Author Topic: Steering Stem Damage, Am I Screwed?  (Read 3442 times)
Offline Analysis
« on: March 17, 2011, 12:47:37 PM »
Hi guys,
I was using my dremel to remove the race on the steering stem, I didn't realize I was cutting into the steering stem until it was a bit too late. My question is, how much damage is too much damage? I've tried to take some pictures but the camera wouldn't focus.
Offline Roach
Re: Steering Stem Damage, Am I Screwed?
« Reply #1 on: March 17, 2011, 12:54:19 PM »
to play it safe i would consider any damage too much damage with what looks like a deep gouge in the stem i know i wouldn't ride it that's just asking to crack under the stresses of riding.IMO
1978 CB550K Cafe Racer
« Reply #2 on: March 17, 2011, 01:18:30 PM »
Pretty fuzzy pictures.
I expect replace is best, though.
Offline Analysis
« Reply #3 on: March 17, 2011, 01:36:07 PM »
Thanks, that's what I was fearing. If only I hadn't had it cleaned and coated... The gash is about 2 mm deep.
Offline lone*X
« Reply #4 on: March 17, 2011, 02:42:19 PM »
Playing the devils advocate here so everyone take this with a grain of salt.  Couldn't you weld a small bead across the gash then file it down to contour?  The penetration of the weld wire into the stem would remove any stress points from it being cut and the amount of heat required would be minimal.  As long as the contour is correct the race would cover any minor irregularity.  Trying to think outside the box.  OP has already put a quite a bit into refurbishing the part.  Pity to waste it IF it would be safe.
« Last Edit: March 17, 2011, 02:43:51 PM by lone*X »
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline Analysis
« Reply #5 on: March 17, 2011, 02:51:07 PM »
Thanks, I'm going to try and use it - it's an hour drive to go get another one from a parts store.
Offline Roach
« Reply #6 on: March 17, 2011, 02:53:31 PM »
where are you in van and what store do you go to?
Offline Analysis
« Reply #7 on: March 17, 2011, 02:55:35 PM »
Bent Bike (http://www.bentbike.com/). Is there another closer? I'm in New West. You?
Offline Roach
« Reply #8 on: March 17, 2011, 02:57:13 PM »
tsawwassen and bent nike is the only place to go good guys
Offline Analysis
« Reply #9 on: March 17, 2011, 02:57:57 PM »
What's in tsawwassen?
Offline Roach
« Reply #10 on: March 17, 2011, 03:01:51 PM »
im in tsawwassen ...lol and bent bike is the only place to go.....there is a place in poco i think but i hear the guy is a douchebag and jacks his prices for rusty parts way up
Offline Kong
« Reply #11 on: March 17, 2011, 04:29:35 PM »
That's no problem at all.  Knock off any burs that are sticking up with a flat file and put your tapered bearing on it.  It is not any sort of safety hazard and it will not do a thing to harm your steering - safe as mother's milk.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline camelman
  • Man... Myth... Legend
« Reply #12 on: March 17, 2011, 05:33:29 PM »
I have a few thousand miles on a stem with the same cut. No worries. That piece is made of steel which is very forgiving in low cycle fatigue, and that part doesn't flex much. In fact, it hardly flexes at all and mostly provides strength in shear at the outer edge of the bearing races, which it is totally oversized for.
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline Analysis
« Reply #13 on: March 17, 2011, 05:38:24 PM »
Alright! I've got it in the freezer and we'll see how it goes!
« Reply #14 on: March 18, 2011, 11:47:25 AM »
I hope you provide full disclosure when you go to sell it.
Offline Analysis
« Reply #15 on: March 18, 2011, 05:01:25 PM »
I don't see myself selling it as it's my first rebuild/restore.
