Author Topic: What gauge is the stock battery/starter cable?  (Read 4196 times)
Offline timdhawk
  • 1978 CB750K
« on: February 17, 2011, 04:21:22 PM »
I am having a hell of a time finding cable this size. I thought it was close to 8 ga (I know stock is metric sized) but looking on an AWG wire size chart using the actual wire OD measurement, stock should be a 4 ga. When held side by side to "8 ga" battery cable at the auto parts store the wire portion looks to be the same size but the wire coating is twice the factory diameter.
I really want/need to keep it as close top factory size as possible.
In deeper than I should be...
Offline Gaither
  • '77 CB550F
Re: What gauge is the stock battery/starter cable?
« Reply #1 on: February 17, 2011, 05:51:20 PM »
Have you tried a Honda Dealer? Likely so.
'Just a thought - -
Gaither ('77 CB550F)
Offline timdhawk
  • 1978 CB750K
« Reply #2 on: February 17, 2011, 08:16:18 PM »
'Just a thought - -
I forgot to mention this is for a custom length application, not a factory run.
Offline timdhawk
  • 1978 CB750K
« Reply #3 on: February 18, 2011, 07:24:06 AM »
anybody?
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: February 18, 2011, 07:30:59 AM »
What are the required amps for this connection? I don't know them off-hand, but you might use that as a guide.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=3pkc5e88qt6229p7cuafbg8a87&/topic,60973.0.html
« Reply #5 on: February 18, 2011, 11:14:36 AM »
i have uset 2 parelel kabels..it fits better   think it must take up to 120 amps
i hate all this v-w.... vords
Offline Trav-i
  • Has finally become an
« Reply #6 on: February 18, 2011, 01:25:10 PM »
I used 4 gauge on my chop, to do a custom length run and have had no problems.
Travis
Forum member #9962
1992 GL1500 Interstate
Offline Bodi
« Reply #7 on: February 18, 2011, 03:02:04 PM »
There's no exact AWG equivalent, Japanese wire gauge/size is measured in square mm. I would probably go with AWG 4, you could get away with AWG 8 since the starter is a short term load and although the wire would get warm if you ran the starter for a long time, the voltage drop over a short length would be minimal. AWG 6 would be great but just try to find it.
Offline timdhawk
  • 1978 CB750K
« Reply #8 on: February 19, 2011, 07:41:26 AM »
Thank you. Thats what i needed to hear.
