Author Topic: Let's go roadracing...continuing saga  (Read 226524 times)
Re: Let's go roadracing...continuing saga
« Reply #1325 on: June 26, 2018, 07:24:55 PM »
Well TG, I was singing the blues but that won't fix the bike again. I ran some regular pump gas through it tonight to burn off the race gas. It fired right up poor thing.  8)
I had my fingers crossed the Krober tach would work again, and it does but reads aprox 2K rpm too high. I'm pretty sure these can be calibrated and will contact the company in Belgium.
I love this tach, it is a tough s.o.b.
« Reply #1326 on: June 27, 2018, 12:10:39 AM »
Brent sorry to see your bike is beaten up again...imagine that is some footage he does not want his mom to see, but knowing how bikes will flip and flop at high speed with no guidance it probably does not surprise her with it beaten up so bad.  Racing certainly is not an inexpensive endeavour.
Personally I am gonna be mean spirited and hope the guy responsible for so much carnage cannot afford to rebuild his bike.
 All that Ti did not save him any money and could cause you to spend even more money.
Anytime you increase the strength of one part you stress another and find the next weakest link in the chain.  Too bad the guy riding the bike is one of those weak links.  Merely makes it more dangerous for others.
Offline simon#42
  • liverpool
« Reply #1327 on: June 27, 2018, 04:52:40 AM »
they are the best rev counters by far , i have always used them . one ive had since the 70´s its been on rotax´s and aprilias and i have so far failed to kill it , i have had to search a few gravel traps for it mind .
Online gschuld
« Reply #1328 on: June 27, 2018, 06:39:19 PM »
Team Waller got some nice recognition on the VRRA site.  Brent’s bike was used on the main page👍
George
Online gschuld
« Reply #1329 on: June 27, 2018, 07:29:17 PM »
Start watching from about 23:20 and the crash(at 23:30) is about 100 yards ahead of the bike taking the video.
You can see Tyler pull away from the guy making the video early on(9:32, below)
George
« Last Edit: June 27, 2018, 07:52:34 PM by gschuld »
Offline simon#42
  • liverpool
« Reply #1330 on: June 28, 2018, 01:36:22 AM »
hard to see anyone at fault from that ,  will someone please teach yannick  to start racing when the flag drops and to try and be in the right gear occasionally .
Offline turboguzzi
« Reply #1331 on: June 28, 2018, 01:41:57 AM »
with all that armco around the track all where in luck to have it happen in a turn with good run-off..... like really lucky
« Reply #1332 on: June 28, 2018, 04:18:43 AM »
Ya think? ??? ;D
Offline simon#42
  • liverpool
« Reply #1333 on: June 28, 2018, 05:04:09 AM »
it made me cringe mike , as for changing down a gear on the exit of a corner ...... no.no.no no !
Online gschuld
« Reply #1334 on: June 28, 2018, 06:58:57 AM »
It was the only video I could find.  Tyler has the front row seat GoPro video footage of course, but I’m thinking he is distracted by his upcoming wedding on Saturday to edit and post the carnage video😉.
FWIW, Brent has another complete set of fairing/fairing mounts, fuel tank, and seat on hand ready to race.  Rearsets and other crash consumables are on hand or easily attainable.  So ideally Brent and Tyler have 4 weeks to put her back together again for the July 27-29th race at Calabogie.  Frame questions, bent fork tubes, wheels OK?  Time will tell.
George
Offline bear
  • Leeton in Australia
« Reply #1335 on: June 28, 2018, 06:34:28 PM »
Geezz......They reckon I could murder a box in my time but I don't think I could hold a candle to that bloke. :o
« Reply #1336 on: June 28, 2018, 08:02:58 PM »
LOL. That's an FZR600 in a 400 frame to boot. Probably the best combination in the class that day. After the red flag he came down the front straight weaving back n forth as if the race might restart and he was keeping his tires warm...... He never claims to be a front runner.
« Reply #1337 on: July 14, 2018, 04:57:52 AM »
Crash damage sucks, in the end though I feel lucky. The frame, swingarm, triple clamps and shocks survived. It's wise to have the odd weak link to save more expensive bits. For example, hollow axles reduce weight but can also be considered consumable. Kevin's (ttr400) front axle I was able to straighten. The front wheel was "tweaked" but just needed to be re-trued, forks were bend but salvageable. Otherwise front damage may have been worse.
