Author Topic: Assembling my '74 CB550 - Putting it all back together  (Read 173290 times)
Offline 2strokeTrush
  • Can you get that back together sonny?
Re: Assembling my '74 CB550 - Electrical System Pt 3: Main Harness/Clutch
« Reply #250 on: September 15, 2014, 08:30:38 PM »
Your really helping my motivation on my 500, 550 builds!  Thanks man!
If You Aint First Your Last!!
 350F project-http://forums.sohc4.net/index.php?topic=133079.0
500F Project-http://forums.sohc4.net/index.php?topic=135660.0
« Reply #251 on: September 17, 2014, 06:20:33 PM »
Another great episode, Ron.  Will you attempt start up this year?
Offline MickB
« Reply #252 on: September 17, 2014, 07:58:53 PM »
SR thanks for your efforts, your documentation is a gift to all builders that'll keep on giving for a long time. Many future builders will gain from your doco.
BTW as you used all your old bolts, I'm waiting on getting all my 500's washers (I might still get copper washers), nuts and bolts back from being re-zinced.
I agree with your advise and 6 months ago I printed the Honda Workshop Manual out (available from this forum), it's been placed in a clip folder (so you can take out the pages you need), it's plenty greasy as it should be.
Looking forward to the next installments and then seeing you ride  probably the best resto'd 550 in the world.
Offline SohRon
« Reply #253 on: September 22, 2014, 05:20:41 PM »
To all who have replied, thanks! I've been away and haven't had a chance to keep up with the forum... we did our yearly camp outing and I'm pleased to say that this year nobody broke anything! Hoorah!
Café, Two stroke and Mick, I appreciate the encouragement and am always glad to hear that the thread has been useful... that's the name of the game, of course!  ;D
Stev-o, I hope to get it  up and running this fall. I'm closer to finished than the thread shows, so it is likely to happen soon! I ordered a tank kit from Caswell, and as soon as I get that taken care of she'll be pretty much ready to go.
Thanks to all who keep up with my insanity; I appreciate the support.
Offline Tews19
  • I am no
« Reply #254 on: September 22, 2014, 05:30:43 PM »
SohRon do you mind doing one of your great detailed write ups for the caswell liner? I ordered mine today and am freaking out about possibly ruining my tank.
BTW thanks, I got the tank!
1970 Honda CB750 survivor.
« Reply #255 on: September 22, 2014, 05:33:10 PM »
What an awesome thread.
I've been very pleased with my Caswell lined tank.
« Reply #256 on: September 22, 2014, 06:01:50 PM »
Me too, two tanks here.
Offline CycleRanger
  • No comment about being an
« Reply #257 on: October 15, 2014, 02:24:54 PM »
Incredible detail as always!
I used shrink tubing also to replace the missing plastic from the aluminum ties.
Yamiya sells real aluminum ties but like everything from them they are pricy.
http://www.yamiya750.com/index.php?main_page=product_info&cPath=185_96&products_id=839
That little grey clip for the clutch interlock cable may break on you.
I went through a couple before I just gave up.
I think they were "OOS" (old old stock) and were brittle from age.
Offline Restoration Fan
  • My wife will never call me
« Reply #258 on: October 19, 2014, 07:43:03 AM »
Subscribed.  Excellent detail.
Offline SohRon
Re: Assembling my '74 CB550 - Throttle installation
« Reply #259 on: October 19, 2014, 01:34:05 PM »
Thanks for the comments, guys. I appreciate it!
Yamiya sells real aluminum ties but like everything from them they are pricy... ...That little grey clip for the clutch interlock cable may break on you.
CR, those bands appear to be the same thing Honda is selling, down to the use of plastic sleeving for the covers. BikeBandit carries them as well, though I'm not sure they're any cheaper there...
The little plastic clip seemed to be pretty flexible to me; maybe they broke down and cast a new batch! Ya think?   :D
CRF, thanks for the vote of confidence, but I'm having enough trouble completing the work I've started to take on a new project! I'll let you know how it goes, though!
On to the update. I've been preparing a post for a while but it was just getting too long and picture heavy so I've decided to split it up to ease the bandwidth. In this section I'll begin with the throttle installation so that those of you that have been holding their breath can finally let go.  ;D
Here's a shot of the throttle components all laid out for your perusal
Shown above are the grip, throttle tube, the push and pull cables and, kind of in the middle right, a little assembly of parts known as the "Throttle Adjuster Screw" that appears only on the '74 model CB550.It's a real curiosity and, in fact, it's where I'll begin the install.
