Author Topic: Supercharged CB750 drag racer engine on Ebay  (Read 10514 times)
Offline Phil
« Last Edit: March 09, 2011, 02:10:41 AM by SamCB750A »
  • Moderator
Re: Supercharged CB750 drag racer engine on Ebay
« Reply #1 on: March 08, 2011, 09:07:33 AM »
It's H2Erics old motor that he posted a picture of recently.
Sam. ;)
Hey Buckers old chap, what did you do to the gearbox? made a right pigs ear of that one ;D ;D ;D ;D ;D
Sam. ;)
« Last Edit: March 08, 2011, 09:13:32 AM by SamCB750A »
Offline JLeather
« Reply #2 on: March 09, 2011, 04:20:46 AM »
Man, that is a badass looking setup.  Wonder if it could be at all streetable...
Offline H2Eric
« Reply #3 on: March 09, 2011, 06:54:10 AM »
Hi y'all
Badass motor for sure or should I say was, as it will require some work and quite a few parts to get the thing going. No gearbox and no oil pump either. The original gearbox was a Pete Miller 3-speed, constructed form Jaguar (car) overdrive units - gear change by compressed air (100+ psi). The magneto that is also on offer is a Vertex one with all the advance / retard gubbins removed so that it can be laid over on its side and driven by means of a toothed belt. This also means it's fixed advance. The Hilborn jets (pills) that went with the setup have apparently gone AWOL and if the previous owner did nothing to it as seems highly likely it is still set up for an 80% nitromethane 20% methanol diet. No pulley on the supercharger, but I assume that Mr. Magnuson could supply another one as the company appears to be still in business, half inch pitch, 25mm bore according to the manual, which I've still got. Still got the original bill of sale for the blower as well. Blower was run at approximately 15% over engine speed if memory serves. See the listing for the condition of the crank cos it's damaged unless of course W. Fish Esq of Blackpool who acquired the bike from me changed it for the spare, but I very much doubt it. In which case the spare crank has gone AWOL as well. There was also an A4 sized folder with copies of the Magnuson manual, Hilborn injection set up and gearbox, perchace that has gone the same way.
G. Magnuson Esq. offered these blowers for street use using a drive off the clutch. Never never seen such a set up myself, but there is a picture of one for a Kawasaki 900 in the manual.
I'm afraid it does ever so slightly pi$$ me off to discover that my original bike has been neglected and broken up. I often wondered what had happened to it, now I know at least partly.
Whoever gets this motor I wish them the very best of luck and I will be only too happy to provided any further info or assistance I can, but I do hope they will give it a good home put it to good use.
Cheers
Eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
http://forums.sohc4.net/index.php/topic,94588.0.html
Growing old is mandatory, growing up is optional.
  • Moderator
« Reply #4 on: March 09, 2011, 07:19:14 AM »
What's it worth Eric?
Sam. ;)
Offline H2Eric
« Reply #5 on: March 09, 2011, 01:27:37 PM »
Just what somebody is prepared to pay for it.   ;D ;D ;D ;D
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
  • Moderator
« Reply #6 on: March 09, 2011, 03:24:40 PM »
It's jumped from 6 bids at £230 to 13 and £485 in the past few hours. ::)
Sam. ;)
« Reply #7 on: March 09, 2011, 05:21:25 PM »
Sam. ;)
Are you supposed to be on a plane or something?
  • Moderator
« Reply #8 on: March 09, 2011, 11:08:23 PM »
What's the rush Murphy? the rushing will start soon enough I hope. ::)
I'll be on my way by the time you read this.
Sam. ;)
« Reply #9 on: March 09, 2011, 11:13:37 PM »
Sam. ;)
Have a safe trip Sam.... ;)
  • Moderator
« Reply #10 on: March 09, 2011, 11:33:12 PM »
Cheers Mick, just got to take a bath and finish packing.
Must go and put the lottery on for the next few weeks :D :D :D
On my way in 2 hours.
Sam. ;)
Offline H2Eric
« Reply #11 on: March 10, 2011, 08:01:52 AM »
Sam. ;)
Looks like it's going to go for good money as it's up to £505 as I write this with a day and a bit to go. I won't be trying to but it back by the way, common sense has prevailed. For those interested the original price of the blower was $1400 which included the nose drive and fuel pump drive at either end, pulleys (22T & 25T) and drive belt, idler pulley (belt tensioning, for the use of), manifolds and the Hilborn fuel pump and injectors. There was also an extra bit for the for the plenum chamber which I bought separately at a slightly later date. The R. C. Golden  Rods were about 500, not sure if that was USD or pounds sterling. The top end of the motor (including the block) came out at about £300 second hand. I forget what the cost of the crankshaft was with its extension pieces at either end, but there was a spare one as well. The magneto was about £100. All prices at 1979 rates. So there you have it. Somebody is going to get a very good supercharger as its basically NOS, not quite as efficient as the modern screw type superchargers, but a gem non the less. They are also going to buy themselves a lot of work.
Cheers
Eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
Offline H2Eric
« Reply #12 on: March 10, 2011, 08:48:01 AM »
Just learned that the spare crank has been thrown away!!!!! Would you believe it. Seems the rest of the bike went the same way, probably in the skip. Lets hope what's left finds a better home.
Eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
Offline BLUE71TURBO
« Reply #13 on: March 10, 2011, 11:59:55 AM »
 Doesn't do any of us here in the states any good.   :(    Local pickup only.   :'(
Offline Jim F
  • go baby go
« Reply #14 on: March 10, 2011, 12:47:05 PM »
we can get Sam to put it in the over head on his way over to the states
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline MasterChief750
  • Detonation
« Reply #15 on: March 10, 2011, 03:12:01 PM »
might be cheaper to ship it with the price of extra bags
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
Offline Steel Dragon Performance
    • Steel Dragon Performance
« Reply #16 on: March 10, 2011, 04:54:08 PM »
Hey Eric, what time did that run?
  • Moderator
« Reply #17 on: March 10, 2011, 06:30:55 PM »
Hey US Stig, ;D It's to late anyway, I'm here :D :D :D
Sam. ;)
  • Moderator
« Reply #18 on: March 10, 2011, 06:37:38 PM »
He did say in Q&A that he would ship anywhere, so get yer bid in :D
Quite supprised there have een no bids in today, It's 2.35 am back home, I shoud have been in bed hours ago. :D :D :D
Sam. :D
Offline Big Jay
    • CBRzone
« Reply #19 on: March 10, 2011, 09:44:06 PM »
Which Magnuson blower is that? 80 C.I. or the 110?
Offline H2Eric
« Reply #20 on: March 11, 2011, 04:58:08 AM »
80
Spoke to Paul the current vendor yesterday, he will ship anywhere at cost, so get your bids in folks.
Cheers
Eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
Offline wannaby
« Reply #21 on: March 11, 2011, 04:52:23 PM »
I whant it .... dont know what ill do with it... mayby make a coffee table out of it.
Offline wannaby
« Reply #22 on: March 11, 2011, 05:01:02 PM »
Anybody have any idea how the chopped off part of the tranny was sealed looks like the same procces as the old midget racer motors.....I am trying to collect picks of these older motors any help apreciated...Den
Offline Big Jay
    • CBRzone
« Reply #23 on: March 11, 2011, 07:18:27 PM »
Probably the same way as the TQs
Offline wannaby
« Reply #24 on: March 11, 2011, 07:51:59 PM »
Ya kinda figgered that BJ got any leads on pictures of cut down motors .I have scoured the TQ midget pages and noting out there ....guess it is because they were around before the net was .... must be lots of old motor picks hidden in dusty albums in basements or attics.D
