Author Topic: Installed Dual disc on CB500 used existing "T" to run both brake lines but....  (Read 1255 times)
Offline kwaggs27
my question is, I ran the brake line from the master cylinder down to the port that was previously the pressure switch so I could just run the front ports down to both calipers but does it matter which port I run that master cylinder line to because for some reason my front brakes are dragging and make the bike VERY hard to roll. Even when I take it for a spin the pads don't retract into the caliper and the brake slows the bike down even without touching the lever. So Im wondering if I need to move that main line to the original location on the "T" to get the brakes to open up. Anyone have difficulties with this or is something wrong with my calipers possibly?
1971 CB500
Offline Kong
No, there is no sort of check valve in it.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline kwaggs27
Kong if Im creating pressure from the master cylinder and it is not releasing the pressure after I release the lever where is that pressure supposed to go? It should return back to the master cylinder reservoir correct?
1971 CB500
DH
Loosen up a bleeder valve (lever released) and note if there's any built up pressure.
If not, see if the calipers are still stuck. If no residual pressure at the caliper, and the wheel still won't roll, I'd think its a mechanical issue rather than hydraulic.
Offline kwaggs27
Well Im pretty sure I bled my brakes wrong. I bled them like I would have a car. Pumped the lever, held down and then cracked the bleeder and let air bubbles out and then fluid until it was only fluid. Im not sure this is the accurate way to bleed a dual disc setup. I will try a different method tomorrow and hopefully be riding the bobber this weekend if its a little warmer! ???
1971 CB500
Offline mjstone
  • I'm definitly not a
What are you using for a brake light switch?  I just used a double banjo bolt on mine.  Sounds to me like your bleeding it right.  DH's suggestion sounds more like it or maybe your master cylinder bleed holes are plugged.
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
Offline Kong
You're bleeding it right.  There are two small holes in the bottom of your master cylinder's reservoir, one of them is probably blocked.
1978 Honda CB550K
1977 Honda CB550K
Offline kwaggs27
The master cylinder has a switch built into it so I ran the wires up to that instead of the pressure switch. Kong is there any way to back pressure that reservoir in order to free up the clog or is disassembly the only method?
1971 CB500
I saw a mechanic put a c clamp on the caliper to force fluid back through the return hole in the master cylinder to force it open.
Offline d3buttz
  • More than just an
are you using the brake pads fom the old bike the brake setup was on?   with the floating style caliper on our bikes the pads wear at an angle over time, and if the pads are from a left side and put on the right for the dual- it will not be flush on the rotor, it will be at an opposite angle of the wear now that it is 180 degrees.  it will drag much like the symptoms you described and it happened to me using old pads.   these pistons donot retract very much at all -lets .030" at most, and if the wear angle is more than that-youll have dragging pads.  i faced my old pads off with a lathe(wear a mask, nasty stuff)  or replace them with new ones that are perpendicular/parallell/flat?.  the dragging went away and the spongy ness that i felt on the lever was actually the pads compensating for the angled gap from the wear i described earlier.   good luck!
« Last Edit: April 06, 2011, 06:36:43 PM by d3buttz »
http://forums.sohc4.net/index.php?topic=80508.0
1975 cb750f
1975 cb550k
1972 cb350k
1974 tl125
1996 Nissan pathfinder
1972 Datsun 240z
2002 Nissan sentra se-r spec-v
Offline plippo
  • A but crazy about Honda's
you can try loosening up the two big bolts that keep the 2 halves of the caliper together by 10/13 mm, then put a wood shim of 10/13 mm (or plastic) between the main pad and the disk.
then fasten the bolts. this normally pumps oil back to the reservoir enough to unclog the port...
Cb750 K0, 1, 2, 6, F1
Cb500 K0, 1, 2
Cb550 K '78
Cb550 SS F0, F1, F2
Cb400 F1
Cb450 Blackbomber
Cb450 73
CL450 68
CL350 71
GL1000 K0,1,2,3,Z
Cb250 K0
CB125 K0
XL250 K0, K3
VF500
VFR750
Spacy250
they all look good form the distance!