Here are the parts that make up the "Throttle Adjuster Screw": a screw, spring and a small half-moon shaped flat spring. It resides in the throttle section of the throttle/switch pod. After the switch pod is opened, the moon-shaped flat spring fits down into a recess in the bottom of the switch case with the curve oriented toward the throttle pipe (below, lower right), and the screw and coil spring are inserted from underneath, making adjustment of the flat spring possible (below, upper left). The moon-shaped spring should be covered with a film of grease, not shown here for clarity
There has been a lot of speculation in the forums as to exactly what this is, ranging all the way from a cruise control to a grip stabilizer. I've been told it's used to keep the engine at specific RPMs during tune-up procedures (which is entirely possible); others like to use it to keep a balky engine running during warm-up. Here's what HondaMan (a veteran Honda mechanic) has to say:
"Back in [the day], I heard lots of 'reasons' for it, the most common being that the bellcrank carbs have such a strong spring that it was (is) indeed difficult to hold 75 MPH for a long ride. Honda worried that it needed the strong spring in case the throttle slides get sticky, while the PR Department worried it was too much for the 'average' rider. It was too much for me: the whole first year I had my K1 I used the screw on "slow drag assist' all the time while my right arm grew enough to return tennis balls in matches against the school champs (without ever actually practicing...). When I got the K2 and found the spring to be even STRONGER, I immediately removed it, stretched it to 9" length, then put it back in. It's still that way. :D
Chopper riders of the era simply took the spring off and threw it as far as they could...then the DOT made Honda remove the Throttle Stop Screw altogether in late 1973. It was just another government buttinski move against Honda in those days.
It did spawn a whole industry of throttle assist devices, though."
Here are a couple of pages from the CB750 Shop Manual that explain its use a little more technically:
It's not really suggested for use as a cruise control and, in my humble opinion, you're "cruising" for a Darwin Award if you do; it's too fussy and awkward to fiddle with while in motion and just isn't practical. As HondaMan said, there's a "whole industry of throttle assist devices" out there to choose from specifically aimed at the task.
Back to business. With the Throttle Adjustment screw installed, I turned to the throttle pipe and cables. The grip is fitted onto the throttle pipe, which is then mounted to the handlebar. The bar should be lightly greased - especially at the open end that fits into a "pocket" in the OEM grips - to ensure smooth travel of the throttle pipe. With the pipe and grip in place, the cables can be added.
Here's a close-up of the cables (the ends, at least). Below left are the bar end connectors - the "pull" cable on the left and the "push" cable on the right. The "pull" cable is adjustable while the "push" cable is not
Above right, we have the carb end connections with, once again, the "pull" cable on the left and the "push" cable on the right. Again, the "pull" cable is fully adjustable while the "push" cable is mounted solidly in place...
I'll begin the installation with the "pull" cable. The cable shield fitting is threaded and screws into the front hole in the lower switch housing, where it's locked in place with a nut; I'm leaving it loose for now to aid with cable routing. I threaded the fitting in about a third of the way to set a preliminary adjustment; I can then move it in or out as needed as I progress with fitting the cable.
The "push" cable is positioned next; it's inserted into the switch body and is held in place via a threaded ferrule that's part of the cable fitting. Again, I'm leaving it loosely attached for now; once everything is in place and working correctly, I'll run up the ferrule until it's snug
Now that the cables are attached the ends are inserted into the throttle pipe
I've added a bit of grease to the cable ends to ensure smooth operation of the cable within the throttle pipe guides. With everything in place, I installed the switch cover and buttoned the switch pod up using two screws
So, here's where the real fun begins and, of course, I'm referring to cable routing. The first step, before doing anything else, is to make sure that the carbs are free and snap back from an open to closed position on their own. Just lift the bellcrank and let it snap shut. Reports of sluggish throttle response can sometimes be traced to sticking slides or a stretched return spring, so it's a good idea to test them out before getting the cables involved.
After verifying correct functioning of the carbs, the throttle cables are ready for routing. The main thing to remember is that they run pretty much behind everything. Once the cables are connected at the throttle, they're routed toward the left where they dive down between the gauge mounts on the upper steering yoke
Note that the cables run behind the brake hose and handlebar wiring and, at this point, I've oriented the "pull" cable to the top (outside). As the cables make their way around the headstock they cross and their positions are reversed so that the "push" cable is on top as they're routed under the tank mount, past the wiring harness and between the coils. The "pull" cable is actually a bit longer than the "push" cable in order to accomplish this routing...
