Author Topic: help removing front axle from xl500!!!!!  (Read 1904 times)
Offline stay youth
« on: February 09, 2011, 09:25:26 PM »
hi all need some help. I can remove the front axle on my xl500s anyone here got any tips to remove these?
thanks
1976 cb400f
Offline ron.cieri.313
Re: help removing front axle from xl500!!!!!
« Reply #1 on: February 10, 2011, 06:41:55 AM »
I have an XL250 '79...I think these bikes get driven in wet conditions alot and then corrosions like to keep bits together more than they should...what have you tried so far?...have you sprayed with seafoam or some other lubricant/rust dissolver?
Making the world a better place, one motorcycle at a time.
Offline joesmotos
« Reply #2 on: February 10, 2011, 07:47:04 AM »
Doesnt the axle screw into one side of the fork leg on that bike?
MIght want to get a heat gun or propane torch and some penetrating fluid and warm it up to expand the aluminum then try getting it out..
just my 2 cents worth..
« Reply #3 on: February 10, 2011, 07:48:23 AM »
sounds like a good idea to me too
Offline catzor
« Reply #4 on: February 10, 2011, 09:24:47 AM »
Generally, if you have a torch, some penetrating lube, a 10mm wrench, an impact driver, and a big ass rubber mallet, you can get anything apart on these old bikes. If none of the above works, try to make friends with a guy with a bigger hammer.  :D
1991 CB250 Nighthawk
1986 VT500C
1989 EX500
1973 CB175 Super Sport
Offline stay youth
« Reply #5 on: February 10, 2011, 11:06:45 AM »
thanks ! I feel like it might screw in, since there is a hex head on the opposite side. I soaked in in wd40. Might have to locate a torch!
1976 cb400f
Offline MoMo
  • Ride like you're invisible
« Reply #6 on: February 10, 2011, 11:12:18 AM »
If there is a hex nut it should screw in or out, my recollection of those models is that the axle is like a long bolt...Larry
« Reply #7 on: February 10, 2011, 11:13:16 AM »
You can get torches at home depot for like $30 that run on a little propane tank...relatively easy to use for those of us with little experience lighting things on fire :P
