Author Topic: brake calipers for a 750??  (Read 906 times)
Offline kopptl
« on: February 10, 2011, 02:53:38 PM »
i know a stock caliper is generally the answer. but has anybody ever ungraded to a more modern caliper??  if so, what kind of bike, and what kind of caliper.
-cheers, tom.
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
Re: brake calipers for a 750??
« Reply #1 on: February 10, 2011, 03:29:03 PM »
You would need to make a caliper hanger to fit anything else. So it gets to be a bigger job than
it is on many other bikes.
In the UK anything over 40 years old only needs insurance and Fuel.
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #2 on: February 10, 2011, 03:35:13 PM »
even if you used a more modern caliper, you'd need to upgrade the rotor too.  these old rotors work decent at best, and the newer ones are lighter, floating and can shed heat a lot faster than the old ones.  also, the new ones are tougher and can withstand heat cycles better, meaning less fading...
Offline jaguar
« Reply #3 on: February 11, 2011, 08:32:11 AM »
what bike are you talking about?
are you looking for something that "bolts" on are something to fab?
most vintage rotors are much thicker then a modern rotor so a modern rotor needs a modern caliper.
also you would need to keep the brake ratio in a range so i would assume that you would need a new master
are you already running a twin disc front?
what makes you think you need more brakes?
are you running new pads, lines and rebuilt master?
Offline kopptl
« Reply #4 on: February 14, 2011, 04:00:12 PM »
i have access to a big machine shop in my college machine class.  currently i have no front brakes, my calipers totally seized solid. i plan on getting a master cylinder off of a newer sportbike, and now im thinking a rotor as well. imy goal is to have a newer and better brake set up on the front.
Offline kopptl
« Reply #5 on: February 14, 2011, 04:00:37 PM »
the bike a 76 cb750k model.
Offline jaguar
« Reply #6 on: February 14, 2011, 04:48:05 PM »
plan to do that on the stock forks?
nothing is "bolt on" and anything can be made to fit so its up to you
Offline kopptl
« Reply #7 on: February 14, 2011, 07:02:47 PM »
yes stock forks. if i could find a cbr front end, or a newer sportbike front, i would already have one. but stock is all i have at the momen.t