The rear wheel is fine but the axle was bent in three spots and was replaced. I sent the Krober back to Belgium and it was re-calibrated. That is one fine tachometer and is tough as nails, it's been torn loose and flown away a few times. Of course little repairs like torn apart wiring takes time.
Every bracket known to man gets destroyed as does all bolted on controls, broken master included. Most of this stuff you carry in spares. The lower fairing survived, rest of the glass fibre bits are just that! Thankfully we have spares.
Many thanks to the friends here that help in a big way. This is amateur racing and sponsorship is a rare thing but believe me it is much appreciated.
This has been a very busy summer aside from racing, so my preparation time is limited. Wearing the number 1 plate for 2018 is a big deal so we'll be ready.
« Reply #1338 on: July 14, 2018, 05:37:53 AM »
Love the color of the exhaust
« Reply #1339 on: July 14, 2018, 07:55:28 AM »
Looks like I spoke too soon. Both brake discs are bent and there is something odd with the hub, may need to swap it too.
Did I mention crash damage sucks.  >:(
« Reply #1340 on: July 14, 2018, 09:36:14 AM »
Hopefully it's just an optical delusion, but the steering head appears to be tweaked to the right in the pic?
Online gschuld
« Reply #1341 on: July 14, 2018, 01:52:38 PM »
Brent, that stinks.  You use the cb500/550 diameter rotors not the larger cb750 rotors right?
George
« Reply #1342 on: July 14, 2018, 04:08:59 PM »
OK so I'm stressed.  ???
The discs are fine. After I walked away in a huff then returned after several hours, I realized my balance stand support rod is bent skewing everything. Crap, the silly stuff that happens.
Scottly the frame is ok, must be the picture.
« Reply #1343 on: July 14, 2018, 04:44:45 PM »
Brent, I can only imagine the frustration and anger you have to deal with on stupid stuff like this causing so much damage.  Even the little stuff adds up too fast.
Glad Tyler came through it fine and the wedding is unaffected by anything related to racing. Congrats to Tyler and his bride on their nuptials.
« Reply #1344 on: July 14, 2018, 04:54:23 PM »
Thanks man, they're pretty happy and he's walking on his own two feet!
Online gschuld
« Reply #1345 on: July 14, 2018, 05:08:21 PM »
That’s good news on the rotors😉.  We all have moments like that.
Offline turboguzzi
« Reply #1346 on: July 14, 2018, 11:27:10 PM »
quite a bit of carnage there.... the only time i binned something big time i had to throw it away, you get to keep it :)
funny, years later saw my motor for sale in a swap meet
Offline TimV840
    • YouTube Race Videos
« Reply #1347 on: July 15, 2018, 12:37:04 PM »
Holy hell! Breaks my heart to see a VFR like that. Broke the stem clean off! Sudden stops will do that I guess!
I have full confidence in The Master to have his Honda in tip top shape for young Ty to battle for a few podium finishes at the next round.
TimV
'71 CB350 - Race
'72 CB175 - Pitbike
'75 TR750 Replica - NEW Race
'85 Interceptor 500 - Street
'86 VFR 750 - Street
'96 VFR 840 - Street
'88 FZR400 - 1st Race Bike / Now Street
Offline turboguzzi
« Reply #1348 on: July 16, 2018, 04:10:53 AM »
TimV
bike slid under the ARMCO at 50 mph and the fork tubes hit one of the rail poles full on. luckily without me onboard... and dont ask about the challenge of retrieving that thing with a van.... sorry about the hijack brent!
« Last Edit: July 16, 2018, 04:13:33 AM by turboguzzi »
« Reply #1349 on: July 22, 2018, 02:03:07 PM »
It's a shorter list mentioning the parts that weren't bent or ruined but suffice it to say we're almost done. Thanks to George for a complete back up set of fibre glass parts saves the day. The Krober is on it's way back from Belgium after re-calibrating, due here Tuesday, then the bike can go in the trailer. We're leaving Thursday for the next race so the month long pit stop is nearly complete.   :o