...which is necessary to minimize the angle the "push" cable has to take as it plunges downward to the bellcrank stay. Having the "pull" cable on top at this point can force the cables to form a sharply angled "Y" at the bellcrank which has the potential for both interfering with cable movement and shortening the life of the cable
With the cables in position (the "push" cable is installed first) I adjusted the throttle according to the manual, then tightened all of the loose nuts down. I tested throttle movement by moving the handlebar from lock to lock, making sure the throttle snapped closed in all positions - especially in the full right hand position, as that puts the most strain on the throttle cables.
So, even though this seems like a short post, I'll be calling it done for now. The next episode will cover installation of the gauges and complete the electrical procedures. That should be coming soon, so stay tuned!  ;)
'til next time
« Last Edit: October 19, 2014, 01:54:46 PM by SohRon »
Offline Csrgti
« Reply #260 on: October 25, 2014, 10:57:23 AM »
The time and effort you're putting in to this build and more impressive , the time and effort you're putting into documenting this build is truly incredible. Thank you.
Offline SohRon
Re: Assembling my '74 CB550 - Electrical System Pt 4
« Reply #261 on: November 02, 2014, 02:55:22 PM »
You're welcome, Crgsti. I appreciate the encouragement!
Lots to do this post, so it's on to the next order of business, which is installation of the gauges. Here they are in an exploded view along with their mounting hardware. At left top are the gauges (or clocks, if you prefer), fully restored. Below them are the gauge cushions and the gauge mount "pans" (aka "cans")
On the right, at the top, is the gauge mounting bracket followed by the bracket mounting hardware: two each nuts, split washers and plain washers. Next, we find the hardware for mounting the gauge pans to the bracket: four each washers, split washers, nuts and mounting bolts. All of these nuts, washers and bolts (including the bracket mounting hardware) were originally anodized or Japanned black at the factory; I hit them with a shot of POR-15 Blackcote and they look good as new.
Below those is a grouping of several small rubber grommets. On the left is the grommet for the speedo trip-meter knob, then two lighting sub-harness grommets, followed by four mounts that fit between the gauges and gauge mount pans. At the bottom are four each chrome washers and acorn nuts that are used to mount the gauges to the pans. And, finally, to the right are the lighting wire sub-harnesses.
Assembling all of these parts into an operational gauge cluster is pretty straight forward, so I'm not really going to get into it here. I do have a couple of pointers I'd like to share, though...
When I dis-assembled these gauges initially, three out of the four gauge mount bolts were loose and fell out of the pans as I withdrew the gauges. They're meant to be captured by a couple of small tabs inside the pans; this makes removing and installing each gauge to the gauge bracket easier. My particular bolts either didn't get properly swaged in at the factory or loosened up with use over the years, so I refit them before re-installing the gauges. It's pretty simple: install each bolt into its hole from inside the pan, then, using a pair of pliers, vice-grips or what-have-you, bend the smaller tab down over the bolt head
They don't need to be moosed down tight and immovable - in fact leaving the bolts a bit loose makes installation onto the bracket a little easier. They just need to be securely held in place so that they don't turn or slip out of position while the nuts are being run up.
And although it's not apparent at first glance, the foam cushions do actually have a specific orientation. Flip them over take a look; there are two small square sided grooves opposite each other on the cushion "ring", one at the top, and one on the bottom. Since the cushions are symmetrical from top to bottom, by aligning either groove with the drain hole in the bottom of the pan you can be sure you've got the cushion installed correctly.
Finally, after assembly of all of the components is complete, the sub=harnesses from each gauge are criss-crossed across the back of the gauge mount bracket and held in position by a metal tang attached to the bottom of the bracket
So, here they are: the gauges in their mounting bracket. Below that the speedo cable on the outside with the tach cable on the inside and, in the center, two each nuts, washers and split washers for mounting the bracket to the upper steering yoke
Studs attached to the rear of the bracket slip into two mounts formed onto the yoke. All of the various wires and cables running between the mounts should be gathered together before installing the bracket so that nothing gets pinched between the two parts. Once the bracket and gauges are installed, the washers and nuts so helpfully indicated here by our little Seal-Point Tortie "Moosie"...
...are run up and torqued to spec (see the kind of stuff I have to deal with?)
Now that the gauges are in place on the bike, it's time to install the cables. I started with the speedometer by inserting the cable up into the speedo drive, then attached the cable fitting to the drive housing, coupling the cable to the gauge
The cable then routes down across the bike to the small clip installed onto the brake joint way back during the front brake procedure
This little "L" shaped clip is fitted with the leg of the "L" pointing toward the yoke with the cable running behind it, entrapping the cable between the clip and the yoke. (yeah, yeah; I know I installed it the other way 'round back at the brake procedure... I, um.., I just did it that way to... to keep it in the proper location with... an eye to reversing it when the time came... yeah, that's the ticket!).
