Author Topic: superbike bars w/ internal wiring  (Read 5455 times)
nomad
« on: March 06, 2011, 06:25:41 PM »
I've looked around and didn't see anything like this, but can someone tell me if anyone makes a set of superbike bars that are already punched for internal wiring?  I guess I could drill the holes, but would rather not.
If drilling my own is the only option, what's the best way to go about it other than simply drilling and filing the edges?  Thanks.
Offline DarcyCB400F
Re: superbike bars w/ internal wiring
« Reply #1 on: March 06, 2011, 06:30:08 PM »
Not sure if this helps but here goes anyway...  ::)
The factory bars on the '77 CB400F are wired internally...
1977 CJ360T
1977 CB400F
1980 CB900 Custom
1981 GS550L
1989 DR200R
1998 VT1100C2 ACE
1999 XR400R
2006 CR230F
2007 HD Road King
nomad
« Reply #2 on: March 06, 2011, 06:32:35 PM »
The factory bars on my '74 CB750K were wired internally too...
Offline Grabcon
« Reply #3 on: March 06, 2011, 07:56:55 PM »
Ideally a milling machine would help, but for most of us a drill press or a hand drill are in order. Drilling the holes is not the issue, it is getting all of the burrs out from the inside of the holes. Those burrs will cause great electrical grief.
I opted to grind out the controller on each side and run the wires on the outside. It may not look as clean but it is simple and there will be not electrical issues.
CB750   1974 - Gone
CB750F 1976 - Gone :(
CB550   1978 - Gone & now back
CB900F 1981 - Gone
ST1100 1991 - Gone
ST1100 2000 - Gone
VFR800 2008 - Gone
ST1300 2008 - Gone
BMW F700GS - Wife's
VFR1200X 2016 - Mine
Offline DavePhipps
    • Hillside Technology
« Reply #4 on: March 06, 2011, 08:09:29 PM »
The 400 bars are closer to superbike bars then the 750 high rise things.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
nomad
« Reply #5 on: March 07, 2011, 04:00:41 AM »
Ohhhh, ok.  Not having any familiarity with the CB400's left me scratching my head.  Thanks for cluing me in.  ;)
« Reply #6 on: March 07, 2011, 04:07:45 AM »
Drilling the bars is not so hard once you get to it. Use the old bars for a template. Centerpunch and drill 2 holes near each other then connect them and file or Dremel them into an oval. One small hole for the locating peg. A hand held drill will do it if the bars are in a vise or suitable holder. Sharp bits always help.
Offline vames
« Reply #7 on: March 07, 2011, 04:14:56 AM »
Those little cutting wheels on a dremel will cut a nice clean line between two drilled holes.
Hinomaru
« Reply #8 on: March 07, 2011, 04:46:25 AM »
OK, it's not a true Superbike bar, but the Flanders "Cafe Style Bar" is very close to the original Honda "Euro" bars pictured below. The Flanders bar has internal wiring holes and are knurled. They do not come cheap, but your original K4 clutch & throttle cables fit nice. The upper brake hose will need to be shorter for a clean fit that looks factory.
Part number: 650-01071 on page 35:
http://www.sideroadcycles.com/HandlebarCatalog1-28-2011.pdf
Here's a pic of my original Honda 750K Euro bars for comparsion:
nomad
« Reply #9 on: March 07, 2011, 05:57:33 AM »
http://www.SideRoadCycles.com/ImportedMotorcycles/ImportHandlebars/ImportStreet/78StreetWire.html
Wow!  $110.95!!!  Besides the cables fitting nicely, what makes this bar cost that much?  Is it made from some special, space age alloy?  Like you said... pricey. :(  BUT, it does seem to fit the bill on what I'm looking for.  I guess at this point, the wife shouldn't flinch too much at another $100+ part.  ;D  Then again...
