The SOHC/4 World Tour is in under way.
ZV, are you checking with the throttle wide open? The readings you have should start the engine. Once it starts you should see the readings go higher. Good luck...Larry
HOLY CRAP $150!?!?
Quote from: photolar on March 14, 2011, 09:30:35 AMZV, are you checking with the throttle wide open? The readings you have should start the engine. Once it starts you should see the readings go higher. Good luck...LarryYes, kind of. Im doing the compression check without the carbs on the bike. So essentially wide open.Quote from: Free Booter on March 14, 2011, 08:34:18 AMHOLY CRAP $150!?!? Yep. The guy was asking $250. I offered $150 and he took it.
Quote from: ZanVooden on March 14, 2011, 11:21:14 AMQuote from: photolar on March 14, 2011, 09:30:35 AMZV, are you checking with the throttle wide open? The readings you have should start the engine. Once it starts you should see the readings go higher. Good luck...LarryYes, kind of. Im doing the compression check without the carbs on the bike. So essentially wide open.Quote from: Free Booter on March 14, 2011, 08:34:18 AMHOLY CRAP $150!?!? Yep. The guy was asking $250. I offered $150 and he took it.Give it another dose of Seafoam and check it again..Larry
