Author Topic: Dead '74 CB550  (Read 1802 times)
Offline Blacknine
Dead '74 CB550
« on: February 15, 2011, 07:11:11 PM »
Help! My CB has been running great all day, put it in the garage and went to start it just now and all the electrics are dead. All 3 fuses are good, ignition switch appears to be in good shape and battery is fully charged. If i put a flathead on the main relay (starter solenoid) the bike will turn over but nothing lights up. I also tried jumping the switch but nothing happened. Any idea where I should go from here?
Re: Dead '74 CB550
« Reply #1 on: February 15, 2011, 07:22:44 PM »
Ignition switch Hmmmmmm--Wiggle the key and start there tracing wires maybe.How old is the battery and is your charging system good?
« Last Edit: February 15, 2011, 07:28:36 PM by ekpent »
Offline MoMo
  • Ride like you're invisible
Re: Dead '74 CB550
« Reply #2 on: February 15, 2011, 07:27:28 PM »
Check the battery cables to make sure the terminals are clean, also, the negative ground at the frame. Make sure the connection plug is tight at the ignition switch...Larry
Re: Dead '74 CB550
« Reply #3 on: February 15, 2011, 07:29:38 PM »
I updated but +1 on Larry----------
Offline Spanner 1
Re: Dead '74 CB550
« Reply #4 on: February 15, 2011, 07:39:29 PM »
Shorting-out the solenoid sends power to the starter only... so normal.
How sure are you that the 15A main fuse and it's fuse holder are good..... ?
Offline Blacknine
Re: Dead '74 CB550
« Reply #5 on: February 16, 2011, 03:51:18 AM »
Unless the fuse holder is bad, I took out each fuse, checked them, and then jumped it with a piece of wire instead of the fuse and still nothing. I don't even know where else to look on the bike at this point
Offline GoatBaSS
  • Could someone find an
  • To weird to live, to rare to die.
Re: Dead '74 CB550
« Reply #6 on: February 16, 2011, 05:09:27 AM »
Check the fuse housing. I have seen many needing to be replaced over the years. Look for melting...
Leethal # 3046?
1972 CB750K/900CC Red Headed Dunstall, 1975CB750FSS Gone BNF: 1974CB500T, 1976CB750K X 2
Offline Blacknine
Re: Dead '74 CB550
« Reply #7 on: February 16, 2011, 08:21:27 AM »
Fuse housing looks ok. No melting or anything, one of the wires in the connector had been pushed out slightly, so I jumped it to the wire on the side of the connector and still nothing.
Re: Dead '74 CB550
« Reply #8 on: February 16, 2011, 08:25:42 AM »
You are going to have to be methodical with either a test light or multimeter and start at the battery checking for voltage then work along the system junction by junction, going here, there and everywhere is a road to frustration and insanity
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
Re: Dead '74 CB550
« Reply #9 on: February 16, 2011, 08:48:20 AM »
I  was about to reply when I saw bryanj's reply, so +1 on what he said.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline Gaither
  • '77 CB550F
Re: Dead '74 CB550
« Reply #10 on: February 16, 2011, 09:49:32 PM »
FWIW
Just looking  at fuses can fool you. When I was getting 3 miles to a 15 amp main, the bad fuses all looked OK. They were burned in the metal ends and didn't appear to be bad. This was caused by corroded fuse clips. An overload (short) will burn 'em in the middle were you can see the damage.
I twisted the end caps off and they were melted in the metal caps. Also, you can check 'em with an ohm meter.
Just a thought -
Gaither ('77 CB550F)
Offline Spanner 1
Re: Dead '74 CB550
« Reply #11 on: February 17, 2011, 04:49:07 AM »
Go Gaither....  ;D :)... Gaither +1.
