Author Topic: Let's go roadracing...continuing saga  (Read 221097 times)
Offline simon#42
  • liverpool
Re: Let's go roadracing...continuing saga
« Reply #1450 on: March 15, 2021, 10:49:59 AM »
as nothing turns in the caliper bush when the bike is moving there is not much point in any of that .
« Reply #1451 on: September 06, 2021, 01:56:55 PM »
Wow time flies, last post March. It's simple, when nothing happens, there is nothing to report!
Our race season ended this past weekend. I was asked to head up a small team of ex racers in a safety check on the mock grid. Pretty simple stuff and I communicate with race direction in the tower. It keeps me involved with the club and our group gets along and has our share of laughter!
Our ass'n had only two rounds, one in Aug and last weekend. The provincial gov't mandates track safety regarding Covid but spectators were allowed. It just seems odd that we've only had three rounds in two years and our neighbours to the south are running events non-stop. Be that what it may, it was great hooking up with fellow motorcycle folk and enjoying some good racing.
My bike raced only the August round at Mosport and the track was fast, Tyler dropped into the low 1:36's which is fully half a second faster than his previous best. Good for a 70's 500. I finally finished an alteration with the rear caliper bracket, and torque arm. Just simply the way it should have been designed the first time.
When I sent the cylinder to Millenium for replating after the 2019 season, I asked that they straighten the upper deck, which they did, however they then bead blasted both surfaces. One sleeve didn't plate well and was overlooked so I returned it with another spare sleeve to use as a replacement. After much "discussion" LOL they agreed to remove the sleeves and re-do the surfaces. They argued until blue in the face that "older Hondas need a blasted surface to help seal". I argued to the contrary! The surfaces were mirror like when returned, certainly the smoothest surfaces I've ever seen.
During the months after engine assembly while I finished the chassis work, I fretted about this. Maybe the blasted surface would allow a better "bite" for the viton/steel base gasket and the sealant I use with the copper head. Did I shoot myself in the foot.....?
The answer is no! It has never been more oil tight. If the decks are flat, then the smoother the better, and the proof was in the pudding. Honestly I felt more than a little relief, but glad to have stuck to my principals. LOL
I want to re-think an idea to limit shift drum rotation during shifting. In race pace there is never an issue, but at a reduced pace like the sighting lap or cool down it sometimes slips through 2nd into neutral on a down shift. The CB650's shifter shaft incorporates a mechanical limit during shifting as I recall. I'll attach some pics later if it's an easy solution.
« Last Edit: September 06, 2021, 01:59:17 PM by bwaller »
« Reply #1452 on: September 06, 2021, 04:39:38 PM »
Sorry to hear you guys have been locked down and unable to race. Hopefully it wasn't without positive effects for the virus reduction.
Glad you had great results though.
I think the virus and its mutations will be with us a long time...so, we need to learn to adapt and move on with our lives. Enjoy life now, there are no makeup days...
Happiness is largely a choice.
« Reply #1453 on: August 19, 2024, 02:17:40 PM »
Well I've been a bit of a stranger here for a long while. I just wanted to make a quick update in case anyone remembers, or gives a damn!
The VRRA had our Mosport (Canadian Tire Motorsport Park) round this past weekend. The weather was good & bad but managed to get through all the finals yesterday. My son Tyler is probably only able to make one race weekend a year, so my bike doesn't get raced very often. He did very well though and came within a second or so per lap of his previous best time. The bike ran like a top.
Martin Morrison and his brother came from Ohio to race with us and both rode well. Martin raced his CB550 and it looked and sounded great as usual. Tyler and Martin finished one/two in their natural class, so good outcome for the 550's. Well done guys
I'll see if I can dig up some pics and post them here.
« Last Edit: August 19, 2024, 02:22:59 PM by bwaller »
Offline Old Scrambler
« Reply #1454 on: August 19, 2024, 02:56:24 PM »
It's great to hear from you..........NO.........we have not forgotton ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #1455 on: August 19, 2024, 04:38:46 PM »
Brent congrats to you both on the great results and fun outing. After the Davies frame suffered a nasty outcome did you replace it with another or go back to your reinforced stock frame for the cb550?
Congrats again!
« Reply #1456 on: August 19, 2024, 05:36:06 PM »
Never had a Davies frame.
« Reply #1457 on: August 19, 2024, 05:38:02 PM »
Was it another custom frame or am I merely dreaming?
Offline turboguzzi
« Reply #1458 on: August 20, 2024, 12:47:29 AM »
wow, nice to hear! kudos to you and Tyler still being competitive.
« Reply #1459 on: August 20, 2024, 06:54:15 AM »
We changed the steering head and head angle, plus beefed up that area. Thanks TG, it's been a while, I'll send you a note.
« Reply #1460 on: August 21, 2024, 09:25:31 AM »
This bike is done for the season. It hasn't been raced much the last couple seasons, and probably has only 5 race weekends since last rebuild. Still I always tore it down and followed my procedure at the end of every season. I'm just unsure how much the bike will race going forward.
The bike is running flawlessly, but I decided to do a leakdown test and decide how the top end looked. I always drain all race gas then run it on pump gas to heat it up to drain oil. I have found the VP fuel I use will rust spark plug ends if left so must be some corrosive properties if left alone.
I'd like to hear how others perform leakdown testing, but I like to run the engine, then cool a bit but check while still warm. Then pull each piston to TDC, then back it down the cyl about 10 degrees and have someone hold the crank in place, so the piston doesn't move. It's really good, 1x 3.5%, 3x 4%, all past the rings. With Nic bores and thin rings I've seen this before, it takes a while to seat the rings.
There is some metal chaff on the drain plug magnet which I expect is from the gearbox from after it was polished. Maybe I'll just pull the bottom case and check it. Otherwise the top end is fine.
« Reply #1461 on: August 21, 2024, 01:39:53 PM »
Damn Brent! I knew I was missing something in my life - your race reports. Get back on it asap
