Author Topic: breaking a stock mirror apart  (Read 1269 times)
nomad
« on: February 10, 2011, 01:18:45 PM »
Anyone ever taken a stock mirror apart?  The chrome finish on this one is just ok at best and I was wanting to get it chromed properly.  I don't see anyway to take the swivel (mirror) part off of the stem.  If you're willing to break the mirror in it to get to it's "guts" would you find a nut/ screw in there that would let you break it down all the way?  Anyone got an old mirror that's ready for the trash (or have already done this) that they'd be willing to do this to?  Better yet, anyone got one that's already broken that they can look at?  THANKS!
Offline Damfino
Re: breaking a stock mirror apart
« Reply #1 on: February 10, 2011, 01:34:39 PM »
Why? I would think you could find a genuine Honda replacement for less than the cost of re-chroming and repairing that one. ??? ???
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
nomad
« Reply #2 on: February 10, 2011, 01:43:11 PM »
This is a brand new Honda replacement, but the chrome finish from the factory is meh...  Definitely could look better imo.
bollingball
« Reply #3 on: February 10, 2011, 05:46:44 PM »
Is it chrome ? Or stainless? Have you tried to buff it?
nomad
« Reply #4 on: February 10, 2011, 05:58:06 PM »
Chrome.  Yeah, I'll try buffing it before doing anything too drastic just to see what will happen.
Offline HondanutRider
« Reply #5 on: February 11, 2011, 05:05:08 AM »
Not sure about the construct of your particular mirror, but I have removed the glass/mirror in several in the past, by carefully prying the rubber sealing ring that holds it in the frame.  You have to get under the glass with a small knife blade, or something similar, and work the glass out from the rubber which retains it.  I have broken glass in the past, trying to do this with seals that were not really rubbery, but rather a hard plastic, which maybe would soften with a heat gun - but also would maybe melt. :(
At any rate, once the glass is out, most mirrors I've seen have a nut holding the frame onto the ball of the stem, along with a spring arrangement that allows it to pivot.  These can be disassembled.
Offline LBM 550F
« Reply #6 on: February 11, 2011, 01:09:53 PM »
Hi.
I had dissembled both stock mirrors on my 550F to tighten up the tension nut, Don't try to pull the rubber ring out instead push it into the mirror with a piece of stiff plastic or wood. Work around the glass with dish soap helps. It works! and on reassembly use wd-40 put the rubber ring on the glass and carefully (with gloves on!!) push the whole matter together.
                        L.
nomad
« Reply #7 on: February 11, 2011, 01:26:56 PM »
New mirror from Honda... no rubber rings (at least that are visible).  It appears that the metal housing is simply crimped around the glass.  Did the original mirrors from the early K's look like these?
nomad
« Reply #8 on: February 11, 2011, 01:27:06 PM »
Can anyone point me towards any other after market mirrors that look similar to these that can be disassembled if need be?  I'd like to keep the "stock" feel if possible.
« Reply #9 on: February 12, 2011, 05:24:36 AM »
Hi.
                        L.
That sounds like a much better technique than I described for dis-assembly.  Pushing the rubber in all the way around, rather than trying to pop the glass out, would be more likely to prevent breakage.
