The reason I started playing with rearset bracket ideas is that I picked up a set from CognitoMoto. The quality is great. They do however require some cutting of the frame. Not really a big deal unless you have an already powder coated frame, say like me
![Undecided :-\](http://forums.sohc4.net/Smileys/default/undecided.gif)
So after a few days of research and soul searching I decided to cut! So nerve racking
![](http://bambuproductions.com/images/CB550/framemod.jpg)
I didn't fully remove the stock rear brake setup. My plan is to reuse it as a mount point for an exhaust hanger.
I masked up everything up and painted with a ceramic that matches almost perfectly.
![](http://bambuproductions.com/images/CB550/framemod1.jpg)
![](http://bambuproductions.com/images/CB550/framemod2.jpg)
![](http://bambuproductions.com/images/CB550/framemod3.jpg)
Now, I could have trimmed more done and smoothed out bu the brackets as is really cover 95% of the cuts. If I design my own then they will be 100% covered. I also really did not want to have the frame redone.
Bracket on the left side. Haven't decided on color yet. Think I am going to wait until the engine is in.
![](http://bambuproductions.com/images/CB550/rearset_bracket.jpg)
Also got some other parts in.
Caliper pipe from Slingshot.
![](http://bambuproductions.com/images/CB550/caliper_pipe.jpg)
Spring for the side stand. Not installed yet because man, is that thing a bear! Think I need to get the wheels on the bike so I can apply more force before it is on.
![](http://bambuproductions.com/images/CB550/spring.jpg)
A slew of headlight parts
![](http://bambuproductions.com/images/CB550/headlight_parts.jpg)
Couldn't resist trying the trim on the bike. It is a little too shinny so it will be going off to the chrome shop to have a new brushed finish applied.
![](http://bambuproductions.com/images/CB550/headlight_trim.jpg)
And finally go more of the front wheel together.
![](http://bambuproductions.com/images/CB550/front_assemble.jpg)
![](http://bambuproductions.com/images/CB550/front_assemble1.jpg)
