a roughed out aluminum bearing spacer for the front, but I won't know the weight savings until I compare it to the already lightened steel spacer.
Guessing I'm already below 400 lbs, but I won't know until I put it all together!
Time has become a bit of an issue, too, as come hell or high water, I plan to ride the RELAY!!!
