Author Topic: CB350F Carb Rubbers - Where to buy?  (Read 953 times)
Offline gsand
« on: March 22, 2011, 02:27:49 AM »
Hi there SOHC,
I've looked around through google a bit and my usual stores (Z1, old bike barn) and I cant track down these.
I've yet to try HONDA but will ring tomorrow and expect a high price.
To Clarify the rubbers that bolt to the head and then hold the carbs
My current ones are crusty and hard as rocks.
My other option is make some flanges from flat steel with some tube welded - then just use a piece of straight hose to attatch the carbs to
Thanks in advance.
« Last Edit: March 22, 2011, 02:43:22 AM by gsand »
Offline tortelvis
Re: CB350F Carb Rubbers - Where to buy?
« Reply #1 on: March 22, 2011, 06:18:43 AM »
Check out the many threads on restoring hard rubber in the tricks and tips page.
« Reply #2 on: March 22, 2011, 07:10:30 AM »
Anything other than original connectors will change the pressure in there...and tuning will be required.
search WINTERGREEN and read the threads on rubber restoration. if yours arent cracked, they should come back.
or...hope something comes up on ebay, softer than what you've got.
Offline gsand
« Reply #3 on: March 22, 2011, 08:31:04 AM »
Thanks for info. Ive seen some of the info on restoring the rubbers.
I'm from Australia so I will have to find a substitute for Wintergreen.
Mine are not cracked, but I Had to pry at them to get the carbs out of them, hopefully I haven't caused any damage
Thanks alot
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #4 on: March 22, 2011, 09:14:44 AM »
David silver in the Uk has them in stock.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline -CB-Jamie-
« Reply #5 on: March 22, 2011, 09:26:30 AM »
+1 on David Silvers if you want new ones, they're reasonable on postage too.
Carb rubbers for 1 and 4
Carb rubbers for 2 and 3
72 CB350/4
76 CB400/4 CB400f "Project Resurrection"
77 CB550/4 1977 CB550 Yet Another Cafe
77 cb200
09 cbf600
