Hey Guys....
Got me wondering what caused the swelling of the phenolic pistons...
found this on the web...makes some sense...Of course...ANYTHING you read on the web must be true...right?
Q. Why do some brake calipers have phenolic pistons while others have steel pistons?
A. It depends on what the original equipment manufacturer or rebuilder chooses to use. Phenolic pistons are 80 percent glass fiber bonded together with phenolic resin, the same type of binder that’s used in brake pads and clutch linings. Phenolic pistons are light weight, won’t rust or corrode like steel, doesn’t transmit heat to the brake fluid, and they have a greater amount of “roll back” when the brakes are released which helps reduces brake drag. Steel pistons, on the other hand, are stronger and can take more abuse. They also help pull heat away from the pads.
Phenolic pistons and steel pistons have both been used since the 1970s in brake calipers. So have aluminum pistons.
Ford and Chrysler vehicles have used phenolic pistons almost exclusively. General Motors, on the other hand, has used mostly steel pistons in the calipers of its vehicles over the years. The same is true for many import vehicle manufacturers.
Q. I’ve heard that phenolic pistons sometimes swell up and stick. Is this true?
A. Phenolic pistons do swell slightly because the material is hygroscopic (absorbs moisture). But most of the swelling occurs immediately after manufacturing and is limited to about a .001 to .002 inch dimensional change. By compensating for this with increased manufacturing tolerances, sticking should not be a problem in normal use. Some Chryslers back in the 1970s had phenolic pistons that would swell up and stick because of moisture contamination, but that’s ancient history.
Q. Can phenolic pistons be reused in a rebuilt caliper?
A. Yes, provided they are undamaged. Phenolic pistons are brittle and can be damaged by careless handling during disassembly. But if handled with care, they can often be reused.
Phenolic pistons can sometimes develop a slight bellmouth shape when the pads wear down and the piston protrudes from its bore. In such instances, the piston would not be reused.
With steel pistons, it’s a different story. By the time a caliper needs to be rebuilt, the steel pistons are often corroded and can not be reused. Most steel pistons are nickel and chrome plated to resist corrosion, so pistons should never be sanded to clean them up. Doing so removes the protective coating and encourages corrosion.
