I got the "new" Cb550 up and running, but I hit a small snag. I turn the key on and nothing happens. I checked the fuses and confirmed I was getting power to the switch. If I turn the switch on and push on the wiring harness connection, the bike comes to life and works fine from then on, until I go to turn it on again later. I suspect the igniton switch (it has that funky combination fork lock/ignition unit on the handlebars) and tonight my suspicions were confirmed when I wiggled the harness to turn the bike on so I could aim the headlight, I saw blue flashes through the plastic switch contact housing.
So, my question is can the switch be taken apart and cleaned/repaired somehow, or is it toast? To I need to buy a whole new switch? I've seen aftermarket contact assemblies, but the one place I know that carries them is out of them. On the parts drawings I don't see it listed as a separate part, but is the contact assembly alone available from Honda?
Thanks!
Oh, BTW.. when I go to sync the carbs, do I have to take the tops off the carbs to get at the adjustment screws? A manual I got with the bike (not Honda, of course....
) only shows adjusters on the outside of the carbs, but I don't see any...
