Author Topic: 1975 CB550k1 Chain and Sprocket  (Read 5955 times)
Offline campbmic
  • Sea-Foam and Flaming 151 is a dam good
« on: February 14, 2011, 10:13:14 PM »
Hi guys! Im in the market for a new chain and sprocket and have done some research. From what I can tell I need a 530 17/37 sprocket with a non o-ring chain.
Through searching the forum I found this seller who apparently sells this kit ($95)
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=400169465492#ht_836wt_877
With a standard 530 100 link chain for like $69.
Anyways, will this kit work for me if I get a 530 100 link non o-ring chain?
Is this the stock chain and sprocket setup?
What about 520 chains, x-rings, and o-rings?
If this guy ends up not working out does anyone have links to buy the chain and sprocket kit I need?/
Thanks
« Last Edit: February 14, 2011, 10:16:44 PM by campbmic »
Its hard to be wrong when you know nothing!
Offline Lars
Re: 1975 CB550k1 Chain and Sprocket
« Reply #1 on: February 15, 2011, 02:11:29 AM »
You may very well get it from here as well:
http://www.davidsilverspares.co.uk/CB550K-1976-USA/
O-ring chain works fine.
...if you got the ability to act...
Offline c(b)hris
« Reply #2 on: February 15, 2011, 05:48:13 AM »
Hey I might be wrong but are you sure about that O-ring chain?  I always thought you had to use a non-O-ring chain because of clearance issues on this bike.
http://forums.sohc4.net/index.php?topic=1526.0
75 CB550
74 CB750
Offline campbmic
« Reply #3 on: February 15, 2011, 06:20:56 AM »
Ive also heard o-ring chains are no bueno.
I personally dont like DSS because it takes such a long time for me to get my order
Offline Kong
« Reply #4 on: February 15, 2011, 06:21:26 AM »
All I can tell you with dead certainty is that an O-Ring chain will cut into the cases of a 550's engine right across a rubber seal and the result will be an oil leak if it is allowed to continue.  You can do a search to find pictures of what this damage looks like, I posted some pictures in association with getting advice on removing a stuck front sprocket that shows it - you should be able to find it with a search.  The point is to use a Non-O-Ring chain, they are narrower and will not cut into the cases.
On edit.  Look at the left side of this photo, see that black rubber plug, the one with the crescent-shaped cut in it that matches the cut in both the upper and lower case half's?  That was caused by an O-ring chain.  It seeps oil:
« Last Edit: February 15, 2011, 06:26:52 AM by Kong »
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline Lars
« Reply #5 on: February 15, 2011, 06:46:31 AM »
Point taken, I will check my own bike. Only had the chain on for a short while.
Offline underachiever
  • Squandering my potential since 1989
  • 77 CB550K
« Reply #6 on: February 15, 2011, 06:49:38 AM »
Yep. 17/37 100 link NON o-ring is what you want.
As for sourcing such. Ummm.....how about a motorcycle shop?
Otherwise there are lots of mail order places in the US which ship cheap or free to the lower 48, (unlike to canada where we get royally hosed!)
Try Z1 or TAS or bikebandit or crc2 or western hills or..................check the FAQ for somewhere near you
tony
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: February 15, 2011, 06:52:31 AM »
I'd also avoid getting any kit, unless it has exactly the type/brand of chain and sprockets that you're looking for and costs the same as or less than it would cost to buy them all separately.
Check out Z1 Enterprises for sprockets, and look here for chain:
http://montecdirect.com/Merchant2/merchant.mvc?Screen=SFNT&Store_Code=MD
Good standard chain for $15-$20 for 100 links.
Also, if you'd like to help wake up your 550 on the low-end of the tach, switch to a 16 tooth front sprocket.  It was by far the easiest and best improvement I made to mine.  Noticeably increased torque off the line without increasing the rmp too much on the top end.
Offline chadbenson
« Reply #8 on: February 15, 2011, 07:02:26 AM »
Look your bike up on bike bandit! They actually have decent prices sometimes. You should be able to get both sprockets and a decent roller chain for $100 bucks including shipping.
http://www.bikebandit.com/1975-honda-cb550-sprockets/c/a697344a690344?mg=957&t=1
http://www.bikebandit.com/1975-honda-cb550-sprockets/c/a697344a690426?mg=957&t=1
http://www.bikebandit.com/chains/c/a697193a697167a697127
Offline Kong
« Reply #9 on: February 15, 2011, 07:28:29 AM »
I agree entirely, if you are putting on new sprockets and chain you should go to a 16 tooth front.  You may notice that the sprocket in the photo above is a shinny new 16-tooth version, count 'em.
1978 Honda CB550K
1977 Honda CB550K
Offline Gordon
  • 750K1, 550K2
« Reply #10 on: February 15, 2011, 08:05:27 AM »
Still too much, IMO.  If you get the parts separately from Montec and Z1 it should be about $75-$80 total.
