Hey Jamie! Can I buy you a beer??? Thanks very much for this info as it is VERY HELPFUL to say the least!!
Your measurements are exactly what I needed. The 7" spread on your forks is exactly how I measured mine which are 3/16 farther apart. The spacer is exactly the same... Thanks again! You have above and beyond!
Now it's very obvious that my axle assembly is fine.
I believe my forks are straight because when I spin them in the triple tree "TT", the spread at the forks studs remains unchanged. I will take them apart and roll them as a last resort but I think I need to look closer at the triple tree.
MCrider and MarkM have pointed out the TT may be the problem...
Insert Quote
Could the yokes/triple clamps be twisted?
I would slacken off the bottom yoke pinch bolts, and the end caps holding the spindle and bounce the front end to square it all up.
If the yokes are twisted then the gap between the fork ends will be larger than if the whole setup is square.
End Quote
I am going to take a closer look at the TT and the steering stem and yokes for obvious reason that these members have posted. The steering stem clamps seem to be lined up nicely with the yokes as the fork tubes slid right in without binding. Even 1/16 out of alignment in these could result in 3/16 at the fork leg couldn't it.
Is there any adjustment in the steering stem or yoke clamps that would me to align things better?? MarkM mentioned bouncing the front end to settle everything in to square...
