Author Topic: K&N air filter - stock airbox - jetting differences ?  (Read 1556 times)
Offline greenjeans
  • 1972 CB750K2
« on: March 12, 2011, 10:12:53 AM »
Yes I've searched :).  Finding mostly answers dealing with pod filters.
75 CB750K  (back from a 15 yr hiatus)   stock 4 into 4 exhaust.  Stock airbox.
About to order a ton of carb parts & was thinking of adding a K&N filter as I can find those for just a bit more than the stock Honda filter.
K&N's site claims that no changes in stock jetting are necessary.  Seem like I remember reading something to the contrary.   Can't remember if it's for pods or a "stock style" filter.
Anybody know for sure before I order new jets ?
« Last Edit: March 12, 2011, 10:14:57 AM by greenjeans »
Offline Old Scrambler
Re: K&N air filter - stock airbox - jetting differences ?
« Reply #1 on: March 12, 2011, 10:27:17 AM »
My K3 came with 105 mains...........I switched to 120s and a K&N filter in my stock box with 4 1/4-inch extra holes drilled into the bottom.  Now run stock exhaust with caps.........seems to be just fine.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline dhall57
« Reply #2 on: March 12, 2011, 10:43:16 AM »
Hey greenjeans, The PO of my 750K6 put a Mac 4 to 1 on it. Im sure when this was done the jets had to be changed to work with the  Mac set up instead of the factory pipes. My A/F box is all stock. I have no idea what size jets mine are, but I recently replaced my stock air filter with a K&N and have not changed anything. The bike honestly seem to run and breath a little better. The K&N was for sure worth the extra money.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline KeithB
« Reply #3 on: March 12, 2011, 03:17:49 PM »
I have a '72 750K and replaced the air filter with a KN and kept the stock jets.
No problem.
I do think the '72 ran a bit rich anyway....
Nanahan Man
« Reply #4 on: March 12, 2011, 03:45:17 PM »
These days, you have to ask if ethanol is involved.
The K&N reduces the carb throat vacuum slightly. (Makes it slightly leaner.)
Gasohol also make the ratio leaner.  Less energy in alcohol/per unit volume.
A more open exhaust will improve scavenging so a more air and fuel are needed.
Depending if starting from stock configuration, no changes are needed for the K&N.  Add some other things, maybe so.
Offline greenjeans
  • 1972 CB750K2
« Reply #5 on: March 13, 2011, 11:06:43 AM »
Just what I needed.  Thanks, fellas.
