Author Topic: oil seals in crankcase how too  (Read 790 times)
Offline gerryw
« on: February 11, 2011, 09:29:49 AM »
i have split the cases on my cb400f for camchain (big suprise) i obviously always oil the seals for start up but do i use sealant on the seals in the cases, or install dry (no sealant)
How about the base gasket?
Thanks
gerry(back to a cb400f after 30yrs!!!!)
« Last Edit: February 11, 2011, 09:31:50 AM by gerryw »
Re: oil seals in crankcase how too
« Reply #1 on: February 12, 2011, 04:38:31 AM »
Welcome back to the 400F....about time!
I only ever spread the sealant to the seal edge but not the seals. With mating surfaces well cleaned no sealant on the base gasket either.
You changed the cam chain, what about the horseshoe shaped tensioner in the base? Often there are chain wear marks on it that cause problems in movement.
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: February 12, 2011, 04:44:57 AM »
Never used any sealant on the outer surface but would use Belray assembly  lube of all metal surfaces...Larry