Actually, that little clip is addressed nowhere in any of the Honda literature I have, the exception being the parts fiche for the bike. I became aware of it while searching the pictures in the owner's manual with an eye loupe, where I  saw it in the background with a cable running through it. Search as I could, I could find no other picture or mention of it anywhere. One more reason for the thread, I guess...
From the clip the cable routes down through the grommet installed onto the front fender (below left), then through this little wire guide mounted onto the fender stay (right), and finally it connects to the speedo drive at the wheel hub, where it's held in position with a screw (bottom)
Something to notice about the above pic is that I loosened up the axle clamp nuts and rotated the speedo gear so that it's perpendicular to the axis of the fork leg (in red). I then re-torqued the nuts, remembering to tighten the front nut first. This step completes installation of the speedo cable.
On to the tach cable, and it's fitted to the gauge just like the speedo cable was
After connecting to the gauge, the cable snakes under the bottom steering yoke and routes through the wire guide installed with the horn (inset below right), then on to the tach drive mounted to the head (below left)
And I like that base pic so much I'm posting an unadulterated copy of it here...
Sorry... just couldn't help myself...
Now that the gauges are sorted, the next items to consider are the front turn signals. Here they are with their mounting nuts and washers exposed
Installation is pretty simple; the wires and stems are threaded through the openings provided in the fork "ears", then the washers and nuts are run up to hold them in place (remember that it's orange on the left, light blue on the right)
Note that there are small dimples punched into each "ear" just behind the signal mount (above inset). Just align the "point" on the stem base "nut" with the dimple to orient the signals.
So, we'll need a ground for these signals, and that gives us a clean segue into fitting the headlight (smooth, right?). Here's the headlight support housing (AKA "shell" or "bucket"); it's one of the few parts off of the original bike that I'll be using on the build
I gave it a couple of shiny new coats of Rustoleum Painter's Touch 2X Gloss Black and it looks good as new. I'll be installing it using the hardware laid out below...
At top are the mounting nuts; these live inside the shell and are fitted with ground leads for the signals. Below them are chrome washers for the big mounting bolts, and two spacers. At bottom, on either side of the bolts, are two neoprene washers that aren't strictly standard, at least for this model. I picked them up at my local "ACE" in the "Large Neoprene Washer" section near the fender washers (below left)...
Using a dab of stick glue I stuck them to the inside of each of the headlight mounting "ears" (above right) in an effort to help keep the headlight shell in place and pointed properly down the road. They're not required; I just like to add this stuff because hey, that's just the kind of guy I am! Once the  headlight shell is in place they'll be invisible and, who knows? IIRC there's at least one model that uses something similar to this, so they may actually work!
As a preliminary step, I installed the spacers into holes provided in the shell (one on each side)
Installation is easy as pie: I gathered up all of the sundry wires and harnesses (don't forget the turn signal buzzer and front brake switch sub-harnesses!) hanging out at the front of the bike and threaded them through the opening in the rear of the shell while simultaneously raising it into position between the fork mount "ears" (opening oriented down). Next, I inserted the mounting bolts through the washers, the "ear" mounts and the spacers fitted into the shell, then secured everything using the special mounting nuts (below left inset)
These fit into a slot molded into the inner case wall so they can only be properly oriented one of two ways, either of which will suffice. Something to note is that each mounting "ear" has a small punch mark at its nose that indicates the centerline of the headlight shell (above right inset). There isn't a corresponding punch mark on the shell (at least the one I have), so it's simply a matter of aligning the punch mark with the centerline of the mounting "land" formed into the shell in order to get the headlight into the correct position
With the headlight bucket in place I got a stool, needle-nosed pliers, 000 steel wool and a pinch of Sour Diesel and, facing the bike straddling the front wheel, proceeded to make the final connections. I used the steel wool to go over all of the bullet connectors until they shined; then, using the needle nosed pliers, inserted each connector into its corresponding female counterpart until it clicked. There's a dimple in each of the female connectors that "clicks" into a gap at the end of the bullet "head"; you can have the connector partially inserted and not know it, so feel and listen for the "click" to make sure the connections are right.
