Author Topic: New project for a first timer CB550 build - Slowly getting back to it!  (Read 171641 times)
Offline Bankerdanny
  • Endeavor to persevere
Re: New project for a first timer CB550 build
« Reply #125 on: September 03, 2013, 02:53:14 PM »
It looks right to me.
Offline bambuhiphop
« Reply #126 on: September 03, 2013, 02:56:23 PM »
Offline bambuhiphop
« Reply #127 on: September 03, 2013, 10:48:49 PM »
Rear Hub all test fitted together. Turned out good I think. All set to be installed after some loctite.
« Last Edit: August 12, 2015, 10:28:55 PM by bambuhiphop »
Offline MoMo
  • Ride like you're invisible
« Reply #128 on: September 04, 2013, 04:50:29 AM »
You forgot the spokes :P
Offline bambuhiphop
« Reply #129 on: September 04, 2013, 07:27:03 AM »
Spokes are overrated. I'm going to go with paper mache  ;)
No. Spokes are sitting on the shelf. Just waiting to get the rims from Buchanan and then they will be whole.
« Reply #130 on: September 04, 2013, 10:42:57 AM »
I think it would be easier to assemble spoke the hub with sprocket off and then install sprocket and carrier after the wheel is built up.
Offline bambuhiphop
« Reply #131 on: September 04, 2013, 10:48:36 AM »
Oh, I know. It will be coming off before I lace and true. I wanted to dry fit everything after stuff got powdered and ensure fit was correct before I got to far into the wheel.
Offline bambuhiphop
« Reply #132 on: October 10, 2013, 09:25:07 AM »
Hello Again  :) Haven't posted in a bit cause I haven't been able to much on the bike this last month. Had some other time and money commitments that had to come first. My time is opening back up and the bike budget should be following suit shortly.
In the meantime I was able to do a few smaller items:
- I re-threaded one of my fork lowers
- I did get a keyless ignition system
- Working on a new wiring setup and diagram
- Installed the battery so I can test my wiring when I start running it.
- Installed some new bolts
- Prepped my brake arm for install
- Worked on the bars and controls. I drilled out the left side of the bars and in the center. Modified my left hand switch so wires would route better. Pulled wires through the bars. Mounted everything on the left and then the throttle on the right. Decided to remove the Stop/Run switch on the right side. So no drilling on the right!! Going with a different push start mounted elsewhere.
That is about it for now. Just needed to post something. Helps it feel like the project is moving forward  ::)
« Last Edit: August 12, 2015, 10:29:45 PM by bambuhiphop »
Offline jude0007
« Reply #133 on: October 10, 2013, 02:07:58 PM »
Sorry if you mentioned this in a previous post but what is that LH handle bar control? Or where did you pick it up?  I like it a lot.
76 CB550
79 CB650
75 CB400f
71 CL350 Scrambler
63? CA95
Offline FastCB550
    • Classic Honda Bulletin Board
« Reply #134 on: October 10, 2013, 03:03:30 PM »
Nice progress and build. Thanks for taking the time to share the updates with us!
1978 - CB550
600cc Overbore, Velocity Stacks, 4 into 1 Carpy Exhaust, Seat & Electronics by Kott Motorcycles, PD46C Carbs with 42 idle jets and 115 mains.
www.HondaBB.com
Offline bambuhiphop
« Reply #135 on: October 10, 2013, 03:25:58 PM »
Offline bambuhiphop
« Reply #136 on: November 11, 2013, 11:11:07 AM »
Man, haven't had time to work on the bike this past month let alone post anything. Budget opened up a little but no new major part purchases. I did track down a new headlight bucket. Decided to not mount the right hand controls. Going to eliminate it. Planning on mounting a Start/Stop switch under the tank.
I finally got out into he garage to work though. Man it was nice!! Decided to work on getting the case split. Finally got the last seized screw out. Had to order a stud removal tool from APE cause heat, PB Blaster, and vice grips on go two of the studs out. Unfortunately it wasn't all puppies and kittens. Two studs sheared off so I will be taking the top half to a machine shop to have them removed.
Also a not so good thing was a piece of the bottom part of the block broke out by the point mount. So the bottom half will be joining the top to the machine shop for some welding.
So while I had some hiccups I did get the case split  :D
So next step is to remove the primary shaft and then I start the cleaning!
« Last Edit: August 12, 2015, 10:31:36 PM by bambuhiphop »
Offline bambuhiphop
« Reply #137 on: January 29, 2014, 07:50:26 PM »
Was able to pick up a few parts amidst the house projects that I have had to work on. Hopefully the house will behave for a little bit now.  ::)
After awhile at the platers I got my headlight bucket ears, rear axle, and rear adjusters back. I had them finished in a brushed chrome. I really like the way they turned out. Went ahead and got the pieces dry fitted on the frame.
