Author Topic: Caliper emergency! Please calm my nerves...  (Read 1641 times)
Offline ddanz27
  • 1974 CB350F
« on: March 03, 2011, 09:40:52 PM »
Okay so I picked up a caliper seal tonight for my 350f and wanted to start the rebuilding process on my caliper (hoping I can get by with just a seal and no new piston). I get it off okay and everything looks fine only I can not get the piston or pad out of the left hand side! How do I get this thing out so I can continue?? If it is frozen in there am I going to have to drop a couple hundred on a whole new caliper??? Like always, thanks for your help guys...
1974 Honda CB350F
Offline BeSeeingYou
Re: Caliper emergency! Please calm my nerves...
« Reply #1 on: March 03, 2011, 09:45:49 PM »
I take it you disconnected it from the master cylinder?  Hook it back up but don't mount it to the fork, bleed it and use the master cylinder to pump the piston out.
Offline cameron
« Reply #2 on: March 03, 2011, 09:50:23 PM »
everyone does that the first time. :)
1976 CB550F
« Reply #3 on: March 03, 2011, 09:52:33 PM »
If you can't pump it out with the master cylinder, the grease-gun method never fails. ;)
Offline ddanz27
  • 1974 CB350F
« Reply #4 on: March 03, 2011, 09:53:22 PM »
Yes I did disconnect it from the MC. So I should be able to reconnect and just pump it all the way till it practically falls out? Thanks that makes sense now, looks like I just got ahead of myself. Heres another question for ya, what kind of medium should I polish/clean the cylinder/piston with? steel wool to rough?
1974 Honda CB350F
Offline cameron
« Reply #5 on: March 03, 2011, 09:56:44 PM »
hook it back up, bleed it a little.. and use the hydraulics to pop it out. CAREFULLY, or you get covered with fluid.
And fine sttel wool is fine.. but probably overkill. Hopefully it will come out pretty clean, with no surface rust or anything.
Last time I did mine.. i used a paper towel and some windex.
1976 CB550F
Offline BeSeeingYou
« Reply #6 on: March 03, 2011, 10:05:09 PM »
Yeah you will have to bleed it to get it to work.  You don't have to do a perfect job.  A cloth and polishing/rubbing compound will do the trick on the piston.  Make sure you clean out the seal groove as junk collects in there and causes the brake pad to hang up.
And make use of the search function as all this has been posted before as well as just about every other problem you may run into.  A wealth of useful advice is at your keyboard. :)
« Last Edit: March 03, 2011, 10:06:43 PM by srust58 »
Offline faux fiddy
  • bike in a box
« Reply #7 on: March 04, 2011, 01:01:06 AM »
I just did a thread on that/ question and advide from an old school  GURU.
Use a softer metal to dig the crud out of the groove the seal sits in.
Homemade tool made of copper, a softer metal won't scratch things up.
http://forums.sohc4.net/index.php?topic=84409.0
And as far as nerves, if beers don't work, maybe hunt down a valium?
Oh yeah, and I hear DO  NOT USE WD-40, DO NOT USE SOLVENT, DO NOT USE PENETRATING OIL. USE ONLY BRAKE FLUID AND DISC BRAKE ASSEMBLY LUBRICANT.
\ Anything else ruins brake seals.
+1 to all of the above.
« Last Edit: March 04, 2011, 01:04:39 AM by tree fiddy of industry »
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline Kong
« Reply #8 on: March 04, 2011, 04:59:22 AM »
You might be able to clean up your piston, once your get it out, with steel wool, but what you may find is a rusted ring around it right where the old seal contacted.  Stock replacements are irrationally expensive but a member here crafts composite replacements (using stock Ford (Lincoln) caliper pistons as his base stock) that will last a lifetime.  He charges about half what a stock replacement costs and his pistons are superior.
The best way I've found to clean the caliper itself it to toss it into a can of carb cleaner overnight.  Do that and you won't have to scrape the (aluminum) seal groove with anything harsher than an old tooth brush.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline MoMo
  • Ride like you're invisible
« Reply #9 on: March 04, 2011, 05:28:12 AM »
Kong,  does the carb cleaner damage the black finish?...Larry
Offline Kong
« Reply #10 on: March 04, 2011, 05:37:20 AM »
Larry,
Didn't touch mine.  The caliper cases are apparently powder-coated.
I'll come back later today and note which brand of carb cleaner I used on them - it was probably the "Gunk" brand, but I'll check.  Whatever it is the stuff was sold at Advanced Auto, I'm sure of that; I bought a gallon of it ($19 if I remember correctly) just a couple of months ago.
1978 Honda CB550K
1977 Honda CB550K
bollingball
« Reply #11 on: March 04, 2011, 05:37:38 AM »
+1 on all others advice. Only if you have to use steel wool use #0000
Offline ddanz27
  • 1974 CB350F
« Reply #12 on: March 05, 2011, 08:24:56 AM »
Thanks for all the advice guys. I ended up just reattaching the mc and pumping thr piston out that way. Once I got it out though I noticed some pitting on the piston. Were talking ballpoint pin sized pits. Should I try and reuse or buy a new phenolic?
1974 Honda CB350F
Offline BeSeeingYou
« Reply #13 on: March 05, 2011, 10:21:04 AM »
If you are the neat type you can clean them with a sharp pick then fill them with JB Weld using a plastic squeegee made from a milk jug.  Sand smooth with very fine sandpaper if needed.  If you're the type that tend to get more on you that the object being repaired get the plastic replacement. ;)
