Author Topic: New project for a first timer CB550 build - Slowly getting back to it!  (Read 142516 times)
Offline bambuhiphop
Re: New project for a first timer CB550 build
« Reply #150 on: February 02, 2014, 03:34:23 PM »
lovely work sofar!  what gasket kit are you getting for the motor?
Thank you. So far I have been eyeballing a kit from Dime City
http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-engine-parts-honda-cb550-engine-gasket-set-16-6112.html
But I haven't done as much research as I should so it's not set in stone.
Offline bambuhiphop
« Reply #151 on: February 02, 2014, 03:36:44 PM »
I'm following, I loves 550s.
Wish I could find a basket case.
You are doing a great job on this one.
Appreciate that. I love my basket case. Was lucky to have found it when I did. They are very hard to come by in any shape in my area now.
Offline bambuhiphop
« Reply #152 on: February 05, 2014, 08:01:43 PM »
Got some new parts from FrankenFrankenStuff
Better mounts for my seat:
And shiny new side covers  8)
Hoping I can get some assistance from someone on the correct grommets for the side covers.
I pulled up pics from my tear down back in 2011 and I'm pretty sure that the covers that were on the bike when I got it weren't original. They were mounted with screws as you can see in this pic:
They were mounted with these little grommets which I though were stock but I can't find them in the parts diagram
So I have no idea which parts I need to mount. I think I need number 17 (qty. 4) and number 66 (qty. 2) yes?
« Last Edit: August 12, 2015, 10:39:02 PM by bambuhiphop »
Offline calj737
  • I refuse...
« Reply #153 on: February 06, 2014, 03:21:42 AM »
Yes, but double check your qtys for both sides.
Offline bambuhiphop
« Reply #154 on: February 06, 2014, 08:26:57 AM »
Diagram really isn't that clear to me. What quantity's do I have off? I am assuming 2 (17 or 17247-303-000) per side for the top mounts (total 4) and 1 (66 or 83551-300-000) per side for bottom mount (total 2).
Offline jason405
« Reply #155 on: February 07, 2014, 08:06:44 PM »
@bambuhiphop
Read through the whole thread. Bike is turning out great! I'm just beginning a 550 project. My first.
I'm curious about the paint you have used on the parts that you didn't have powder coated. I saw you mention the dupli caliber paint, but did you use that on EVERYTHING you didn't have powder coated? No por15?
What general process did you follow when painting all those parts?
Planning on painting most parts myself, so just looking for advise. Love how your parts came out!
Thanks,
Jason
Offline bambuhiphop
« Reply #156 on: February 08, 2014, 02:07:47 PM »
Jason, thanks for reading my thread! Nice to know someone can get something from my learning curve, ha!
I did in fact originally use the caliper paint on a lot of parts. But in all honesty only a few parts still have that paint on it. Those would be the caliper, the rear brake lever, and battery case. I decided to go with a newer style brake master so that is out of the picture. I also got a new rear sprocket. The front brake arm and rear drum cover I ended up having powder coated.
A few parts I did a crap prep job on the paint started chipping. That was the main reason for replacing or powder coating. But my process was to clean the parts, remove excess paint, spray 2 light layers, and then a heavy layer.
I did just recently read a great thread over on the ton about painting with rattle cans. Some great info in it. I will be adopting some of those practices when I paint my engine.
http://www.dotheton.com/forum/index.php?topic=10993.0
« Last Edit: February 08, 2014, 07:43:54 PM by bambuhiphop »
Offline jason405
« Reply #157 on: February 08, 2014, 07:31:40 PM »
Thanks for the reply! Keep up the great work!
Offline lynnepearce661
« Reply #158 on: February 09, 2014, 02:22:58 AM »
hi
being a collector of 550's and parts, i am loving your rebuild.
where did you get the new sidecovers please?
« Last Edit: February 09, 2014, 02:26:23 AM by lynnepearce661 »
Offline bambuhiphop
« Reply #159 on: February 09, 2014, 08:40:06 AM »
The side covers came from fellow member FrankenFrankenstuff
Here is his website: http://www.fb-stuff.com/fb-stuff-store.html
I also have a points cover from him and the seat mounts are also his. Super easy guy to work with who makes great products!
« Reply #160 on: February 10, 2014, 12:46:17 AM »
Thank you for your reply.   In NZ there are not alot of fours on the road now,  so its nice to know that they are out there.   Cheers and keep up the good work  :)
« Last Edit: February 10, 2014, 01:13:36 AM by lynnepearce661 »
Offline stuartni
« Reply #161 on: February 13, 2014, 07:40:05 AM »
great work so far bike looks ace
Offline bambuhiphop
« Reply #162 on: February 17, 2014, 11:08:08 PM »
Worked on some detail type items the past few days here and there. Been getting thread locker on all the bolts on the front end and cut the spacers for the preload in the forks.
