Author Topic: Is my brake piston fubar?  (Read 1900 times)
Offline domer
« on: March 05, 2011, 09:50:28 AM »
probably, but how the hell should i know... any input is appreciated. oh and if i could afford the time and cash, i would have just bought a new one any way, but if i gotta, i gotta. the seal came out in multiple pieces, so im hoping the piston will do... whats that old saying? wish in one hand and something in the other?   ;D
Re: Is my brake piston fubar?
« Reply #1 on: March 05, 2011, 09:59:52 AM »
Looks borderline. Depends on where the pits hit in relation to the seal. With new pucks, assuming the old oones were worn, the pits will be at a different place, unfortunatley, maybe closer or under the seal.
Try it, if it leaks get a new one.
Offline BeSeeingYou
« Reply #2 on: March 05, 2011, 10:06:16 AM »
Take a sharp pick and clean out the pits and then using a sharp flexible plastic squeegee (made from a milk jug) scrap a small amount of JB Weld across the pits. Sand smooth with very fine sandpaper.  Or for around $35 a member here makes phenolic replacements that seem to have a good rep.  Do a search for those.
Offline domer
« Reply #3 on: March 05, 2011, 10:16:42 AM »
ya, i kinda figured it was shot, or damn close. and its not like its gonna get any better... and $35 is doable. phenolic piston it is. too bad, its like 68 and sunny  :'(
« Reply #4 on: March 05, 2011, 10:52:57 AM »
I wouldn't say that piston is shot...
Offline HondanutRider
« Reply #5 on: March 05, 2011, 01:28:55 PM »
2nd
Offline Toxic
« Reply #6 on: March 05, 2011, 04:52:40 PM »
I reused mine with no issues and it was in slightly worst shape than yours.
Get a new seal from your Honda dealer and make sure you clean out the groove properly.
Search on here for "caliper rebuild" and you will find more than enough info.
Offline nilsey
« Reply #7 on: March 05, 2011, 06:37:43 PM »
2nd
3rd!
i rebuilt my caliper last week, the piston's in worse shape than that and its been serving me fine.
1976 CB550K: stock airbox, cb650 cam swap, 4x2 exhaust, dual disc brake conversion.
1974 BMW R90/6
Offline domer
« Reply #8 on: March 05, 2011, 06:41:39 PM »
 ;D ;D ;D
That's what I wanted to hear. Already have a new seal, guess I'll give it a shot!
Offline MoMo
  • Ride like you're invisible
« Reply #9 on: March 05, 2011, 06:46:10 PM »
+4  I have used much worse without any problem after filling with JB...Larry
Offline Kevin400F
« Reply #10 on: March 06, 2011, 03:00:35 AM »
If it leaks and you want a corrosion-proof phenolic replacement piston, let me know.
Kevin
Offline Kong
« Reply #11 on: March 06, 2011, 05:20:17 AM »
I've got two of Kevin's pistons, in my dual disk setup and recommend them.  Smart money (and not too much of it) to spend.  Once you put out the money for one of his pistons, which don't cost a whole lot more than a new seal, your worries about sticking or corroding brake internals are gone forever.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
