I've just picked up a '75 CB 750K in great (cosmetic) condition. It hasn't been on the road since 1995, so I know I have quite a bit of work ahead of me. I have the Clymer manual, and some experience getting an '82 Yamaha XJ 650 Maxim all fixed up a couple of years ago. That was carb rebuilds, balancing, and a lot of electrical work. Here's my list for things I have to do for the CB so far:
Replacing:
- Oil filter
- Air filter
- Plugs
- Ignition wires, most likely
- Clutch/throttle cables
- Master cylinder leaked all over, rebuilding to be on the safe side
- Caliper rebuild
- Chain
- Sprockets
- Clutch
- Carb rebuild
- New fuel lines + inline filter
- New wiring harness was $75 at partsnmore.com, so I went for it. I hate electrical problems.
- Clean/dielectric grease all electrical connections
- Sealed fuse box and blade type fuses
- Fork oil
Tank is not rusty, and the inline filter should take care of what I can't see.
Bike has electronic ignition.
I have questions about brake pads/shoes. The mileage on them is unknown. Should they be replaced anyway, just due to age?
I've bought the clutch friction plates and springs, but I'm not sure about the steel clutch plates. The previous owner related a story about how he had a bike that hadn't run in a while, and the clutch felt fine... but after 500 miles, the plates had basically disintegrated and he had no friction. Should I replace them to be on the safe side?
Tires, mileage unknown. They hold air and have no cracks that I can see, but is a tire that old safe?
Wheel bearings. Again, mileage unknown. Probably better to replace, but it doesn't look all that easy for the rear wheel, and with all the stuff I have to do already... I'm afraid I'll take this thing apart and get stuck on a few bits and pieces and then I won't get it all back together until mid-June.
I am resisting the urge to replace the rusty back spokes "while I'm in there" because I can see aligning the wheel being a second-guessing-myself nightmare.
Cam chain. Bike has 28,000 miles, and it's never been replaced. I hear the replacement time is 30,000 miles and and I don't expect I'll put all that many miles on it this summer. Something that can wait, or should I do it now?
I think that's all. The plan of attack is to get the carbs rebuilt and fire it up first. The back brake works, so I'll be able to ride it around a parking lot at low speeds. After that electrical, then all the roadworthy stuff. Trying not to change too many variables at once.
Anything else I should be doing, or other advice?
