Author Topic: 400f gear pedal/ lever options  (Read 803 times)
Offline Tim2005
« on: February 21, 2011, 01:28:22 PM »
Has anyone found an gearchange lever that fits a 400f, either with it's own linkage or using the 400s? I don't want rearsets or anything, just the lever in stock position, and ideally I'd like to find a tasty looking alloy one.
thanks
Offline gerryw
Re: 400f gear pedal/ lever options
« Reply #1 on: February 22, 2011, 05:34:50 PM »
my yamaha  rd350lc (82) linkage, slips right on, the lever is shorter, but will work, the lever boss is thinner , so you would have to shim it a bit. I will be buying a pattern one for my bike.
If you are in the states, i would look at rz350 ones..
I would assume various honda ones would work, would be worth a hour or so at a friendly bike wrecker.
I know intercepter levers (mid eighties) are aluminum would look good.
Gerry
