Author Topic: Drive Rivets for VIN Plate  (Read 5071 times)
Offline Accolay
« on: March 15, 2011, 06:05:28 AM »
I need to get some. How much should I be worried about what type of metal the rivets are made of to prevent electrolytic corrosion? Just get steel coated zinc? Or just go with the 3M double sided sticky tape?
1977 CB550F
Offline drones76
Re: Drive Rivets for VIN Plate
« Reply #1 on: March 15, 2011, 06:40:51 AM »
Here is a discussion that may help.  I would not use a double sticky tape.  If it falls off you are in for a hell of a problem if and when you are inspected or want to sell it.
http://www.hondatwins.net/forum/viewtopic.php?f=13&t=5541&p=49155&hilit=vin#p49155
1974 Norton Commando Roadster
1980 Goldwing Interstate
1975 Kawasaki KZ400D
Looking for a SOHC-4
Hinomaru
« Reply #2 on: March 15, 2011, 07:07:21 AM »
The correct data tag rivets are size 1.5 x 5.0 mm and the Honda part number is: 90841-001-000
Other rivet sources can be found in this old thread:
http://forums.sohc4.net/index.php?topic=29686.0
The 1928-31 Model A rivets will also work in a pinch:
http://www.snydersantiqueauto.com/ModelAParts/DataPlates/3327?partnumid=
« Last Edit: March 15, 2011, 07:11:00 AM by Hinomaru »
« Reply #3 on: March 15, 2011, 11:00:30 AM »
Last time i wanted them Honda still had stock
Offline Accolay
« Reply #4 on: March 15, 2011, 12:20:29 PM »
Thanks for that part number. Why are these not available from Honda in the United States? "Not Available."
CMSNL has them, but I have to make a minimum 10 Euro purchase. David Silver is out of stock. Does anyone know what the originals were made out of/plated with? I think I can get them at Fastenal in either zinc/steel or stainless steel. Does that matter?
1977 CB550F
nomad
« Reply #5 on: March 15, 2011, 12:34:14 PM »
I've got a whole box of these... http://www.mcmaster.com/#91654a077/=bg3npl
Part Number: 91654A077
Nail Type: Easy-Drive
Easy-Drive Nail Type: For Sheet Metal, Plastic, and Plywood
Material: 18-8 Stainless Steel
Finish/Coating: Plain
Decimal Size: .100"
Number Size: No. 2
Head Type: Oval
Shank Type: Spiral
Head Diameter: .162"
Head Height: .069"
Recommended Hole Size (Drill No.): .086" (44)
Length: 1/4"
Box Quantity: 100
Specifications Met: Not Rated
Note: Length is measured from under the head.
PM me your address and I'll mail a couple of them to you if you want them.
Offline markb
  • When I finish my current project I might be a
« Reply #6 on: March 15, 2011, 02:42:47 PM »
That's what I use, they work great.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline Kong
« Reply #7 on: March 15, 2011, 02:57:52 PM »
Not really.  That plate is not the official frame serial number.  Look on the other side of the neck and you'll find the real number - which should match the riveted plate - stamped into the metal.  Now if that number is missing (ground off or welded over) , then you have a problem.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
