Hi all,
I recently traced a "no crank" condition to the starter gear popping up out of mesh with the gear set that drives the crank shaft (and then wedging against it out of mesh). I removed the starter and noticed a lot of end play in the starter gear. I looked at some online parts outlets but did not see a starter nose bushing. Anyone here ever run into this situation? Were you able to find a replacement bushing?
Thanks,
Rob