Offline Blacknine
« Reply #11 on: February 15, 2011, 08:15:16 AM »
Oh boy, I just had my mechanic put a 530 O-ring on mine too. This sucks.
Offline c(b)hris
« Reply #12 on: February 15, 2011, 08:30:58 AM »
[soapbox] I've also been burned a couple of times by dealers giving me the wrong parts/putting my bike back together wrong.  Sucks when you don't know what you're doing and they're the ones you have to rely on, but I guess it's good that it makes you rely more on yourself.  I always do some serious googling before I do anything new to my bike anymore.  Kind of ironic, that I couldn't put my 36 year old motorcycle back together without the internet.  [/soapbox]
thankGODforthissite.
75 CB550
74 CB750
Offline Blacknine
« Reply #13 on: February 15, 2011, 08:42:55 AM »
Can anyone link the correct standard chain the bike needs?
Offline Gordon
  • 750K1, 550K2
« Reply #14 on: February 15, 2011, 09:00:02 AM »
530 size, 100 link standard roller chain.  Available anywhere that sells motorcycle chain.  If you look at the link to Montec I posted above you'll find one.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #15 on: February 15, 2011, 10:27:31 AM »
I paid $27 for my chain delivered to my house. Basic 530 100 link roller didn't even have to cut it. I'm still looking for a 16 tooth front sprocket. None of the above mentioned websites has one. Z1 has a 16T for a cb650 if that fits I would like to know.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #16 on: February 15, 2011, 11:15:19 AM »
If you do much freeway driving, you do NOT want a 16 tooth front sprocket on the 550.  I certainly didn't like it.  But, it did help with the stop light grand prix in the city.  ;D
The 16T only helps in first gear, IMO.  Otherwise, if you need better pick up, drop a gear to get it.
Offline campbmic
« Reply #17 on: February 15, 2011, 01:01:39 PM »
Does anyone know if I can use x-ring chains?
Also, with these chains
http://www.crc2onlinecatalog.com/Index_Main_Frame.htm
Do I need to buy the master link also or should it come with it?
Thanks
« Last Edit: February 15, 2011, 01:04:04 PM by campbmic »
« Reply #18 on: February 15, 2011, 01:27:12 PM »
In 530?  No.  Not without an offset front sprocket (on the 550).
X ring chains are just as wide as oring types.  They just have a different pin seal shape.
Offline apex_seeking
  • Ron Swanson is a
« Reply #19 on: February 15, 2011, 01:27:42 PM »
I know it has been said but I don't think it can be said enough.
Don' put o-ring chains on 550s!
This is my bike, not someone who knew a cousin that was a brother of...no , my bike. It will seep oil. Your beautiful bike will no longer be able to hold her liquids and leave you with some embarrassing explaining to do.
Offline c(b)hris
« Reply #20 on: February 15, 2011, 01:34:56 PM »
75 CB550
74 CB750
  • Ron Swanson is a
« Reply #21 on: February 15, 2011, 01:46:51 PM »
My point exactly ;)
Offline singedebile
« Reply #22 on: February 15, 2011, 02:58:26 PM »
I really like that link to montecdirect but i am still as clueless as to which brand/type 530 to buy from that huge list there..  also is 100link the right size for the stock gearing? or will it need to be shortened?
1975 cb550f super sport, 1976 Yamaha IT400, 1974 Suzuki T500
  • Ron Swanson is a
« Reply #23 on: February 15, 2011, 04:50:06 PM »
http://www.bikebandit.com/rk-m530h-heavy-duty-chain
I just bought this one. 530 100 link
Offline cameron
« Reply #24 on: February 15, 2011, 08:22:18 PM »
I just got this recently, for the same job. Free shipping over $100. It got here just fine!
Thank you for recently shopping at MOTORCYCLE ONLINE STORE.  Your order placed at http://www.shopmotorcycleonlinestore.com on 1/27/2011 has been updated.
Order Status: Shipped
Shipping Agency: UPS
Order Subtotal: $108.97
Order Tax: $0.00
Order Shipping Charges: $0.00
Order Total: $108.97
Payment Method: PayPal
Order:
Qty.    Part Number  Price Per Item  Special Order      Product Name
1       PJ1-20            $10.76           No                      BLACK LABEL CHAIN LUBE
1       56-0401          $6.75             No                      OIL FILTERS
1       249502           $26.99           No                      REAR SPROCKETS FOR HONDA
1       120855           $2.15             No                      530 STANDARD CHAIN
1       120800           $40.76           No                      530 STANDARD CHAIN
1       JTF288-17       $21.56           No                      JT SPROCKETS FRONT SPROCKETS
1976 CB550F