Hinomaru
« Reply #10 on: March 07, 2011, 06:32:23 AM »
Well, Flanders bars are considered by some to be the "Holy Grail" of handlebars and you're probably paying for the name. Being made in the USA adds to the price too. My personal experience shows them to be a high quality part right down to the chrome plating. I've also "heard" that they are harder to bend when your bike falls over. ;)
http://www.flandersco.com/
Offline Really?
« Reply #11 on: March 07, 2011, 09:01:38 AM »
I got the wires in momma's bars.  Used a dremel and a drill to make all the holes.  Not too much work to do it either.  If you make a small mess, no matter, the controls will cover them up.
I used a 3x5 card.  I wrapped it and cut out the holes.  Used those to mark the other bars.  Worked out very well.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline cobrajunkie
« Reply #12 on: March 07, 2011, 10:20:26 AM »
I need to drill my bars soon as well and the burrs have been a concern.  I have 12" rat tail file I plan to use.  Any other ideas for removing the burrs left by drilling?
« Reply #13 on: March 07, 2011, 10:39:31 AM »
a silicon carbide grinding bit for your dremel/ hand drill.
should speed things up a bit.
« Last Edit: March 07, 2011, 10:44:49 AM by flybox1 »
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #14 on: March 07, 2011, 01:51:14 PM »
Hop on amazon and get a pipe deburring tool.  That'll clean up things nicely.  Then don't forget to get a rubber grommet if you can, that'll help all but eliminate wires rubbing.
nomad
« Reply #15 on: March 07, 2011, 02:11:12 PM »
I wonder if Plasti Dip painted on around the perimeter of the hole would work?
Offline wannabridin
  • -Garrett
« Reply #16 on: March 07, 2011, 04:40:05 PM »
I don't see not, but youd probably need to wrap it around at least the id or od of the bars, otherwise I see it rubbing off.  Grommets are clean and simple! :)
nomad
« Reply #17 on: March 07, 2011, 04:42:52 PM »
I was just thinking that a grommet for an oval, custom cut hole would be hard to come by.  The round holes up near the grips would be easy to get grommets for.  Is there a source for oval grommets?
« Reply #18 on: March 07, 2011, 05:13:16 PM »
There may not be room for a grommet. I'd just clean the burrs up real good and go on.
Offline wannabridin
  • -Garrett
« Reply #19 on: March 07, 2011, 05:44:59 PM »
http://www.rubbergrommets.com/products/search.php?product=grommets
i don't know about the oval grommets.  i'm probably going to go this route just because i'll have minimal wiring going through my bars.  (DCC switch housing, no starter, brake line switch.)
Offline Scott S
« Reply #20 on: March 15, 2011, 06:40:34 AM »
 I understand the actual cutting/drilling part, but I'm still unsure about marking the holes in the correct spot.
 I have a set of 400F bars, but they're just too narrow for me. I was going to drill another bar, but don't know how to get the holes marked so that the controls aren't rotated too far forward or back one the bars are mounted.....am I making sense?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Really?
« Reply #21 on: March 15, 2011, 08:17:54 AM »
Yes, use the cards like I recommended up above.  After you have the holes in the card punched out, also mark the card at 12 o'clock.  Decide where you want the new bars, cut the holes out in the cards and use a marker or something to mark where you are going to make holes on the bars.
If you need to, you can always oblong the the hole for the pin to get a little more rotation out of it.  It really does not take much.  And you will have enough wire to make up for the small difference.
Hope that makes sense.
Offline robdrobd
  • Who? Me?
  • Isn't she a beauty?
« Reply #22 on: March 15, 2011, 08:25:12 AM »
I think I have a pair of 76 750f bars and a pair of 77 400f bars. If the 400f bars you have are from a 75 or 76 I will trade straight up or even add cash to the deal if needed. I want the narrow, lower profile bars for my 77 400f. Let me know, thanks.
« Reply #23 on: March 15, 2011, 08:35:07 AM »
wrap your bars in painters tape first.
then, using TipperT's card trick, trace your cutout on the tape with a sharpee then go to work  8)