So, that completes the electrical system installation. I tested everything using a tank battery I have and everything worked as it should; I took some shots but those will have to wait for another day as this has gone on long enough. In the next post I'll be starting the beast up and installing the tank, seat, side covers etc, etc.
Getting closer every day!
'til next time
« Last Edit: November 02, 2014, 03:03:38 PM by SohRon »
Offline SohRon
Re: Assembling my '74 CB550 - SHE LIVES!!!
« Reply #262 on: November 11, 2014, 09:50:22 PM »
SHE LIVES!!!
She's a bit "rattly" and doesn't want to idle very smoothly, but I'm hoping that syncing the carbs will help with that; on the day I took this video the temp dropped 30 degrees in two hours and it was starting to snow outside as I was doing the shoot, so I didn't get a chance to do anything more than start her up... this is how she sounds on her "virgin" run. I plan to get some quality tweaking time in this weekend, whatever the weather.
So, the bike is actually done, as you might be able to tell from the video. I was hoping to get the tank and seat on her and get some pics, but I ran out of time (see above). That's something else I'll have to get to soon. I'll continue posting procedures (should be more soon) but I just had to share the joy. It's been a long, strange trip, but I'm glad it's finally finished.  ;D
More to come...
« Reply #263 on: November 11, 2014, 11:18:44 PM »
That fully deserves a ... WooHoo!!   ;D
Offline flatlander
« Reply #264 on: November 11, 2014, 11:49:31 PM »
that's a great moment sohron, congratulations!
Offline SohRon
« Reply #265 on: November 12, 2014, 05:23:11 AM »
Thanks for the replies, guys. Yeah, I'm glad she's finally done; all told I've been fooling with this project for over six years, so it's great to see it finally come to fruition... I'm mainly glad she runs with no loud noises or leaks of anything anywhere (whew!).  I'll still be finishing up the thread, just had to let everyone in on the milestone  ;D ;D ;D
« Reply #266 on: November 12, 2014, 06:05:34 AM »
Woo Hoo - nothin like the first start up, congrats Ron.  Saw the video, plz tell us you actually did the start up previous to filming it? We know you are good, but it's rare to have a bike start immediately after setting for so long. Great job.
Offline SohRon
« Reply #267 on: November 12, 2014, 08:12:17 AM »
Why, Stev-o, are you doubting me?  ::)
This is actually the third time I started it up... it did take a bit of encouragement to get it to go the first time. but it's started first time ever since.
I'll get some pics this weekend, so stay tuned!
Offline Maurice
« Reply #268 on: November 12, 2014, 09:56:08 AM »
 :o
You should write a book. The Clymer people can go run for their lockers.
Would you mind doing a CB450, then a K6 750? I'll wait.
Offline fastbroshi
  • Puppet
« Reply #269 on: November 12, 2014, 10:05:17 AM »
...and a pinch of Sour Diesel...
ok I guess I'm the only one that caught that?  lol
Just call me Timmaaaaay!!!
Offline MickB
« Reply #270 on: November 12, 2014, 01:11:59 PM »
SohRon its a perfect ending to the project. Must've been a great feeling for you when she fired up, all the time spent restoring parts and working towards this moment, a very pleasing end.
« Reply #271 on: November 12, 2014, 03:44:37 PM »
Of course not, just making sure you are human!  Cant say it enough, fantastic job.
This will be the Jan BOTM.
Offline SohRon
« Reply #272 on: November 12, 2014, 10:48:47 PM »
I appreciate the comments, guys. Yes, it was a great feeling to hear her go, finally. I started her once before in the previous build, so I knew she's run, but a lot's happened between then and now, and you just never know...
A 750 thread sounds good! I'll take the pics, you write it up. Right?  ;)
Fastbroshi, I can't slip anything by you!   8)
I did forget to mention the mug of coffee, though... just didn't want anyone to know I drank the stuff...
More to come!
Offline Gman
« Reply #273 on: November 13, 2014, 06:28:14 PM »
Ummm, is there a BOTC category?  (Bike of the Century)  :)  Ron, so pleased to hear it finally, again, fire up!  Now all you have to do is throw a leg over it...
G
« Last Edit: November 13, 2014, 06:30:33 PM by Gman »
'76 CB550K
Stock airbox, MotoGPWerks 4-1, HondaMan ignition, Lesters
Offline CycleRanger
« Reply #274 on: November 14, 2014, 06:41:25 AM »
SHE LIVES!!!
http://youtu.be/GVLyG16Zi6w
Aww, heck, now you've ruined it!  They're always worth more if you don't take them out of the packaging!  :D
//Still in awe of your dedication to authenticity!
