Author Topic: Source for Ti nuts for rocker arm adjusters.  (Read 16066 times)
« on: February 14, 2011, 06:55:03 AM »
I believe thread is 6mm X .75. Anybody know a specific source?
Re: Source for Ti nuts for rocker arm adjusters.
« Reply #1 on: February 14, 2011, 07:40:16 AM »
It's probably easier than all this, but I sent a request in to a place I had retainers made to see if they could supply. I'll let you know.
« Reply #2 on: February 14, 2011, 08:09:50 AM »
Thanks Brent. I'll take a 3 sets. Maybe some others are interested too.
  • Moderator
« Reply #3 on: February 14, 2011, 08:48:51 AM »
Did you not think to just google it?
Sam. ;)
« Reply #4 on: February 14, 2011, 09:15:44 AM »
Sam. ;)
Of course I did Sam. The pitch is the problem.
Offline voxonda
« Reply #5 on: February 14, 2011, 09:32:12 AM »
Hey Mike,
Pure coincidence, but I'm working on it. Will get back on this subject.
Rob
« Reply #6 on: February 14, 2011, 09:41:28 AM »
 If we can get Ti hex stock in right size they will be easy.. I doubt that the tap would be a problem..
Offline lordmoonpie
    • Moonpie
« Reply #7 on: February 14, 2011, 11:26:15 AM »
Mike,
Pete Lidster in the UK will make some for you - pete@ti64.co.uk
His titanium stuff is more a work of art, shame to use it on the bike. He does all sorts too - spindles, bolts, whatever. I'm sure he'd send to the US...
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline voxonda
« Reply #8 on: February 14, 2011, 11:44:15 AM »
Found it. Grade 5 Ti M6x.75 m/m nuts. 6-8 weeks delivery.
Rob
« Reply #9 on: February 14, 2011, 01:24:57 PM »
Rob
Er ... how much?
« Reply #10 on: February 14, 2011, 01:38:44 PM »
Sorry Mike nothing at Trick Titanium. He suggested a place in Ohio that I called and that didn't pan out either. Tha last fellow suggested Earls but I fiqured you would know if they offered such hardware.
Looks like you have options now anyway even if it takes a little longer.
Offline voxonda
« Reply #11 on: February 14, 2011, 01:50:20 PM »
Rob
Er ... how much?
hi Ron,
Never like to talk prices, rather thru pm or mail. But around USD 2.20/piece
Rob
« Reply #12 on: February 14, 2011, 01:52:41 PM »
Understood, check you PMs.   :D
« Reply #13 on: February 14, 2011, 02:46:20 PM »
Thanks guys...what a crew! ;) ;D Rob...PM me when you work it out. ;)
Offline jaguar
« Reply #14 on: February 14, 2011, 04:55:14 PM »
so are people ordering them?
Offline kos
    • m3racing.com
« Reply #15 on: February 14, 2011, 05:01:09 PM »
Those with my lightened rocker arms, and you will have the world by the tail!
I have steel nuts sourced from a Yamaha street bike that are half the height, so they turn out to be very light, but they are 2.50 USD each. So if you can purchase Ti for the same...go for it.
Watch out or ...sudden acceleration!
Kos
220...221, whatever it takes.
Offline jaguar
« Reply #16 on: February 16, 2011, 07:18:47 PM »
anyone have a link to order a set?
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #17 on: February 16, 2011, 07:25:11 PM »
man 6-8 weeks huh?  well it was suggested to me to get new rocker arm adjusters and nuts while having the top end torn down, and they're about $1.50 for the nuts online at the cheapest!  sign me up for a set!  less than $20 for a set, not a bad deal!!
now is anyone making the adjusting stud out of a lighter material?  shave some weight off there too!   ;D
Offline lordmoonpie
    • Moonpie
« Reply #18 on: February 16, 2011, 11:54:55 PM »
Would there be any issues in making the adjusting stud out of Ti? What sort of forces are exerted upon it?
1994 Ducati 888 SP5
  • Moderator
« Reply #19 on: February 17, 2011, 12:00:57 AM »
more than you would like hammering on your nuts. ;D ;D ;D ;D
Sam. ;)
Offline mec
« Reply #20 on: February 17, 2011, 12:41:58 AM »
there is friction between the stud and the valve stem. cause of the bad friction properties of Ti, i wouldnt do that.
but i would make the nuts out of Al 7075, and you can save another milligrams.
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline voxonda
« Reply #21 on: February 17, 2011, 03:42:35 AM »
Have thought about Al(cheaper) but wondered if there would be a prob caused by the expansion coefficient. (Alu= 23.2, steel= 12.0 and Ti=10.8)
Offline kos
    • m3racing.com
« Reply #22 on: February 17, 2011, 03:35:19 PM »
I would not use aluminum for nuts, but I have used Ti with no problems. My steel ones that are half thickness of Honda OEM are almost as light as OEM, work perfect and they are just about as the Ti that are full thickness as I read this  thread?
Mark@ M3
Offline voxonda
« Reply #23 on: February 17, 2011, 10:38:32 PM »
Yes Mark, nuts are DIN934 so are 5 m/m thick.
Offline Leino
  • Not much of an
  • in drag racing since 2005
« Reply #24 on: February 20, 2011, 03:49:34 AM »
I need a set of lighter nuts too, the ones I have are quite heavy and hanging low  ::)