I had ordered a 110/90-18 AM26 tire that was going to go on the back but it felt to skinny to me so I thought about putting it up front. Turned out to be a little wide so it is on its way back and a 100/90-18 is headed my way. This is it mocked up.
My start switch came in last week. Was planning on mounting it under the tank but it was smaller than I expected (pleasantly) and it turned out to fit very nicely up on the triple.
Did a little work on the rear hub and brake. Got the cotter pins in and some thread locker down on a few bolts
Wanted to also share my approach to making sure all parts are put back in the right order. I have so many new parts so this method has helped a great deal. I have printed out the microfilms and I mark the part when it goes on. Pretty simple but as I said has helped me.
And lastly I ordered a front rim last week. Got a 2.15 Sun rim from Buchanan's. Should see it next week with the new tire. Of course I will be away on business but something to play with when I get home. In preparation for that I got the bearing retainer completely on. Gave me a little scare with the threads on the hub but got it cleaned up and it threaded well. Then laid out the inner spokes.
Looking forward to getting the rim and the remainder of the spokes on there. I think the color combo is working out nicely :)
« Last Edit: August 12, 2015, 10:41:26 PM by bambuhiphop »
Offline DustyRags
  • I'm not skilled, I'm just a
  • Just try it and see what happens
« Reply #163 on: February 18, 2014, 07:01:35 PM »
Wow. Found this thread this morning, and I gotta say, you've got talent and perseverance! Excellent work!
In for the follow! Love the 550s :)
1976 CB550K- sold
2005 Kawasaki Vulcan 500- sold
2000 CB750 Nighthawk - sold
1975 XL350 - crashed
2004 Suzuki Vstrom 650 - sold
Offline bambuhiphop
« Reply #164 on: February 18, 2014, 09:34:29 PM »
Thanks Much! It will be done one day. In the words of Dori, "Just keep Swimming"
Offline bambuhiphop
« Reply #165 on: March 01, 2014, 09:55:14 AM »
So when I got home from the business trip this week I had my new front tire and rim waiting for me! Tire is a Roadrider 100-90/18. Rim is a Sun 2.15 18".
Started lacing it up. Not the easiest thing to do in the world. Took me a few try's but after looking at an old picture I was able to get it all laced up. Next up is to true it and seal it so I can get the tire mounted.
Inner spokes on:
One side of outers added:
And all of them on hand tightened:
« Last Edit: August 12, 2015, 10:42:20 PM by bambuhiphop »
Offline calj737
  • I refuse...
« Reply #166 on: March 01, 2014, 09:56:41 AM »
I love the finish on that rim. Is it their standard anodized or a satin?
Offline bambuhiphop
« Reply #167 on: March 01, 2014, 09:58:38 AM »
I know right! Standard finish. Perfect fit for the look I am going for.
Offline minimo
« Reply #168 on: March 01, 2014, 11:45:55 AM »
Great looking wheel! Good idea on keeping track of wheel parts.
Offline 2strokeTrush
  • Can you get that back together sonny?
« Reply #169 on: March 01, 2014, 08:25:51 PM »
Are those carbon fiber look signals from DCC? and Are they Led?
If You Aint First Your Last!!
 350F project-http://forums.sohc4.net/index.php?topic=133079.0
500F Project-http://forums.sohc4.net/index.php?topic=135660.0
Offline bambuhiphop
« Reply #170 on: March 01, 2014, 08:30:05 PM »
Yes and yes. I will more than likely be changing them out though. Style isn't quite turning out how I planned.
« Reply #171 on: March 02, 2014, 07:32:01 AM »
Thanks, DCC told me they weren't LED though so i guess now i have to buy a LED relay like you did.  How does that hook up? And is that all I will need to make them work.  Im no electrician I don't want to blow something up!
Offline bambuhiphop
« Reply #172 on: March 03, 2014, 08:23:47 AM »
So I double checked and sure enough that is a filament bulb in there. The led flasher will let you flash a led bulb directly. It wires in place of the existing flasher. If you were to run leds with the stock flasher you would need to either have a blinker that has a load resistor already or buy and install a separate inline load resistor so the LED bulb will flash correctly.
« Reply #173 on: March 03, 2014, 09:14:42 AM »
You won't blow anything up, but when you activate your flashers, they will only turn on solid.  You just need to replace the mechanical existing flasher with an digital LED flasher.  It's a plug and play fix.
Offline calj737
  • I refuse...
« Reply #174 on: March 03, 2014, 09:17:50 AM »
I think Tweakin did this exact modification on his GT bike. Also references the same flasher replacement.
