Author Topic: Source for 110mm rotor bolts?  (Read 1490 times)
Offline Bakeoff
« on: February 28, 2011, 11:55:47 AM »
I have everything ready to go for my dual disc setup on my '74 550 aside from hoses (easy) and bolts.  What do you guys source the bolts from or where do you get them?  Sure, I could do something from Fastenal or McMaster, but I'm trying to retain an OEM finish and not spend an arm and a leg.
Offline Steve F
Re: Source for 110mm rotor bolts?
« Reply #1 on: February 28, 2011, 06:43:23 PM »
If you're looking for the zinc plated bolts of the proper length....good luck.  When I did mine, I used stainless bolts from McMaster and I had to shorten them to the right length and face the heads a little to clear the speedo drive.  If I had the zinc plated bolts, I couldn't have done this without the fear of rust setting in on the exposed metal.
Steve F
Offline Grabcon
« Reply #2 on: February 28, 2011, 08:31:54 PM »
Graingers has the bolts you need that are zinc plated. They are around $10.00 for the 6 bolts.
CB750   1974 - Gone
CB750F 1976 - Gone :(
CB550   1978 - Gone & now back
CB900F 1981 - Gone
ST1100 1991 - Gone
ST1100 2000 - Gone
VFR800 2008 - Gone
ST1300 2008 - Gone
BMW F700GS - Wife's
VFR1200X 2016 - Mine
Offline johnrdupree
« Reply #3 on: March 01, 2011, 05:24:54 AM »
I'm in the same boat with my 550.  I've been scouring the net looking for bolts and zinc or stainless are the only options I've found.  The original finish is chrome and nobody makes them.  GL1000 bolts (OEM #90122-371-000, discontinued) should work, if you can find some.  I'm torn between going to Fastenal or the junkyard.
Good Luck
~john
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
1954 NSU Lambretta 125 (long term project)
Offline mrrch
« Reply #4 on: March 01, 2011, 05:47:42 AM »
my build
Offline johnrdupree
« Reply #5 on: March 01, 2011, 05:55:38 AM »
Oh, wait, hold the phone.  I think this is what we're looking for:
http://www.allensfasteners.com/detail.asp?Product_ID=70673
I have to hit the junkyard anyway, but if that doesn't work out I may have to give these guys a shot.
~john
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
Offline Bakeoff
« Reply #6 on: March 01, 2011, 07:34:31 AM »
Wow!  Some real info! I'll follow up on these leads and let you guys know what I find out.
Offline mrrch
« Reply #7 on: March 01, 2011, 07:40:21 AM »
Good find.
Easy to find deals when so many sets of eyes are looking.
my build
Offline raymond10078
  • Just learnin' as I go . . . .
« Reply #8 on: March 01, 2011, 09:17:41 AM »
I went to bikebandit, entered 8x110 in the search bar, and got a list of Honda bolts from various bikes.  Just another idea . . . .
The nice thing about it is that you can click on the "applications" link to find out where the bolts were used.  Lots of info.
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline mjstone
  • I'm definitly not a
« Reply #9 on: March 01, 2011, 09:28:54 AM »
I went to the local hardware store to get mine.  Found out that they didn't carry any metric long enough.  What to do?  Went over to the SAE stuff, 3/8 x 4 1/2" and nyloc nuts.  Perfect fit!  No need to do anything with clearance, speedo drive clears just fine.
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
Offline Bakeoff
« Reply #10 on: March 01, 2011, 10:56:02 AM »
Then I'd have to use those damn fraction wrenches that get shoved to the back of the tool box!   :P
Offline Ricky_Racer
« Reply #11 on: March 01, 2011, 11:34:39 AM »
Hi. Where did you find the "applications" link with the reverse part number lookup? Thanks! RR
« Reply #12 on: March 01, 2011, 11:54:57 AM »
[/quote]
The "applications link" is actually called (on the web page) "Fits machines".
How did I find it?  Just a lot of internet searches, trying to find what fits what, or what interchanges with what.  Unfortunately, bikebandit has changed over to their own part number system, but when searching, Honda part numbers are still recognized - and as indicated, parts descriptions can get you there too, as long as you know what Honda originally called a part (sometimes the name isn't what you'd think it would be).
