Poll
Tube or tubeless
tube
8 (88.9%)
tubeless
1 (11.1%)
Total Members Voted: 9
Author Topic: Lester guys  (Read 1631 times)
Offline Ryan6838
Lester guys
« on: March 16, 2011, 08:29:08 PM »
So Im about to put the new tires on the lesters i picked up, my question is should i run tubes or not. I know there listed as tubeless but people have said they dont have a shoulder like most tubeless rims. Is it safer to air on the side of caution and run tube or go without them. What are you guys running lesters doing?
1978 cb750k
Offline MoMo
  • Ride like you're invisible
Re: Lester guys
« Reply #1 on: March 16, 2011, 08:33:18 PM »
I put tubes on the K1 I restored that had Lesters, mostly for piece of mind...Larry
Online scottly
Re: Lester guys
« Reply #2 on: March 16, 2011, 08:40:06 PM »
Are your Lesters marked "TL"?
Offline MoMo
Re: Lester guys
« Reply #3 on: March 16, 2011, 08:50:22 PM »
sorry, the bike is long gone as it was a job for a customer...Larry
Offline Ryan6838
Re: Lester guys
« Reply #4 on: March 16, 2011, 08:52:43 PM »
Yeah there marked tl indicating tubeless. in the lester section of faq they also say the t and tl wheels look the same. just want to check and see if it was a better idea to just run tubes or not.
1978 cb750k
Online scottly
Re: Lester guys
« Reply #5 on: March 16, 2011, 08:59:35 PM »
BTW, I have a set of Morris-clone Kawi wheels, which are clearly marked tubeless, and I didn't notice any difference in the bead seating area from my genuine Morris wheels, marked "TL". I plan on doing a better comparison, with both wheels side-by-side, as soon as I can...
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: Lester guys
« Reply #6 on: March 16, 2011, 09:39:48 PM »
Tubes in mine.
Offline jaguar
Re: Lester guys
« Reply #7 on: March 16, 2011, 10:18:49 PM »
tubes in mine
Re: Lester guys
« Reply #8 on: March 17, 2011, 09:34:48 AM »
As far as I know the difference is..
 a small raised bump on the rim surface, just inboard of where the bead sits when inflated.. keeps the bead from popping off (inward)..in cases of low inflation.
Offline Ryan6838
Re: Lester guys
« Reply #9 on: March 17, 2011, 04:44:03 PM »
thanks for the replys guy and the info. id never seen them side by side. Tubeless would be nice to run an angles air stem to make things easier on the 16in rear.
1978 cb750k
Offline wildcatmahone
  • Poseur
Re: Lester guys
« Reply #10 on: March 17, 2011, 05:04:21 PM »
I own a cherry set of  Lesters that I will be running on my CB750 . Until I see an info sheet from LESTER saying directly that they can be run tubeless I will be running them with tubes. I have heard from a handful of guys that they have run them tubeless with no problems but not buying it. Really when it comes to your wheels and tires it's your ass on the line so I like to be 100% sure or nothing. So yeh +1 on tubes.
Happy Paddy's Day
-Wildcat
Offline backwoodsman
Re: Lester guys
« Reply #11 on: March 17, 2011, 05:05:40 PM »
Tubes in mine speedo goes to 150 then stops a little after im still here.
Offline Ryan6838
Re: Lester guys
« Reply #12 on: March 17, 2011, 05:21:53 PM »
well maybe ill just run tubes to be on the safe side lol
1978 cb750k
Offline SKTP
Re: Lester guys
« Reply #13 on: March 17, 2011, 05:41:20 PM »
I am running tubes
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline MoMo
Re: Lester guys
« Reply #14 on: March 17, 2011, 05:57:34 PM »
Back in the 70's when the Lester wheel first came out, no one I know trusted "tubeless" so we all puts tubes in when we did a conversion.  That is why I put tubes in the bike I did...Larry
Offline tmac
Re: Lester guys
« Reply #15 on: March 18, 2011, 12:06:04 AM »
T U B E S !!
Re: Lester guys
« Reply #16 on: March 18, 2011, 07:27:58 AM »
 Why stop at a tube..??.. moght as well run a rimstrip to make doubly sure....
 A buddy of mine ran tube-type Goodyears.. tubeless on his Morris mag for years..
 i have a 17 inch wire wheel here that says tubeless on it..
Online scottly
Re: Lester guys
« Reply #17 on: March 18, 2011, 07:33:43 PM »
I pulled the tire off the Kawi tubeless rim, and there is no raised bump. In fact, I placed a straight edge across the surface, and it slopes down slightly towards the center. When I pull the tire off the Morris, I'll make sure it is similar before I decide to run tubes or not. I'm really hoping I don't have to. What do tubes cost these days? This could be the first time for me an 8 pound weight reduction took zero labor, and saved money!! :) :)
