Author Topic: Float hinge pins didn't survive  (Read 1890 times)
Offline skypilot44
  • Wife says I'm a legend in my own mind
« on: March 10, 2011, 12:15:47 pm »
Hey guys - guess I'm not the first to sacrifice float hinge pins on a rebuild. Like to think I did a fair amount of searching and have been unable to find just hinge pins for a 1975 cb550K 022A carb set. Gotten lucky in the past - hope my luck hasn't run out. The FAQ's show lots of great info up until I need to get new pins. Any thoughts appreciated.
 Stu
Re: Float hinge pins didn't survive
« Reply #1 on: March 10, 2011, 12:27:45 pm »
they're brass.
couldnt you make your own for a few pennies   ???
dont recall the OD, 1.5mm?
lots of hits come up on the interwebs...
« Last Edit: March 10, 2011, 12:35:43 pm by flybox1 »
« Reply #2 on: March 10, 2011, 12:30:14 pm »
they're brass.
Yeah, brass stock from a hobby store? They use it for making toy car frames etc. A hardware may even have it, though may not be as small as the hobby stuff.
Offline skypilot44
« Reply #3 on: March 10, 2011, 12:36:44 pm »
Both excellent ideas. I'll have to mic out the size and go hunting. Thanks
« Reply #4 on: March 10, 2011, 12:38:28 pm »
Offline Queeg
  • insane fuel junkie
  • OY! with the poodles allready!
    • Queegs Problems
« Reply #5 on: March 10, 2011, 03:01:16 pm »
I used brazing rod I had at my shop. If you know a welder give him a shout. I have bronze in one bike and stainless in the other bike. No problems with either.
guess who?
Offline RatBikeRandy
  • Yes I Can
« Reply #6 on: March 10, 2011, 03:55:37 pm »
I used a piece of coat hanger wire 4 years ago - no problems and REAL cheap.
Offline Bodi
« Reply #7 on: March 10, 2011, 04:00:59 pm »
I think those pins are steel. I've used a drill bit the right size, just ground off the drilly part and used the solid shank.
Offline faux fiddy
  • bike in a box
« Reply #8 on: March 10, 2011, 09:29:15 pm »
+1
they're brass.
I think the ones on the 350f are 2mm. 550 might be the same, but worth checking for sure.
If anyone is sucessful at finding brass stock in metric sizes, let me know. One set of carbs I have  came with  some clipped off finish nails that are sloppy loose.
« Last Edit: March 10, 2011, 09:31:53 pm by tree fiddy of industry »
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
« Reply #9 on: March 10, 2011, 09:49:22 pm »
Flyboxes link above is metric. Shouldn't be a problem.
« Reply #10 on: March 12, 2011, 02:00:27 am »
16126-259-004 is the honda part number $2.42 each at Dave Silver
« Last Edit: March 12, 2011, 02:02:01 am by bryanj »
Offline MoMo
  • Ride like you're invisible
« Reply #11 on: March 12, 2011, 03:35:49 am »
Me too, still working well....Larry
