Author Topic: Missing carb piece 1977 CB 750 Keihin 41A  (Read 4479 times)
Re: Missing carb piece 1977 CB 750 Keihin 41A
« Reply #25 on: March 29, 2011, 09:22:06 PM »
 Just for kicks, shake your airbox, if its off..
Offline anotherCB
« Reply #26 on: March 30, 2011, 06:07:35 AM »
754 you make me think I am smart now, because i did that already right after i realized the piece was gone  ;D too bad it was not there, but thanks for bringing it up!
1978 CB750K, 2016 R1200 GS/LC, 1973 R75/5
Offline GammaFlat
« Reply #27 on: March 30, 2011, 07:13:02 AM »
Now shake your exhaust pipe.  Couldn't resist. :)
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
Offline anotherCB
« Reply #28 on: March 30, 2011, 07:30:15 AM »
Good one GammaFlat...
Offline jtb
  • An unlikely
« Reply #29 on: March 30, 2011, 05:11:05 PM »
I've got an extra PD 41B body from an F model.  I suspect the tube is the wrong size, but I'll be glad to send it to you if you want to check.  Looks to me like the only way to remove it is to cut it out.
1977 CB750F
1985 V65 Sabre
« Reply #30 on: March 30, 2011, 08:41:30 PM »
 I got a puller built I think, will know tommorow...
Offline anotherCB
« Reply #31 on: March 31, 2011, 11:37:04 AM »
What a great group! So many people worrying about my small carb piece :-)
I am not sure whether the piece of the 42B will fit, but will check later.
I also tried to pull one of the other jets out of my carb without success. I believe it will only work with a special tool.
Thanks again guys, have the carbs almost cleaned and ready to go back on!