Started playing with height ideas on for the headlight. Also put the lower fork caps on.
Also, got the front hub dry fitted:
Received a very cool custom piece for my rear taillight that will fit under the seat cowl. Didn't have the "flex" as the plastic piece so I made some cuts. Going to weld up some panels to it aped probably have it powder coated. Then I can work on the rear piece of the seat for the finished look.
Totally scored on a new cam. Picked up a Yoshi B grind cam this weekend. It's gonna rock when the engine is all said and done.
And lastly couldn't help but snap a pick of its current state. Still a ways to go but it is kind of starting to look like a bike again :)
« Last Edit: August 12, 2015, 10:34:49 PM by bambuhiphop »
Offline bambuhiphop
« Reply #138 on: January 30, 2014, 08:03:14 AM »
One word of advice through, not sure that wire hangar is rated for the HP the new Yoshi cam will deliver. Might want to double-check your structural design there. Just saying...  ;)
What? You don't like my super high tech copper romex shocks?? They are rated to a million horsepower each!!! But have zero rebound ;)
Offline redrider736
« Reply #139 on: January 30, 2014, 06:10:48 PM »
Got two parts in the mail today. That's about all I have to share. Been super busy at work...
LED turn signal flasher
Great Build thread !!!! Can I get a bit of info on this ^
78' CB550k (Not Run'n / Basket Case Project)
77/78 cool 2 member #269
Offline bambuhiphop
« Reply #140 on: January 31, 2014, 10:11:55 AM »
Thanks. That is a LED flasher I got from SuperBrightLEDs. I am running all LED's for signals and taillight and didn't want to run load resistors so I picked this guy up. I used a different model flasher before in my old FJ60. Worked just fine. Here is the link.
http://www.superbrightleds.com/moreinfo/motorcycle-accessories/lf1-s-flat-universal-motorcycle-electronic-flasher/787/842/
Offline redrider736
« Reply #141 on: January 31, 2014, 10:45:56 AM »
Thanks for the info and link.... much needed
Sent from my GT-P5113 using Tapatalk
Offline minimo
« Reply #142 on: January 31, 2014, 01:17:35 PM »
Bambuhiphop, all looking clean. Nice progress. Your 550 is looking more like a bike than mine.
Offline bambuhiphop
« Reply #143 on: February 01, 2014, 10:01:51 PM »
Thanks man. Going slower than I would like (really want to ride this thing) but it will be done when it's done.
Offline bambuhiphop
« Reply #144 on: February 01, 2014, 10:10:23 PM »
Was able to get the engine disassembly finished. Got the remaining gears, bearings, and shift drum out. Now just need to do a little machine work to remove two broken studs an reweld the piece that broke off.
Did have two questions hoping some folks can chime in on for me.
One. I saw these little "cracks" on the underside of the top case by the cylinder holes. On 1 and 4. Anything to be concerned about or research further?
And Two, any suggestions for prep work on the case with it being split for media blasting? Tape anything off or just blast everything?
« Last Edit: August 12, 2015, 10:36:14 PM by bambuhiphop »
Offline WhyNot2
  • I'm finally an
« Reply #145 on: February 02, 2014, 07:22:01 AM »
I'm following, I loves 550s.
Wish I could find a basket case.
You are doing a great job on this one.
Offline bambuhiphop
« Reply #146 on: February 02, 2014, 08:29:29 AM »
thanks calj737.
I am familiar with soda blasting. Just haven't ever had it done because no one local to me does it. I will look into doing myself. Don't know why I hadn't thought about it. Thanks for the idea!
Luckily I do have a powder coater local to me that will let me use there oven for high temp paint so I just need to decide if I am going to high temp paint or powder coat next.
Offline jtran000
« Reply #147 on: February 02, 2014, 10:34:19 AM »
lovely work sofar!  what gasket kit are you getting for the motor?
Offline bambuhiphop
« Reply #148 on: February 02, 2014, 03:34:23 PM »
Thank you. So far I have been eyeballing a kit from Dime City
http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-engine-parts-honda-cb550-engine-gasket-set-16-6112.html
But I haven't done as much research as I should so it's not set in stone.
Offline bambuhiphop
« Reply #149 on: February 02, 2014, 03:36:44 PM »
Appreciate that. I love my basket case. Was lucky to have found it when I did. They are very hard to come by in any shape in my area now.
