Poll
  Oil leak around head gasket; Would you:
Ride it until it gets REALLY bad
Go ahead and buy parts to fix it this Winter
Don't touch it...you'll screw up something
555cc, baby!
 Try the tampon trick
Author Topic: Stopping top end oil leaks: Worth it?  (Read 12680 times)
Offline ak58lp
Re: Stopping top end oil leaks: Worth it?
« Reply #25 on: March 31, 2011, 09:08:24 AM »
Man, what a bummer!  Maybe one of the o-rings shifted and got pinched.
MJ
Someone suggested re torquing the head but I can't see how that will work. I really don't want to spend another day to tear it down and then the time to zip it back up. I think it's sadly time to move on.
My Bike - 2001 Honda ST1100
Wife's Bike - 1982 650 Nighthawk
Offline ak58lp
« Reply #26 on: April 09, 2011, 06:08:32 PM »
Just thought I would post a happy update to this.
Major headache came last week when I took it out for a ride and had oil blast out of the same place on the OTHER side of the bike.   At this point I was ready to give up but my friend told me to check the head bolts again. I thought there was no way they could back out as I had them to book spec torques and also LocTite on them. I removed the rocker head and checked them from inside to the outside by the book. All were tight...oh no...
Then I got to the 2 bolts right above the leak and got at least 2 more turns on them before I hit the torque value.
I can only think that I torqued them all to half the spec then did the others and forgot these 2. Anyway the wife and I went about 300 kms today and everything is dry.
I guess the total cost for new head gasket, O-rings, all new gaskets, relapping valves and new valve seals to be under $200.
Offline eworth
« Reply #27 on: April 09, 2011, 06:36:34 PM »
Bought my CB550 last fall.  Had the oil weeping mentioned.   I paid someone to do it right.  Glad I did.   It was worth the peace of mind for me to have it done.  But others wouldn't mind a bit.  It depends on finances and intent for your ride.
