Author Topic: Is my bike going to explode/implode?  (Read 5145 times)
Offline hcritz
Re: Is my bike going to explode/implode?
« Reply #25 on: April 11, 2006, 08:29:24 AM »
Good Deal...
Nice when it's something simple!!!
Offline techy5025
  • 1969 Diecast and Sandcast 750's
« Reply #26 on: April 11, 2006, 08:24:52 PM »
Not to beat a dead horse....but pairs of plugs fire at the same time
as the ends of the coil secondaries are tied to two plugs.....inners and
outers. I would think that removing a plug wire would open the secondary
path and kill the other plug.   ???
.....unless of course by holding the plug wire you are completing the path. ;D
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
Offline Lumbee
    • My pics...
« Reply #27 on: April 12, 2006, 07:41:24 AM »
...hey heavy, on the racing idle, you said you synced the carbs...did u use a sync gauge or just bench sync?  My 78K carbs raced like that after I rebuilt them, and I finally adjusted the needles down, and that will bring the idle down.  As someone mentioned, you need to get yourself a sync tool to do it right.  That will also help with the slow return to idle...
"I'm not a welder, but I play one on HondaChopper.com"
Offline hevykevy420
« Reply #28 on: April 13, 2006, 07:20:27 AM »
I did use vacuum gauges to synchronize the carbs.  I couldn't get each carb exactly perfect, compared to the #2 carb, as it seemed like if I adjusted one carb, it would change the setting on a different carb.  I was able to get them all pretty close though, and called it good and put everything back together.  I'm not sure why, but on the gauges the readings were around 5 at idle, and in this range on the gauges it says "check for vacuum leaks".  Should my readings have been higher????
Its just that when  I rev up the engine, sometimes I have to push hard forward on the throttle to bring the engine down to idle speed.  I"ll have to investigate some more...check for manifold leaks..etc.  I lubed the return cable and the cables seem good so I don't think its poor cables, but maybe I should just replace them to be sure.
1978 CB750K - 836 Wiseco kit, 4-1 Kerker Exhaust, Web cam (63b grind), HD valve springs, polished stuff.  Comfortable.
1975 BMW R90/6 - tight
2002 RC51 - Jardine slip ons.  Uncomfortable.
Austin, TX
Offline hcritz
« Reply #29 on: April 13, 2006, 07:28:12 AM »
Do you have any slack in the throttle cables???
Should be a little....
« Reply #30 on: April 13, 2006, 08:04:00 AM »
 You should check for vacuum leaks . If you are using the original intake boots(manifolds) you are probably sucking air which will jack your idle up.
Offline kaceyf2
« Reply #31 on: May 02, 2006, 07:01:47 PM »
HEY I GOT AN IDEA THAT MAY HELP BRO, i cant because its daft i am in the uK, but maybe someone will LISTEN TO YOUR NOISE OVER THE PHONE, diagnosis,is best done with the bike, but it may help....
In my own experience...
It wasn't a Previous Owner who didnt know what he was doing that messed up your bike, it was The Previous owners mate who THOUGHT that HE did.
