If your cylinders are not perfectly round, then re-using the rings will likely cause a poor seal. This is because the rings will be worn into the oval form of the cylinder in one orientation. If you take the pistons out, then the rings are going to rotate, and you'll never get them back to the exact position they were in prior to dismantling. The result will be a square peg in a round hole issue, although not quite as noticeable.
If your cylinders are perfectly round, then no issues and your rings will seat back in with a little honing. If they are not perfectly round, then you might not get as good of a seal as you are hoping for, more blowby, and some degree of lower power.
Camelman
