SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Is there a secret to this petcock gasket?!?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Is there a secret to this petcock gasket?!? (Read 744 times)
Tugboat
Puppet
Master
'75 CB750K + '67 CL90 + '71 CT90
on:
February 13, 2011, 04:48:59 PM »
The petcock on my '77 KZ400 is supposedly the same as early CB750K's... everything except the screen. I bought a rebuild kit from a member here, and the o-ring that goes between the petcock and the tank fits perfectly. The little 4-holed gasket that goes behind the lever seems to fit too, but when I had it all back together and put some gas in the tank it leaked. Total PIA! I've taken it apart and put it back together five or six times now, and it still leaks. Is there a secret to getting that piece to seal correctly? Just thought I'd ask before I go and spend $20 on an OEM gasket on ebay. Ugh.
Logged
TwoTired
Really Old Timer ...
Re: Is there a secret to this petcock gasket?!?
Reply #1 on:
February 13, 2011, 04:53:06 PM »
You sure you have all the parts for it. There is a flat spring washer needed for some of them.
Post a pic of the parts you have. Especially if you are making a Frankenstein.
Logged
curtis
Full Member
Reply #2 on:
February 13, 2011, 06:45:11 PM »
I have changed several of those never on a kz but hondas and yamahas. make sure the flat spring washer is in and I do think there is a front and back to the valve or(rubber washer) as u call it. Not being a jerk I got chewed out at a parts counter for the same thing. There should be a lip or ledge on the outside and around the four holes on one side that goes out. GOOD LUCK. You should try changing them on the side of the road with a full tank.
Logged
seanbarney41
not really that much younger than an
Reply #3 on:
February 13, 2011, 07:08:17 PM »
also, if you have done all of the above, and it still leaks, try coating all rubber parts with wd40 or even some grease, then things will tighten up without the metal sticking to the rubber and galling...
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
